Camera and microphone icons not in top bar when related physical switch is off
@irvinewade
Yes, like that. Just reverse the roles of the input ‘file’ and the output ‘file’ to the dd command, although I would normally also add bs=1M status=progress for both backup and restore.
I have restored the dd image to /dev/sdb2, but when I boot up the phone, after the librem 5 logo, I got a blank screen.
Could it be that grub, located on the /boot partition (/dev/sdb1) does not find the disk because it has a different UUID than the partition created when flashing the phone?
It must be noted too, that, I reflash an image with encryption enabled, while the partition I backed up was not encrypted.
You should be backing up and restoring the entire disk, not just one specific partition of the disk!
Ok, then a manual copy is my only hope, then.
For the problem with the camera I will contact the Purism support directly.
Thank you for the quick reply.
You probably have two recovery options.
  1. Attempt to repair the boot partition to reflect the situation on the root file system. Both of the issues you raise will be relevant (UUID and encryption). OR
  2. Reflash the phone again and copy back any relevant personal files from the backup.
