Logging out and logging back in seems to fix it.
Yes, I did the same.
Phew. Thatâs better.
Solution ![]()
Are these the correct settings? Does the box in the âDark Modeâ section need to be checked? (mine wasnât initially)
It is correct, and the checkbox is not required for the toggle.
What is the purpose of the checkbox in that case?
When manually toggling the theme in the web browserâs settings, a Discourse instance can be configured to automatically switch colour schemes. Unchecking the box means the Discourse instance only follows the theme configured by the user account instead. However, that requires saving the changes in the Interface tab for it to take full effect, so if you manually toggle light/dark theme using the top button, that takes precedence instead, regardless of the other two settings.
This gives you flexibility for web browser fingerprinting purposes. You could have your web browser configured to have its theme set to Auto, the Discourse theme in the Interface tab set to Light, and only use the top button to toggle themes, assuming JavaScript is enabled.
