From Amber to Crimson on my Mini
Is there any documentation on the full process to bring a Mini from Amber to Crimson? As I understand it, I will have to erase the system drive and do a complete fresh install, but would love to have a how-to to read over first.
Thanks for any help…
Amber has been dead for some years so you may struggle to get documentation but I would start with creating a full disk image of your existing system drive. I would do this for two reasons:
  1. In case something goes pear-shaped with the process.
  2. You may have personal files or settings that you want a copy of in order to reinstate them after the fresh install.
The process for a reinstall is documented here: Installation - Purism user documentation
It may help to clarify whether your current install is using LUKS disk encryption and whether you want that for the fresh install.
Disclaimers: I don’t own a Mini and I haven’t done a fresh install of PureOS on x86 hardware. So the above advice is of a general nature only.
For in-place upgrades, I’d recommend that you upgrade to Byzantium first, install all of the Byzantium upgrades, then upgrade to Crimson.
There is no GUI upgrade tool from Amber to Byzantium so you need to manually edit the /etc/apt/sources.list. You can follow these instructions: https://docs.puri.sm/Software/PureOS/cfg/sw-management.html#manually-upgrade-to-a-newer-pureos-release
For those instructions, instead of entering crimson, type in byzantium to upgrade from Amber to Byzantium.
Once you’re on Byzantium and have updated your system with the latest updates, you can try the GUI app: https://docs.puri.sm/Software/PureOS/cfg/sw-management.html#upgrade-to-a-newer-pureos-release
Just keep in mind that the app is pretty strict about foreign packages.
You can manually upgrade and replace byzantium with crimson in the /etc/apt/sources.list file here as well.
Note that byzantium itself is also end-of-life (as of end of August this year). So if something goes wrong with the two upgrades, support may be harder to come by.
And I would still recommend a full disk image before starting, regardless of whether doing two in-place upgrades or doing a fresh install.
Also, any device that old shouldn’t be on the internet. Seriously. There have been far too many serious security flaws patched. A clean download of crimson on a more up-to-date computer may be safer. That depends on your threat model / tolerance for risk of course.
Finally, something really old may have problems with expired certificates or even expired crypto algorithms.
It just isn’t a good idea to leave something that long without updates … but I guess the OP already knows that.
“Recommend” is an understatement - upgrading by jumping across multiple suites is explicitly unsupported, in both Debian and PureOS. You need to upgrade amber to byzantium first before upgrading to crimson.
Excellent, thank you all for the advice. I will be doing a full refresh. I appreciate it.
