Bluetooth Handsfree Audio
I not yet a superhero as dos, but what i found is that wpan-audio-pipeline on gnu mobile is broken, which make stutering.
However gdawn pipeline is better than gcrimson which will potentially reduce ALL stuterings not just audio, audio-streaming but video.
Feel libre to ignore my post.
The answer appears to wait until Dawn? I will say that, when I was on PostmarketOS, the bluetooth was only marginally better. The team over there does not seem to support the Librem5 all that well, however. Maybe @dos and Purism will fork it or improve it for PureOS.
Yes.
Purism Gdawn it is not PMOS v.BUGGY. So the NEW PIPELINE what i said is not there on pmos yet, so that why: marginally better, even just now.
PMOS do not care Librem5,users. I even suggest Purism to ignore pmos,mobian for safety. However divine dawnos and furilab furios is OK for now. I know, i know pmos,mobian,collabora-power is bugs fixing on front PureOS Mobile, but it not great for many reason.
I do not trap it.
Try flashing the firmware jail to a newer version.
https://source.puri.sm/Librem5/librem5-fw-jail
I was told I had an older version by checking with sha256sum /lib/firmware/brcm/*
$ sha256sum /lib/firmware/brcm/*
eeebca3d8a877a6a252f783b66c1350702554f74f0d5e28fda62544bb2cbfa72  /lib/firmware/brcm/BCM4362A2.hcd
46f62076768e50938d0e29b306b24d4663de20b07b474c4759d5801fcbf0bdde  /lib/firmware/brcm/brcmfmac43752-sdio.bin
fc0bed644e599e622600431e7e3a11b5816dc7981f1a747c657475a3a761fabf  /lib/firmware/brcm/brcmfmac43752-sdio.clm_blob
5349c42f676d44166289e9ac0e734579aafc7c5195a3eef323acf1d583cecb50  /lib/firmware/brcm/brcmfmac43752-sdio.txt
After flashing, the checksums became this:
18901a5bef1d418b6895e92d0afae36234f4160b237465dfca3d75e9844e93ef  /lib/firmware/brcm/BCM4362A2.hcd
f892de1047ac91dfed071a0fd2beb1ea783d6d98599ac53477cae8799f1f05ef  /lib/firmware/brcm/brcmfmac43752-sdio.bin
5143146e1923f87f7aab8df043abcf89a657fa9fdc3b22a38806399730d9a97a  /lib/firmware/brcm/brcmfmac43752-sdio.clm_blob
2d2723101fe9c66c853ddb1e2d715851ba100a4390f8ac72fc84dd35736cc66f  /lib/firmware/brcm/brcmfmac43752-sdio.txt
I still sometimes get audio stutters here and there but it is a lot better than before. Sometimes I need to disconnect the device and reconnect it to get clear audio for some reason.
I am sure you probably know this, but the bluetooth is known to stutter if the bluetooth page in settings is open, so make sure that bluetooth settings are closed.
How odd, I don’t get the stuttering with the Bluetooth settings page open :thinking:
I support this post.
NEWPIPELINE on GDAWN, BT stutering will gone.
PurismElectronics
PostmarketOS and Mobian both worked good BT and aux jack handsfree on my original PinePhone… for a while, then ended up working about the same way that Byzantium behaves on L5 (stuttering, no autoswitching BT modes when a call comes in whilst listening to a podcast, no use of the aux jack mic, etc.). I will say that Crimson is an improvement, but only in the area of stuttering – I recently drove a 4 hour trip in a 2016 Ford and it only stuttered momentarily a few times). Still doesn’t use the mic and there was echo on the for the caller on the other end, but not for me. I think it’s the mic thing.
When I try to connect to the wife’s 2023 Ford, the connection is rejected by the Ford with the message, “no compatible Sync features”… “Sync” is what they call their BT interface.
This is why I use the aux jack in my car. Still doesn’t use the mic, but when I set the levels correctly, it is usable.
