Discovered Why L5 MMSC Fails Now
  1. Open Settings → Mobile Network, then under Advanced, select Access Point Names:
  1. On the next screen, tap the + button on the top right corner:
  1. On the next screen, input these two values separately into the two text fields labeled Name and APN, then tap the Save button on the top right corner:
    • Koodo
    • sp.koodo.com
  1. Open Chats, tap the hamburger menu on the top right corner, then tap Preferences:
  1. Under Protocol Settings, tap SMS and MMS Settings:
  1. Under MMS Carrier Settings, input these three values separately into the three text fields labeled MMSC, APN, and Proxy, then tap the Apply button on the top right corner:
    • http://aliasredirect.net/proxy/koodo/mmsc
    • sp.koodo.com
    • mmscproxy.mobility.ca
  1. Send an MMS to someone.
That behavior is unusual, normally it is like your experience before.
My suggestion is to turn off and on your Librem 5 to see if that causes any abnormalies to resolve themselves.
OK, now I understand what you were getting at.
Maybe phosh developer @guido.gunther knows why that is happening.
It happens to me occasionally, too, but only for slow-opening apps, as far as I can tell. I don’t consider it important, though, as the apps eventually load.
Thank you. No idea why it changed overnight. Maybe it’s not possessed or haunted after all - maybe it’s gremlins. OMG - maybe it’s all three! :grin:
Thanks again.
~s
I recall that I had to reset it after flashing byzantium.
Me too. Seems like it’s defaulting the wrong way but that’s a minor issue I guess.
@amarok & @irvinewade
Is it possible that the OP has a devkit and not evergreen as we have supposed?
Just throwing the idea out there🤷‍♂️
It’s an Evergreen, based on this:
and: Frequently Asked Questions · Wiki · Librem5 / Librem 5 Community Wiki · GitLab
[quote=“FranklyFlawless, post:21, topic:23867”]
6. * http://aliasredirect.net/proxy/koodo/mmsc
  • sp.koodo.com
Compared your setup in above and checked and dbl checked - mine match’s everything except:
My Settings doesn’t show “Mobile Network” it shows Settings > Network and below is Mobile. i.e.
Wi-Fi
Network
Mobile
Bluetooth
etcetera
but, my “Mobile” settings are same as your’s except of course Network is Koodo and > Koodo is Automatic and Koodo has a check beside it.
If I turn Automatic off it changes to “Choose Network” and after a long wait, it lists a lot of carriers, Koodo is last.
Tested sending Msgs w/ pic - nadda.
I received several messages that state:
You received a MMS, but it expired on 2024-06-27 16:09
The phone lists my sent MMS - the last with a pic as of last Saturday. From the bottom up, it shows one MMS sent and shows pic and dated “Saturday”
Today I received many, many messages inbound sayoing:
Chat put these two expired messages notifications in between 6th (bottom up) and 5th. like the following
Saturday
Saturday
Saturday
Saturday
Saturday
Saturday
Saturday
Saturday
All the Saturday sent’s w/ pic are on the right-side, the notifications on left-side. The pics shown Sent has a centred square frame w/ a icon two mountain peaks and moon over the smaller peak. There is only one sent that shows the actual pic.
I think that Koodo received my Send’s w/ pic but no one received them. Then after so many days, they dump it and let me know?
Wish I could get Warp installed. Working on it - then I can take screenshots without hooking L5 up to Hoyoki hub. Can’t do right now in middle getting Warp installed. :woozy_face:
Support has reached out to me and I’m in the midst of preparing L5 to send to them. I don’t know what good it will do if Canada’s carriers are preventing people from using devices that protects the user from stalkers, as well as carrier’s stalkers and spies.
It’s as if carriers are saying:
If we (the Carrier) can’t Stalk you, Monitor you online, Inject code into your device, and Record everything you do online, and from where and at what location, using what device so we may Control you, then you can’t play’.
And they take the Internet and leave.
and I can remember when telephone companies said the Internet is just a fad and wouldn’t support it. Fibbers! :unamused:
Go to the usage app and force quit chats three times and then it ‘should’ clear up the duplicates
Now why didn’t I think of that! And it’s so obvious! :crazy_face: and it worked. :+1:
Did that fix a bug or could it continue?
I seem to be having issues with MMS messages now too. I can see the messages arriving in /.mms/modemmanager but they never show up in chatty. Tried killing chatty and reseting everything, deleting the contents of that folder to no avail. Does anyone know what’s going on here?
It was working a couple days ago.
I am also having the same problem. From Sharon’s informative posts i did a bit of digging around in the phone settings and discovered on 4G i can make and receive calls and receive sms but not send them. MMS won’t work on 4G, if i change network settings to 3G only i can make calls and receive calls, send and receive sms and MMS also works but sometimes gets stuck in the modem. I’m with Vodafone Ireland and they are already in the process of shutting down 3G, Limerick has lost 3G and Dublin will lose it next month. 2G and 4G is all that will be available (5G also but L5 can’t handle that). I have called Vodafone support from my L5 and they do not seem to have any issues with the handset (today they reset my AccessPoint/APN settings for me) but i think i’m kinda in Limbo until 3G is entirely gone. Chatty is hard work, i delete conversations and they persistantly reappear (killall chatty from terminal isn’t reliable), there is no reliability with date stamps in a linear order. And yes messages get stuck in modem (MMCLI checks tell me they are there but something is amiss). I have Volte enabled and modem is up to date. @Sharon please don’t leave, you are a champion!
Hmm. I can send/receive texts, but not send/receive texts (MMS?) with pics.
I did try 3,4G and it defaulted to 3G. It tried 3G only and received 1 text/pic test out 4. Went back to 4G only and still no text&pic. Weird.
I may also make/receive voice calls - although quality is a issue but I think that falls with the carrier.
I feel still that Telcoms want to control things and don’t want any interference such people’s rights to privacy to get in the way.
There is a saying, and attributed IMO to the wrong author but it goes like this ‘Remove one freedom every generation, and soon there’ll be no freedoms and no one will notice’. That was coined a long time ago - before computers.
Now, with the ultra-high speed of communications and purposelessly discombobulated changes in systems, procedures and rules that old axiom should start with ‘Remove one freedom every week and …’
We need tools like Librem stuff. But it’s only really great if we may use it online without anti-privacy thugs and bullies denying us access to internet while using privacy respecting devices.
IMO of course.
Could it be that changes that are collateral damages such as dropping service to privacy respecting devices be slowly creeping around? After all, how many people don’t use duopoly leashes phones?? And how many would make it here to ask what is going on?
I’m gonna go play Oblivion now
~s
When i send a test sms on 4G and it does not come through i get the following when i use
mmcli -m any --messaging-list-sms
/org/freedesktop/ModemManager1/SMS/0 (unknown)
I would love to say more in response but ‘Walls have Ears’.
Ring Ring Banana Phone, Cellular, modular, interactivodular.
That was not a slight on L5. Just comm’s in general.
That is a really great reply, going to check my settings now, I am not using that provider and not in Canada so I can’t copy paste solution but that is useful.
I don’t suppose you know why it starts with http instead of https do you?
I already know that Rogers has excommunicated the Librem 5 and will not support it, so when HSPA finally gets turned off in favour of VoLTE, I will not be able to use the voice and text functions on the Rogers network. I am fairly certain the other carriers in Canada will have the same thing in place. My workaround is to port my number to a SIP provider and do everything over the data connection. I’ve already tested this with jmp.chat which provides SIP accounts and it works. I’m told the turning off of HSPA will be about a year from now.
No, I only care about providing solutions.
