I try to save the most important things in the readme, so you could check it one more time ![]()
So I ran systemctl --user disable wireplumber.service(first command to solve the sound)
and I got
‘Failed to connect oto bus: No medium found’
systemctl status → degraded, systemctl --failed → systemd-networkd->wait-online.service loaded failed failed Wait for Network.
I do have network connected.
Try to run the second command to enable wireplumber in videoonly mode and check which sound server is used (pactl info).
Ooops, I have the same status but no issues with sound. I will pay attention to this, thanks for reporting. ![]()
so running the 2nd command worked, after that, I run the 3 command again. I have the sound now.
There is another problem. The Pure Store except the main page, other category page won’t show any apps. Do you have that problem?
That is normal behavior. The store is just bad. There are other threads about that mess.
My advice is not use Pure Store as it is quite obsoleted. I also remove it from autostart list (recipe could). You could use flatpak directly in a terminal (with flathub repo).
Hopefully they can update in the crimson. It has been a whole
Can you share the exact command you used to install these packages?
Just sudo apt install systemd-resolved in a terminal. You can install all of them in one line:
sudo apt install systemd-container systemd-resolved phosh-plugins pureos-theme-gnome pureos-artwork-base kbd
When I do that, it says something like ‘unable to find package kdb’
Sorry, the right name is kbd.
$ apt list | grep kbd
kbd/byzantium,now 2.3.0-3 arm64 [installed,automatic]
Yeah, that is what I did. I tried many times, all worked. But I have to say, it is a bit more lag than the byzantium ha, but I don’t care I think.
Do you still want lists of files that are about to be removed [as per git instructions] or is this irrelevant…?
What apt-get dist-upgrade suggests after updating repo list:
The following packages were automatically installed and are no longer required:
bind9-dnsutils cinnamon-desktop-data cinnamon-l10n cryptsetup-run dnsutils
file-roller gir1.2-ayatanaappindicator3-0.1 gir1.2-gdesktopenums-3.0
gir1.2-geocodeglib-1.0 gir1.2-gfbgraph-0.2 gir1.2-gnomedesktop-3.0
gir1.2-goa-1.0 gir1.2-goocanvas-2.0 gir1.2-gtkspell3-3.0 gir1.2-gweather-3.0
gir1.2-nm-1.0 gir1.2-packagekitglib-1.0 gir1.2-rb-3.0 gir1.2-rest-0.7 gist
gkbd-capplet grub-common grub-theme-pureos hddtemp hwdata inxi
libappstream-glib8 libc-devtools libcamel-1.2-62 libchamplain-0.12-0
libchamplain-gtk-0.12-0 libcinnamon-desktop4 libclamav9 libcolord-gtk1
libdazzle-1.0-0 libdmapsharing-3.0-2 libdrm-nouveau2 libebackend-1.2-10
libebook-1.2-20 libebook-contacts-1.2-3 libecal-2.0-1 libedata-book-1.2-26
libedata-cal-2.0-1 libedataserver-1.2-25 libedataserverui-1.2-2
libexpat1-dev libfam0 libgeocode-glib0 libgfbgraph-0.2-0
libgnome-bluetooth13 libgnomekbd-common libgnomekbd8 libgoocanvas-2.0-9
libgoocanvas-2.0-common libgpod-common libgpod4 libgrilo-0.3-0
libgweather-3-16 libgweather-common libjs-jquery libjs-sphinxdoc
libjs-underscore libkf5attica5 libkf5xmlgui-bin liblept5 libllvm11
libmalcontent-ui-0-0 libmozjs-78-0 libmusicbrainz5-2 libmusicbrainz5cc2v5
libnautilus-extension1a libnemo-extension1 libofa0 libphonon4qt5-4
libphonon4qt5-data libpython3-dev libpython3.11-dev libpython3.9-dev
libqt5designer5 libqt5help5 libqt5test5 librest-0.7-0 libruby2.7
librygel-core-2.6-2 librygel-db-2.6-2 libsgutils2-2 libtepl-5-0
libtesseract4 libtfm1 libtracker-control-2.0-0 libtracker-miner-2.0-0
libtracker-sparql-2.0-0 libwlroots10 libxapp1 libxcb-dri2-0 libxklavier16
nemo-data os-prober p7zip p7zip-full pciutils phonon4qt5
phonon4qt5-backend-vlc phosh-plugins plymouth-theme-pureos
pureos-artwork-base pureos-init-disk-crypto pureos-theme-gnome
python-apt-common python-odf-doc python-odf-tools python-pip-whl python3-apt
python3-construct python3-defusedxml python3-distro-info python3-enchant
python3-future python3-ldb python3-lockfile python3-mako python3-markupsafe
python3-numpy python3-odf python3-talloc python3.9-dev rake ruby ruby-json
ruby-minitest ruby-net-telnet ruby-power-assert ruby-rubygems ruby-test-unit
ruby-xmlrpc ruby2.7 rubygems-integration squashfs-tools tesseract-ocr
tesseract-ocr-eng tesseract-ocr-osd tree unattended-upgrades xapps-common
zlib1g-dev
Use ‘sudo apt autoremove’ to remove them.
The following packages will be REMOVED:
blueman gir1.2-champlain-0.12 gir1.2-clutter-1.0 gir1.2-cogl-1.0
gir1.2-coglpango-1.0 gir1.2-gtkchamplain-0.12 gir1.2-gtkclutter-1.0
gnome-passwordsafe libevdocument3-4 libevview3-3 libfolks-eds25 libfolks25
libgail-3-0 libglib2.0-0 libgnome-desktop-3-19 libgtk-3-0 libgupnp-av-1.0-2
libpurple0 librygel-renderer-2.6-2 librygel-server-2.6-2 nemo
nemo-fileroller ocrfeeder pyqt5-dev-tools pyqt5-examples python3-argon2
python3-dev python3-pwquality python3-pycryptodome python3-pycurl
python3-pykeepass python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.sip
python3-pyxattr python3-renderpm python3-reportlab python3-reportlab-accel
python3-sane python3-smbc python3-software-properties rhythmbox-plugins
software-properties-common
The following NEW packages will be installed:
bolt desktop-base fonts-gfs-didot-classic fonts-quicksand fwupd gcc-14-base
gcr4 geocode-glib-common gir1.2-adw-1 gir1.2-geocodeglib-2.0
gir1.2-girepository-2.0 gir1.2-graphene-1.0 gir1.2-gtk-4.0
gir1.2-gweather-4.0 gir1.2-javascriptcoregtk-4.1 gir1.2-malcontent-0
gir1.2-rest-1.0 gir1.2-shumate-1.0 gir1.2-soup-3.0 gir1.2-webkit2-4.1
gir1.2-xdp-1.0 gnome-bluetooth-3-common gnome-bluetooth-sendto gnome-console
gnome-remote-desktop heif-gdk-pixbuf heif-thumbnailer libabsl20200923
libaom3 libappstream5 libavif15 libcamel-1.2-64 libcjson1 libcloudproviders0
libcolord-gtk4-1 libconfig++9v5 libdav1d6 libdirectfb-1.7-7 libdisplay-info1
libduktape205 libebackend-1.2-11 libebook-1.2-21 libebook-contacts-1.2-4
libecal-2.0-2 libedata-book-1.2-27 libedata-cal-2.0-2 libedataserver-1.2-27
libedataserverui-1.2-4 libedataserverui4-1.0-0 libei1 libeis1
libevdocument3-4t64 libevview3-3t64 libffado2 libffi8 libflashrom1
libfolks-eds26 libfolks26 libfreeaptx0 libfreerdp-server3-3 libfreerdp3-3
libftdi1-2 libfwupd2 libfwupdplugin1 libgav1-0 libgcab-1.0-0 libgck-2-2
libgcr-4-4 libgeocode-glib-2-0 libglib2.0-0t64 libgmobile-common libgmobile0
libgnome-bg-4-2t64 libgnome-bluetooth-3.0-13 libgnome-bluetooth-ui-3.0-13
libgnome-desktop-3-20t64 libgnome-desktop-4-2t64 libgnome-rr-4-2t64
libgoa-backend-1.0-2 libgprofng0 libgranite-7-7 libgranite-7-common
libgssdp-1.6-0 libgtk-3-0t64 libgtksourceview-5-0 libgtksourceview-5-common
libgupnp-1.6-0 libgupnp-av-1.0-3 libgweather-4-0 libgweather-4-common
libharfbuzz-gobject0 libharfbuzz-subset0 libheif-plugin-aomenc
libheif-plugin-dav1d libheif-plugin-libde265 libheif-plugin-x265 libhwy1t64
libidn12 libimath-3-1-29 libjavascriptcoregtk-4.1-0
libjavascriptcoregtk-6.0-1 libjcat1 libjxl-gdk-pixbuf libjxl0.10 libjxl0.9
libkf5archive-data libkf5guiaddons-data libldacbt-enc2 libliftoff0
libllvm17t64 liblrdf0 liblttng-ust-ctl4 liblttng-ust0 liblua5.4-0
libmalcontent-ui-1-1 libmessaging-menu0 libmozjs-128-0 libmutter-15-0
libnautilus-extension4 libneon27 libnftables1 libnma-gtk4-0
libopenexr-3-1-30 libopenh264-7 libpeas-2-0 libpeas-2-common
libpipewire-0.3-common libpoppler126 libportal-gtk4-1 libportal1
libpurple0t64 libpython3.11 libpython3.11-dev libpython3.11-minimal
libpython3.11-stdlib libqrtr-glib0 libraptor2-0 libraqm0 librest-1.0-0
librygel-core-2.8-0 librygel-db-2.8-0 librygel-renderer-2.8-0
librygel-server-2.8-0 libsdbus-c++1 libsharpyuv0 libshumate-1.0-1
libshumate-common libsoup-3.0-0 libsoup-3.0-common libsoup2.4-common
libspelling-1-1 libstartup-notification0 libsvtav1enc1 libsystemd-shared
libtepl-6-2 libtepl-common libtracker-sparql-3.0-0 libtss2-esys-3.0.2-0
libtss2-mu0 libtss2-rc0 libtss2-sys1 libtss2-tcti-cmd0 libtss2-tcti-device0
libtss2-tcti-mssim0 libtss2-tcti-swtpm0 libtss2-tctildr0 liburcu6
libvte-2.91-gtk4-0 libwebkit2gtk-4.1-0 libwebkitgtk-6.0-4 libwebp7
libwinpr3-3 libwireplumber-0.5-0 libwlroots-0.18 libxcb-errors0 libxcb-ewmh2
libxcb-record0 libxcvt0 libxml++2.6-2v5 libyajl2 libyuv0 malcontent
malcontent-gui mesa-libgallium mutter-common-bin pkexec polkitd
python3-setuptools-scm python3.11 python3.11-minimal rpcsvc-proto
systemd-dev tecla tpm-udev waked webp-pixbuf-loader wireplumber
The following packages will be upgraded:
adduser adwaita-icon-theme appstream binutils binutils-aarch64-linux-gnu
binutils-common bubblewrap busybox chatty cheese cheese-common cryptsetup
cryptsetup-bin cryptsetup-initramfs cryptsetup-run dmeventd dmsetup
dnsmasq-base dpkg dpkg-dev duplicity eog epiphany-browser
epiphany-browser-data evince evince-common evolution-data-server
evolution-data-server-common feedbackd feedbackd-common flatpak folks-common
gcr geary gedit gedit-common geoclue-2.0 gir1.2-freedesktop
gir1.2-gdesktopenums-3.0 gir1.2-gdkpixbuf-2.0 gir1.2-geoclue-2.0
gir1.2-glib-2.0 gir1.2-gnomedesktop-3.0 gir1.2-gst-plugins-base-1.0
gir1.2-gstreamer-1.0 gir1.2-gtk-3.0 gir1.2-harfbuzz-0.0 gir1.2-json-1.0
gir1.2-nm-1.0 gir1.2-pango-1.0 gir1.2-peas-1.0 gir1.2-soup-2.4 gjs
glib-networking glib-networking-common glib-networking-services
gnome-bluetooth gnome-calendar gnome-calls gnome-clocks gnome-contacts
gnome-control-center gnome-control-center-data gnome-desktop3-data
gnome-initial-setup gnome-keyring gnome-keyring-pkcs11 gnome-maps
gnome-online-accounts gnome-session-bin gnome-session-common
gnome-settings-daemon gnome-settings-daemon-common gnome-shell-common
gnome-sushi gnome-terminal gnome-terminal-data gnome-usage gnome-user-share
gnome-weather gsettings-desktop-schemas gstreamer1.0-gl gstreamer1.0-libav
gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good
gstreamer1.0-plugins-ugly gstreamer1.0-pulseaudio gstreamer1.0-x
gtk-update-icon-cache hwdata kgx kwayland-data less libadwaita-1-0
libamtk-5-0 libamtk-5-common libappstream4 libarchive13 libasound2
libasound2-data libatomic1 libbinutils libbrotli1 libc-bin libc-dev-bin
libc-l10n libc6 libc6-dev libcairo-gobject2 libcairo-script-interpreter2
libcairo2 libcallaudio-0-1 libcc1-0 libcheese-gtk25 libcheese8
libcogl-pango20 libcogl-path20 libcogl20 libcryptsetup12 libctf-nobfd0
libctf0 libdevmapper1.02.1 libdpkg-perl libdrm-amdgpu1 libdrm-common
libdrm-nouveau2 libdrm-radeon1 libdrm2 libebml5 libegl-mesa0 libegl1
libepoxy0 libevdev2 libfeedback-0.0-0 libflatpak0 libgbm1 libgcc-s1
libgck-1-0 libgcr-base-3-1 libgcr-ui-3-1 libgdk-pixbuf-2.0-0
libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgeoclue-2-0 libgexiv2-2
libgirepository-1.0-1 libgjs0g libgl1 libgl1-mesa-dri libglapi-mesa libgles2
libglib-object-introspection-perl libglib2.0-bin libglib2.0-data libglvnd0
libglx-mesa0 libglx0 libgmp10 libgnome-autoar-0-0 libgnutls30 libgoa-1.0-0b
libgoa-1.0-common libgoa-backend-1.0-1 libgomp1 libgpgme11 libgraphene-1.0-0
libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0
libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 libgtk-3-bin
libgtk-3-common libgtk-4-1 libgtk-4-bin libgtk-4-common
libgtk-4-media-gstreamer libgudev-1.0-0 libharfbuzz-icu0 libharfbuzz0b
libheif1 libinput-bin libinput10 libitm1 libjs-sphinxdoc libjson-glib-1.0-0
libjson-glib-1.0-common libkeyutils1 libkf5archive5 libkf5auth-data
libkf5authcore5 libkf5codecs-data libkf5codecs5 libkf5completion-data
libkf5completion5 libkf5config-bin libkf5config-data libkf5configcore5
libkf5configgui5 libkf5configwidgets-data libkf5configwidgets5
libkf5coreaddons-data libkf5coreaddons5 libkf5crash5 libkf5dbusaddons-bin
libkf5dbusaddons-data libkf5dbusaddons5 libkf5globalaccel-bin
libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5
libkf5guiaddons5 libkf5i18n-data libkf5i18n5 libkf5iconthemes-bin
libkf5iconthemes-data libkf5iconthemes5 libkf5itemviews-data
libkf5itemviews5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kiocore5
libkf5kiogui5 libkf5kiowidgets5 libkf5notifications-data
libkf5notifications5 libkf5service-bin libkf5service-data libkf5service5
libkf5solid5 libkf5solid5-data libkf5waylandclient5 libkf5widgetsaddons-data
libkf5widgetsaddons5 libkf5windowsystem-data libkf5windowsystem5
libkf5xmlgui-data libkf5xmlgui5 liblcms2-2 libldb2 liblsan0 liblvm2cmd2.03
liblzma5 libmbim-glib4 libmbim-proxy libmm-glib0 libnice10 libnm0
libnma-common libnma0 libnss-myhostname libnss-systemd libopenjp2-7
libpam-gnome-keyring libpam-systemd libpango-1.0-0 libpangocairo-1.0-0
libpangoft2-1.0-0 libpangoxft-1.0-0 libpeas-1.0-0 libpeas-common
libpipewire-0.3-0 libpipewire-0.3-modules libpixman-1-0 libpng16-16
libpolkit-agent-1-0 libpolkit-gobject-1-0 libpoppler-glib8 libpurple-bin
libpython3-dev libpython3-stdlib libqmi-glib5 libqmi-proxy librsvg2-2
librsvg2-common libruby2.7 libsmbclient libsoup-gnome2.4-1 libsoup2.4-1
libspa-0.2-modules libstdc++6 libsystemd0 libtalloc2 libtdb1 libtevent0
libtiff5 libubsan1 libudev1 libupower-glib3 libvte-2.91-0 libvte-2.91-common
libwayland-client0 libwayland-cursor0 libwayland-egl1 libwayland-server0
libwbclient0 libwebpdemux2 libwebpmux3 libx11-6 libx11-xcb1 libxfixes3
libxml2 libxmlb2 locales lvm2 mesa-va-drivers mesa-vdpau-drivers
mesa-vulkan-drivers modemmanager mutter-common nautilus nautilus-data
nautilus-extension-gnome-terminal network-manager network-manager-gnome phoc
phosh phosh-mobile-settings phosh-mobile-tweaks phosh-plugins pidgin-data
pipewire pipewire-bin policykit-1 purple-lurch purple-xmpp-carbons
purple-xmpp-http-upload python-apt-common python3 python3-apt python3-bcrypt
python3-cairo python3-cffi-backend python3-cups python3-dbus
python3-distutils python3-evdev python3-gi python3-gi-cairo python3-gst-1.0
python3-ldb python3-lib2to3 python3-lxml python3-mako python3-markupsafe
python3-minimal python3-nacl python3-numpy python3-pil python3-pip
python3-pygments python3-talloc python3-tk python3-yaml rsync ruby2.7 rygel
samba-libs squeekboard systemd systemd-sysv systemd-timesyncd tracker
tracker-extract tracker-miner-fs ucf udev upower wpasupplicant wys
xdg-desktop-portal xdg-desktop-portal-gtk xwayland xz-utils
374 upgraded, 197 newly installed, 43 to remove and 0 not upgraded.
Need to get 328 MB/328 MB of archives.
After this operation, 892 MB of additional disk space will be used.
[edit: 502 bad gateway atm to these, while net otherwise works]
[edit 2: “Codeberg is currently unavailable for technical reason”]
Thanks!
libfolks-eds25 and libgnome-desktop-3-19 should be upgraded to libfolks-eds26 and libgnome-desktop-3-20t64 respectively. You could try to install it first:
sudo apt install libfolks-eds26 libgnome-desktop-3-20t64
Btw. have you considered securing your repo? See: SecureApt - Debian Wiki
Setting up a secure apt repository: from man apt-secure
If you want to provide archive signatures in an archive under your maintenance you have to:
- Create a toplevel Release file. if it does not exist already. You can do this by running apt-ftparchive release (provided inftp apt-utils).
- Sign it. You can do this by running gpg -abs -o Release.gpg Release.
- *Publish the key fingerprint, that way your users will know what key they need to import in order to authenticate the files in the archive. *
Whenever the contents of the archive changes (new packages are added or removed) the archive maintainer has to follow the first two steps previously outlined.
Thanks. Will try after Codeberg is back in a minute…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
libfolks25 : Depends: folks-common (= 0.14.0-1) but 0.15.9-2 is to be installed
libgnome-desktop-3-19 : Depends: gnome-desktop3-data (< 3.39) but 44.0-5 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Thanks for the link! Do you think it matters? I may try for Crimson backports…
Ay, I think it does - and it is good practice to do so! It is also a balance with the work you do and the kind of audience you have with the users of L5.
The main trick is to understand who needs libfolks25 and try to install (upgrade) it by the same command. I thought it was Chatty…
