Hey, thanks but I was of course connected to the internet while downloading the images. Did not work, tried it several times. Always just ends with “No files to extract”.
How do you want to extract binary blob files:
1 - Extract from the current machine (must be same as target machine and run coreboot)
2 - Extract from a pre-built coreboot image (filename must be coreboot-orig.rom)
3 - Files are copied manually (copy to coreboot/3rdparty/blobs/mainboard/purism/librem_skl/)
The following files are needed :
descriptor.bin - The Intel Descriptor - SHA256: d5110807c9d67cea6d546ac62125d87042a868177241be4ae17a2dbedef10017
me.bin - The Intel Management Engine image - SHA256: 3042150c7f655293a69bcf886836732fc451439ae551a2babf3173f4f0d9a8d3
vbt.bin - The Video BIOS Table - SHA256: 51fa214ca44a61b171662d4c2ca6adc1aa3dc6c3d7a24bf9ae5f249f012d61c0
fspm.bin - The Intel Firmware Support Package - SHA256: 7a1acc72073969e6753bbfe145f06c3f4d35e2516cb241641eae968705e2cc46
fsps.bin - The Intel Firmware Support Package - SHA256: 0dac94d249473e9d366597fd1f96a0232fb7bf045a3d08f16784961273351822
vgabios.bin - The VGA BIOS - SHA256: 18d861485b86f93dad2b294cebd40b99eb03493d32b514e731ddb8dcf3a1ce83
cpu_microcode_blob.bin - The CPU Microcode Update - SHA256: 9c84936df700d74612a99e6ab581640ecf423d25a0b74a1ea23a6d9872349213
The vbt.bin, fspm.bin and fsps.bin can automatically be downloaded, the me.bin can also be
downloaded, configured and patched so it will match the expected SHA256.
Enter your choice (default: 1):
remote: Counting objects: 4, done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 4 (delta 2), reused 0 (delta 0)
Unpacking objects: 100% (4/4), done.
From https://code.puri.sm/kakaroto/coreboot-files
579101e..75f97b8 master -> origin/master
Updating 579101e..75f97b8
Fast-forward
build_coreboot.sh | 20 ++++++++++----------
1 file changed, 10 insertions(+), 10 deletions(-)
Already on 'skylake'
Your branch is up to date with 'origin/skylake'.
fatal: No names found, cannot describe anything.
Replacing all version templates with .
Checking for a C compiler... found.
Target arch is x86
Target OS is Linux
Checking for libpci headers... found.
Checking version of pci_get_dev... new version (including PCI domain parameter).
Checking if libpci is present and sufficient... yes.
Checking for libusb-0.1/libusb-compat headers... found.
Checking if libusb-0.1 is usable... yes.
Checking for libusb-1.0 headers... found.
Checking if libusb-1.0 is usable... yes.
Checking for FTDI support... not found.
Checking if Linux SPI headers are present... yes.
Checking for utsname support... found.
Checking for clock_gettime support... found.
make[1]: Entering directory '/home/lurkas/building-coreboot/coreboot/flashrom/util/ich_descriptors_tool'
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/home/lurkas/building-coreboot/coreboot/flashrom/util/ich_descriptors_tool'
Using 'sudo flashrom' to grab the local machine's flash content
flashrom on Linux 4.14.0-3-amd64 (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
coreboot table found at 0x7aad3000.
WARNING! You seem to be running flashrom on an unsupported laptop.
Laptops, notebooks and netbooks are difficult to support and we
recommend to use the vendor flashing utility. The embedded controller
(EC) in these machines often interacts badly with flashing.
See the manpage and https://flashrom.org/Laptops for details.
If flash is shared with the EC, erase is guaranteed to brick your laptop
and write may brick your laptop.
Read and probe may irritate your EC and cause fan failure, backlight
failure and sudden poweroff.
You have been warned.
Proceeding anyway because user forced us to.
Found chipset "Intel Skylake U Premium".
This chipset is marked as untested. If you are using an up-to-date version
of flashrom *and* were (not) able to successfully update your firmware with it,
then please email a report to flashrom@flashrom.org including a verbose (-V) log.
Thank you!
Enabling flash write... Warning: Setting Bios Control at 0xdc from 0x8b to 0x89 failed.
New value is 0x8b.
Warning: SPI Configuration Lockdown activated.
OK.
Found Programmer flash chip "Opaque flash chip" (16384 kB, Programmer-specific) mapped at physical address 0x0000000000000000.
Reading flash... done.
Using 'sudo dmidecode' to grab the local machine's serial number
File ../coreboot-orig.rom is 16777216 bytes
Flash Region 0 (Flash Descriptor): 00000000 - 00000fff
Flash Region 1 (BIOS): 00200000 - 00ffffff
Flash Region 2 (Intel ME): 00001000 - 001fffff
Flash Region 3 (GbE): 07fff000 - 00000fff (unused)
Flash Region 4 (Platform Data): 07fff000 - 00000fff (unused)
Flash Region 5 (Reserved): 07fff000 - 00000fff (unused)
Flash Region 6 (Reserved): 07fff000 - 00000fff (unused)
Flash Region 7 (Reserved): 07fff000 - 00000fff (unused)
Flash Region 8 (EC): 07fff000 - 00000fff (unused)
--2018-03-05 20:36:24-- http://download1479.mediafire.com/mfvjf7t3i7yg/1angqt361xdf8k0/Intel+CSME+11.0+Firmware+Repository+Pack+r50.rar
Slår opp vertsnavn download1479.mediafire.com (download1479.mediafire.com) … 205.196.123.167
Kobler til download1479.mediafire.com (download1479.mediafire.com)|205.196.123.167|:80 …tilkoblet.
HTTP-forespørsel sendt. Venter på svar … 200 OK
Lengde: 56091592 (53M) [application/x-rar]
Lagrer til: «me_11_repository.rar»
me_11_repository.rar 100%[===========================================================================================================================================================>] 53,49M 42,4KB/s på 25m 5s
2018-03-05 21:01:30 (36,4 KB/s) - «me_11_repository.rar» lagret [56091592/56091592]
./build_coreboot.sh: linje 213: unrar: fant ikke kommando
--2018-03-05 21:01:30-- https://www.rarlab.com/rar/unrarsrc-5.5.8.tar.gz
Slår opp vertsnavn www.rarlab.com (www.rarlab.com) … 5.135.104.98
Kobler til www.rarlab.com (www.rarlab.com)|5.135.104.98|:443 …tilkoblet.
Lengde: 222285 (217K) [application/x-gzip]
Lagrer til: «unrar.tar.gz»
unrar.tar.gz 100%[===========================================================================================================================================================>] 217,08K 49,8KB/s på 4,4s
2018-03-05 21:01:35 (49,8 KB/s) - «unrar.tar.gz» lagret [222285/222285]
unrar/arccmt.cpp
unrar/archive.cpp
unrar/arcread.cpp
unrar/blake2s.cpp
unrar/blake2s_sse.cpp
unrar/blake2sp.cpp
unrar/cmddata.cpp
unrar/coder.cpp
unrar/consio.cpp
unrar/crc.cpp
unrar/crypt.cpp
unrar/crypt1.cpp
unrar/crypt2.cpp
unrar/crypt3.cpp
unrar/crypt5.cpp
unrar/dll.cpp
unrar/encname.cpp
unrar/errhnd.cpp
unrar/extinfo.cpp
unrar/extract.cpp
unrar/filcreat.cpp
unrar/file.cpp
unrar/filefn.cpp
unrar/filestr.cpp
unrar/find.cpp
unrar/getbits.cpp
unrar/global.cpp
unrar/hardlinks.cpp
unrar/hash.cpp
unrar/headers.cpp
unrar/isnt.cpp
unrar/list.cpp
unrar/log.cpp
unrar/match.cpp
unrar/model.cpp
unrar/options.cpp
unrar/pathfn.cpp
unrar/qopen.cpp
unrar/rar.cpp
unrar/rarpch.cpp
unrar/rarvm.cpp
unrar/rawread.cpp
unrar/rdwrfn.cpp
unrar/recvol.cpp
unrar/recvol3.cpp
unrar/recvol5.cpp
unrar/resource.cpp
unrar/rijndael.cpp
unrar/rs.cpp
unrar/rs16.cpp
unrar/scantree.cpp
unrar/secpassword.cpp
unrar/sha1.cpp
unrar/sha256.cpp
unrar/smallfn.cpp
unrar/strfn.cpp
unrar/strlist.cpp
unrar/suballoc.cpp
unrar/system.cpp
unrar/threadmisc.cpp
unrar/threadpool.cpp
unrar/timefn.cpp
unrar/ui.cpp
unrar/uicommon.cpp
unrar/uiconsole.cpp
unrar/uisilent.cpp
unrar/ulinks.cpp
unrar/unicode.cpp
unrar/unpack.cpp
unrar/unpack15.cpp
unrar/unpack20.cpp
unrar/unpack30.cpp
unrar/unpack50.cpp
unrar/unpack50frag.cpp
unrar/unpack50mt.cpp
unrar/unpackinline.cpp
unrar/uowners.cpp
unrar/volume.cpp
unrar/win32acl.cpp
unrar/win32lnk.cpp
unrar/win32stm.cpp
unrar/archive.hpp
unrar/array.hpp
unrar/blake2s.hpp
unrar/cmddata.hpp
unrar/coder.hpp
unrar/compress.hpp
unrar/consio.hpp
unrar/crc.hpp
unrar/crypt.hpp
unrar/dll.hpp
unrar/encname.hpp
unrar/errhnd.hpp
unrar/extinfo.hpp
unrar/extract.hpp
unrar/filcreat.hpp
unrar/file.hpp
unrar/filefn.hpp
unrar/filestr.hpp
unrar/find.hpp
unrar/getbits.hpp
unrar/global.hpp
unrar/hash.hpp
unrar/headers.hpp
unrar/headers5.hpp
unrar/isnt.hpp
unrar/list.hpp
unrar/loclang.hpp
unrar/log.hpp
unrar/match.hpp
unrar/model.hpp
unrar/options.hpp
unrar/os.hpp
unrar/pathfn.hpp
unrar/qopen.hpp
unrar/rar.hpp
unrar/rardefs.hpp
unrar/rarlang.hpp
unrar/raros.hpp
unrar/rartypes.hpp
unrar/rarvm.hpp
unrar/rawint.hpp
unrar/rawread.hpp
unrar/rdwrfn.hpp
unrar/recvol.hpp
unrar/resource.hpp
unrar/rijndael.hpp
unrar/rs.hpp
unrar/rs16.hpp
unrar/savepos.hpp
unrar/scantree.hpp
unrar/secpassword.hpp
unrar/sha1.hpp
unrar/sha256.hpp
unrar/smallfn.hpp
unrar/strfn.hpp
unrar/strlist.hpp
unrar/suballoc.hpp
unrar/system.hpp
unrar/threadpool.hpp
unrar/timefn.hpp
unrar/ui.hpp
unrar/unicode.hpp
unrar/unpack.hpp
unrar/version.hpp
unrar/volume.hpp
unrar/makefile
unrar/dll.def
unrar/dll.rc
unrar/UnRAR.vcxproj
unrar/UnRARDll.vcxproj
unrar/readme.txt
unrar/license.txt
unrar/acknow.txt
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c rar.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c strlist.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c strfn.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c pathfn.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c smallfn.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c global.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c file.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c filefn.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c filcreat.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c archive.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c arcread.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c unicode.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c system.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c isnt.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c crypt.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c crc.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c rawread.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c encname.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c resource.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c match.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c timefn.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c rdwrfn.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c consio.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c options.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c errhnd.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c rarvm.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c secpassword.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c rijndael.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c getbits.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c sha1.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c sha256.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c blake2s.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c hash.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c extinfo.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c extract.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c volume.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c list.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c find.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c unpack.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c headers.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c threadpool.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c rs16.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c cmddata.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c ui.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c filestr.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c recvol.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c rs.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c scantree.cpp
c++ -O2 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -DRAR_SMP -DUNRAR -c qopen.cpp
c++ -o unrar -pthread rar.o strlist.o strfn.o pathfn.o smallfn.o global.o file.o filefn.o filcreat.o archive.o arcread.o unicode.o system.o isnt.o crypt.o crc.o rawread.o encname.o resource.o match.o timefn.o rdwrfn.o consio.o options.o errhnd.o rarvm.o secpassword.o rijndael.o getbits.o sha1.o sha256.o blake2s.o hash.o extinfo.o extract.o volume.o list.o find.o unpack.o headers.o threadpool.o rs16.o cmddata.o ui.o filestr.o recvol.o rs.o scantree.o qopen.o
strip unrar
UNRAR 5.50 freeware Copyright (c) 1993-2017 Alexander Roshal
Extracting from me_11_repository.rar
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1140_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1144_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1148_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1149_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1151_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1153_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1155_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1155_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1158_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1158_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1158_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1160_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1160_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1160_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1160_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1163_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1163_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1165_CON_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1165_COR_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1166_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1166_CON_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1166_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1166_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1168_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1168_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1168_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1168_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1169_CON_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1169_COR_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1171_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1171_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1171_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1171_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1173_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1173_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1173_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1173_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1177_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1178_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1178_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1178_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1178_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1180_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1180_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1180_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1180_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1180_SLM_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1183_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1183_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1183_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1183_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1191_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1191_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1191_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1191_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1194_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1194_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1194_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1194_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1196_CON_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1197_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1197_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1197_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1197_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1198_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1198_CON_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1198_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1202_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1202_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1202_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1202_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1205_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1205_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1205_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.1205_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.0.7101_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.1.1001_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.1.1001_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.1.1001_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.10.1002_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.10.1002_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.10.1002_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.10.1002_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.11.1002_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.11.1005_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.11.1006_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1001_CON_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1001_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1001_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1002_SLM_LP_C0_YPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1003_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1003_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1003_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1008_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1008_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1008_CON_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1008_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1008_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1008_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1010_SLM_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1010_SLM_LP_C0_YPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.12.1013_SLM_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.15.1003_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.15.1003_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.15.1003_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.15.1003_COR_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.16.1000_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.16.1000_CON_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.16.1000_CON_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.16.1000_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.16.1000_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.16.1000_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.17.1002_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.17.1002_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.1001_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.1002_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.1002_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.1002_CON_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.1002_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.1002_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.1002_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.3003_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.18.3003_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.2.1003_CON_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.2.1003_CON_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.2.1003_COR_H_D0_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.22.1000_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.22.1000_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.22.1000_COR_LP_C0_NPDM_PRD_EXTR.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.22.3001_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.24.1000_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.24.1000_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.24.1000_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.24.1000_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.25.3001_CON_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.25.3001_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.25.3001_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.25.3001_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.25.3001_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.26.3000_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.26.3000_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.26.3000_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.27.3000_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.27.3000_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.27.3000_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.28.3002_CON_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.28.3002_COR_H_D0_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.28.3002_COR_LP_C0_NPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.28.3002_COR_LP_C0_YPDM_PRD_RGN.bin
Skipping Intel CSME 11.0 Firmware Repository Pack r50/11.0.3.1000_SLM_LP_C0_NPDM_PRD_EXTR.bin
No files to extract
