Why is that ? the L5 is not suppose to negociate this configuration ? (on the power supply, 12v⎓1.5A is available)
Yes, L5 is supposed to only negotiate 5V with 0.2.0 firmware. The type-C controller is susceptible to the infamous Vbus-to-CC-short failure and even though there are some mitigations in place on Evergreen, the risk of damage is still non-zero so we opted for the safe option of disallowing voltages higher than 5V to make sure it doesn’t happen at all.
The firmware version can be checked with:
purism@evergreen:~$ sudo cat /sys/kernel/debug/tps6598x/0-003f/customer_use
0x4c35445000000200
I got the phone on December 2020. It’s one of the firsts evergreen.
purism@pureos:~$ sudo cat /sys/kernel/debug/tps6598x/0-003f/customer_use
0x4c35445000000101
Should I flash the new firmware?
yes, you can flash the new version of the firmware.
amber
or byzantium
? I’m still on the former.
Maybe different PD firmware version. I’m on 0.2.0 (I upgraded)
Maybe you are manually overriding with magic i2c commands.
To be honest, I thought Purism was still always limiting it to 5V.
I’m on byzantium
, but it’s the firmware, as @dos said few rows above. Latest version (0.2.0) actually limits the voltage to 5V.
