Hardware Switches Librem 5
#1
Hello. I wonder what things can be turned off with a hardware switch on the Librem 5 and then will they be turned off so that software definitely can’t turn it on and that no radiation comes out from the turned off part because it isn’t used? Can you tell me which things that much be turned off at the same time? I think I heard that wifi and bluetooth will be disabled at the same time but that won’t be a problem for me I think right now at least. What’s the other things that can be turned off completely to reduce radiation and increase privacy and are there other pairs that will be disabled together?
#2
Hardware Kill Switches for Camera, Microphone, WiFi/Bluetooth, and Baseband
https://puri.sm/shop/librem-5/
