After librem5 has been on a while Millipixels will hang after taking picture
No, I’m looking for minimum values. The baseline when all apps are closed should always remain the same. That’s why I need trace.log as well.
Your data gives me this:
Se how the minimum changes around 5000 seconds, then drops a bit around 12000, and then jumps at 48000? I need to find out why it doesn’t drop all the way back (presuming you had the same programs open at the low times).
To expand on this: you cain obtain the chart by running this:
gnuplot -e 'set output "cma.png"; plot "cma.log" using 1:3'
If you get to the point where millipixels fails to take pics, ideally close all applications you can, including millipixels and then send both logs.
If you check out the logs and see that the baseline is getting higher even when all applications are closed, then please send both logs, too.
One good set of logs and we might be able to diagnose it.
I think I need to postpone further testing a bit and update again to the most recent kernel, because this debug kernel seems to bork my modem functionality (or revert back to the previously poor behaviour). Today I have had three modem crashes already that haven’t been recoverable without a phone restart.
I have triggered a rebase of that kernel branch - it was old enough to be very incompatible with current userspace. Once the CI produces the artifacts you should be able to install it again without losing modem reliability.
Excellent! Just as a side note, a recent call with the debug kernel triggered a change to 3G (before it crashed for the 3rd time today), while after upgrading to newest kernel VoLTE seems to work again (at least indicator stayed on 4G).
I’ve had calls that show 4G but upon running the tool show HSPA not VoLTE so not sure that’s a reliable indicator.
True, but I had VoLTE working before on this kernel, so I am guessing it is LTE this time too. But that was just a side note, so let’s keep this thread to Millipixels :slight_smile:.
My camera continues to work. I also am having modem issues. I’m going to abort this experiment also.
After reverting back by doing apt full-upgrade and rebooting. I managed to take one picture, closed the millipixels ap, opened it back up, and it failed to get another picture. Its hung again. Something is different about the test kernel that made my camera work.
Yes, I increased the amount of memory. That will do nothing if there is a leak, which is why the logs are required to move forward.
Would you like me to continue with the test kernel for a longer period of time in hopes it will eventually fail? If its helpful, I’ll do it.
Definitely helpful, thanks for the offer. After @dos fixed up the kernel package, you’ll have to download and install it again to get stability on par with the regular one.
Test resuming.
I feel like you’re asking me to reproduce a problem that this kernel has fixed. I have taken many pictures without issue. I’ll keep logging data every second but I’m thinking the storage space will run out before I ever see this problem again.
I don’t know if it’s fixed. But I need to have someone confirm whether it is or not, by using it for some prolonged time (days?) and reporting the results.
If the problems come out, it will be regardless of how many pictures you take.
I’m not sure if what I’ve noticed is the same, but as i started to use the camera more, it’s been doing eternal saves of pics more often, freezing the cam picture as well. Only identifiable theme seems to be that I have other apps running as well.
I have resumed testing again, logging with 5s interval. So far so good, but I have seen a couple of spikes in cma.log. Values have returned to the previous ones right after though.
Here are some observation after about an hour of intense testing:
I didn’t get gnuplot to work, so I plotted the chart in LibreOffice Calc instead.
As seen in the chart, there are some outliers, but directly after returning to the previous value. However, the values trend higher probably due to more open apps.
I have taken over 20 photos without Millipixels hanging. I opened more and more apps during the tests and at the end had the following open apps in addition to Millipixels:
Telegram
Geary
Firefox
Markets
Loupe
Calls
Chatty
Calendar
Contacts
Tootle
Weather
Terminal
Settings
Password safe
PureOS store
Maps
Free42 (calculator)
DejaDup backup (backing up phone)
Lollipop
htop
System usage
Nautilus
uPlayer (playing video)
Full log here:
1934.78 6372.64 8698
1939.78 6379.15 8698
1945.36 6385.87 8698
1950.73 6392.70 8698
1955.73 6398.88 8698
1960.74 6404.44 8698
1965.74 6409.48 8698
1970.74 6410.74 8698
1975.75 6413.96 71803
1980.75 6417.39 8698
1985.76 6428.22 8698
1990.76 6440.24 8698
1995.77 6458.12 8698
2000.78 6476.14 8698
2005.78 6493.02 8698
2010.79 6505.45 8698
2015.79 6524.61 8698
2020.80 6542.30 8698
2025.80 6561.45 8698
2030.81 6570.81 8698
2035.81 6576.09 8698
2040.82 6578.82 8698
2045.82 6585.88 8698
2050.95 6593.99 8698
2055.95 6610.62 8698
2060.96 6625.62 8698
2065.96 6638.79 8698
2070.97 6651.83 8698
2075.97 6666.40 8698
2080.98 6672.33 8698
2085.98 6677.25 8698
2090.99 6684.65 23713
2096.67 6686.84 8698
2101.68 6689.40 8698
2106.68 6693.23 8698
2111.68 6700.21 8698
2116.69 6706.22 8698
2121.69 6712.35 8698
2127.38 6714.30 8698
2132.38 6717.00 8698
2137.38 6721.55 8698
2142.39 6727.53 8698
2147.40 6734.37 8698
2152.40 6741.38 8698
2157.40 6748.68 8698
2162.41 6756.12 8698
2167.41 6763.40 8698
2172.42 6770.64 8698
2177.42 6778.22 8698
2182.42 6785.43 8698
2187.43 6792.85 8698
2192.43 6800.32 8698
2197.44 6807.55 8698
2202.44 6814.24 8698
2207.44 6819.82 8698
2212.45 6826.07 8698
2217.45 6832.35 8698
2222.46 6838.45 8698
2227.46 6844.62 8698
2232.46 6850.71 8698
2237.47 6856.93 8698
2242.47 6862.96 8698
2247.48 6869.25 8698
2252.48 6875.31 8698
2257.48 6881.82 8698
2262.49 6887.22 7683
2267.49 6887.85 49361
2273.16 6889.99 8698
2278.17 6890.29 8698
2283.17 6892.80 8698
2288.18 6903.68 8698
2293.18 6914.57 8698
2298.19 6922.74 8698
2303.19 6937.77 8698
2308.20 6955.23 8698
2313.21 6973.88 8698
2318.21 6992.29 8698
2323.22 7010.78 8698
2328.22 7028.56 8698
2333.23 7046.69 8698
2338.23 7064.87 8698
2343.24 7081.56 8698
2348.24 7097.80 8698
2353.25 7112.06 10714
2358.25 7127.88 10714
2363.26 7142.66 10714
2368.26 7157.79 10714
2373.26 7172.58 10714
2378.27 7186.57 10378
2383.27 7200.89 10378
2388.28 7218.48 10378
2393.28 7236.35 10378
2398.96 7254.87 10378
2404.62 7273.98 10378
2409.63 7292.29 10378
2414.63 7310.20 10378
2419.64 7328.75 10378
2424.65 7347.27 10378
2429.65 7365.60 10378
2434.65 7384.15 10378
2439.66 7402.41 10378
2444.66 7417.29 10378
2449.67 7432.64 10378
2454.67 7449.20 10378
2459.68 7458.31 38217
2464.68 7462.58 9172
2469.68 7463.05 10378
2474.69 7463.59 10378
2479.69 7468.40 10378
2484.70 7477.45 10327
2489.70 7489.14 10378
2494.70 7502.85 10378
2499.71 7510.67 60659
2504.71 7513.69 10378
2509.72 7519.06 10378
2514.72 7527.20 10378
2519.72 7541.08 10378
2524.73 7556.81 10378
2530.41 7576.55 10378
2535.69 7589.94 10378
2540.70 7598.02 10378
2545.70 7613.33 10378
2550.71 7625.48 10378
2555.71 7639.23 10973
2560.72 7657.13 10973
2565.72 7675.41 10973
2570.73 7693.09 11026
2575.73 7707.85 11017
2580.74 7724.01 11017
2585.74 7739.22 11026
2590.75 7754.13 11026
2595.75 7766.77 11026
2600.76 7779.17 11026
2605.76 7792.94 10762
2610.76 7809.11 11935
2615.77 7818.43 10711
2620.77 7826.23 10711
2625.78 7830.66 10762
2630.78 7831.21 10762
2635.78 7832.52 10762
2641.19 7832.62 10762
2646.19 7832.77 22571
2651.20 7833.40 6541
2656.20 7837.15 6541
2661.21 7847.25 6541
2666.21 7856.74 6541
2671.22 7866.22 6541
2676.22 7871.86 6541
2681.22 7872.80 10762
2686.23 7874.44 10762
2691.91 7874.58 10762
2696.91 7876.20 10762
2701.92 7884.71 10762
2706.92 7898.04 10762
2711.93 7912.39 10762
2716.93 7920.10 10762
2721.94 7922.59 10762
2726.94 7924.29 10762
2731.94 7925.86 10762
2737.62 7926.76 10762
2742.63 7927.72 10762
2747.63 7928.80 10762
2752.64 7929.73 28983
2757.64 7931.44 10762
2762.64 7931.60 10762
2767.65 7934.46 10762
2772.65 7940.23 10762
2778.34 7950.74 10762
2783.50 7960.58 10762
2788.50 7970.52 10762
2793.51 7977.31 11026
2798.51 7984.69 11026
2803.52 7994.84 11026
2808.52 8005.03 11026
2813.53 8013.22 11026
2818.53 8024.54 11026
2823.54 8035.09 11026
2828.54 8045.56 11026
2833.55 8056.25 11026
2838.55 8066.39 11026
2843.56 8077.70 11026
2848.56 8087.18 11026
2853.56 8098.16 11026
2858.57 8107.42 11026
2863.57 8118.23 11026
2868.58 8126.15 11026
2873.58 8135.58 11026
2878.73 8147.98 11026
2884.27 8159.17 11026
2889.74 8167.94 11026
2894.75 8178.98 11026
2899.75 8188.55 11026
2904.76 8197.07 11026
2909.76 8202.93 10644
2914.76 8211.62 10644
2919.77 8220.36 10644
2924.77 8229.35 10644
2929.78 8239.06 10644
2934.78 8249.99 10644
2939.78 8261.27 10644
2944.79 8273.36 10925
2949.79 8282.84 10711
2954.80 8294.67 10711
2959.80 8307.62 10711
2964.81 8319.25 10711
2969.82 8330.82 10711
2974.82 8343.08 10711
2979.83 8356.71 10711
2984.83 8368.02 10711
2989.84 8381.13 10711
2994.84 8391.71 10711
2999.85 8404.94 10711
3004.85 8414.73 10711
3009.86 8425.86 10711
3014.87 8438.88 10711
3019.87 8449.52 10711
3024.88 8461.18 10762
3029.88 8468.89 12895
3034.88 8476.25 10762
3039.89 8484.47 10762
3044.89 8497.23 10762
3049.90 8509.14 10762
3054.91 8521.61 10762
3059.91 8533.82 10762
3064.92 8543.62 10762
3069.92 8555.44 10762
3074.92 8557.96 10762
3079.93 8564.95 10762
3084.94 8575.79 10762
3089.95 8585.47 11078
3094.95 8590.58 10762
3099.96 8599.14 10762
3104.96 8610.69 10762
3109.97 8623.20 10762
3114.97 8635.48 10762
3119.98 8646.95 10762
3124.98 8656.35 10762
3129.98 8667.23 10762
3134.99 8675.80 10762
3139.99 8685.22 10762
3145.00 8696.17 10762
3150.00 8707.23 10762
3155.00 8719.43 10762
3160.01 8731.41 10762
3165.01 8740.34 10762
3170.22 8750.85 10762
3175.22 8752.09 10762
3180.22 8754.05 10762
3185.24 8754.06 10762
3190.29 8754.13 10762
3195.76 8754.85 48219
3200.77 8755.66 10762
3205.88 8755.97 10762
3210.88 8756.60 10762
3215.89 8757.66 10762
3220.89 8759.89 10762
3225.90 8762.75 10762
3230.90 8766.77 10762
3235.90 8771.50 10762
3240.91 8781.79 12778
3245.91 8786.12 12324
3251.47 8792.40 12410
3256.47 8802.99 12410
3261.48 8811.97 12391
3266.49 8822.08 12391
3271.50 8834.33 12391
3276.50 8843.74 12391
3281.50 8852.80 12391
3286.51 8864.79 12391
3291.51 8873.24 12391
3296.52 8884.74 12391
3301.56 8896.06 12391
3306.57 8906.59 12391
3311.57 8918.30 12391
3316.58 8928.40 12391
3321.58 8938.21 10711
3326.59 8948.05 10711
3331.59 8957.26 10711
3336.60 8969.21 10711
3341.60 8976.61 10711
3346.60 8988.60 10711
3351.61 8996.21 10711
3356.61 9007.10 10711
3361.62 9017.52 10711
3366.62 9034.53 10711
3371.63 9052.20 10711
3376.63 9068.89 10711
3381.64 9085.23 10711
3386.64 9100.17 10644
3391.65 9108.75 10730
3396.66 9125.87 10730
3401.66 9139.88 10711
3406.67 9156.71 10711
3411.67 9173.61 10711
3416.68 9190.43 10711
3421.68 9207.23 10711
3426.68 9223.64 10711
3431.69 9240.27 10711
3436.70 9257.02 10711
3441.70 9271.10 10925
3447.38 9280.59 16167
3452.70 9297.15 16167
3457.71 9314.20 16167
3462.72 9331.37 16167
3467.72 9346.27 16218
3472.73 9362.05 16218
3477.74 9370.06 16202
3482.74 9374.30 16202
3487.74 9378.57 16202
3492.76 9382.42 16202
3498.44 9388.86 16218
3503.48 9393.85 16376
3508.51 9401.24 16218
3513.52 9405.12 16218
3518.52 9410.14 16218
3523.53 9423.78 16218
3528.53 9440.86 16218
3533.54 9457.85 16218
3538.54 9474.51 16218
3543.55 9491.64 16218
3548.56 9508.17 16218
3553.56 9524.48 16218
3558.57 9540.93 16218
3563.58 9557.55 16218
3568.58 9574.91 16218
3573.59 9593.01 16218
3578.59 9610.51 16218
3583.60 9628.06 16218
3588.61 9645.59 16218
3593.61 9663.14 16218
3598.62 9680.67 16218
3603.62 9697.58 16218
3608.63 9710.44 16218
3613.64 9727.07 16218
3618.64 9742.57 16218
3623.64 9760.12 16218
3628.65 9776.97 16218
3633.66 9792.42 16218
3638.66 9807.41 16218
3643.66 9819.46 16218
3648.67 9829.78 16218
3654.34 9849.03 16218
3659.53 9864.08 16218
3664.54 9880.84 16218
3669.54 9897.29 16218
3674.55 9913.23 16218
3679.55 9930.03 16218
3684.56 9947.91 16218
3689.56 9964.69 16218
3694.57 9981.05 16218
Anything else you want me to provide?
If you catch an actual hang in logs, that would be cool. In that case, don’t forget trace.log, because without it I am unable to find the culprit.
I think I’m going to consider it solved when the users of this kernel complete a week without a hang.
Hi,
I haven’t read all the backlog of this thread (sorry).
How do I test the fix/kernel? Just by making a system update on the phone?
Or is this some dev-build where I have to do something more?
