Guix has packaged the Debian kernel. Guix documentation still says that “currently only the Linux-libre kernel is fully supported”. I do not see aarch64 support yet, for example. Has anyone tried on an x86_64 Librem device? It should be as easy as adding (kernel linux-debian) to the operating system declaration. And if it doesn’t work, you just roll back, as usual.
If it works, then Purism’s documentation on Guix System should be updated. For example, it probably shouldn’t recommend users “compiling a custom kernel or installing one from another distribution”.
