Chatty Drops Texts
Woke up this morning and my chatty history with 1 person is gone. What would cause that and what does it mean? Other history is still present.
I had recently upgraded this older Byzantium install to Crimson.
I had something similar happen on Byzantium a looong time back, but I didn’t care about the history and never looked in to it.
Have you tried poking around the sqlite DB filestored at ~.purple/chatty/db/chatty-history.db?
Two things I can think of that could maybe cause something like that: (1) if you changed phone number for a contact, or if you changed the name of a contact, then that could affect how the history is shown because I think chatty sees the phonenumber as the identifier, if that phonenumber belongs to another contact name then the history could appear under that name instead. (2) something with timestamps, it could happen that the history is still there but you don’t see it because it is much further down the list, because some message had a timestamp that was old. Then that history could be moved down the list, but it might still be there.
Also, try greping inside the database as spiffy suggested.
Or better
sudo apt install sqlite3
then understand the basics of the schema
then use sqlite3 to go looking for text messages.
If you did a full disk image before the upgrade to crimson, you may even be able to examine the database as it was before the upgrade.
Yes, and then for example
echo ".dump" | sqlite3 ~/.purple/chatty/db/chatty-history.db > tmp-db-dump.txt
grep -i pizza tmp-db-dump.txt
(Assuming that the missing messages were about pizza.)
I use carddav from my nextcloud server as main contacts DB and, in case I boot and somehow the Librem 5 times out reaching my server (it’s rare, but happens), then some threads are gone and all others become a list of phone numbers. Once connection is established, I don’t know what I have to do to get chatty and the call log to try to “resolve” the contacts again, so restarting is what I do.
