Hibernation with Librem 13v3
#1
Is there a way for me to get hibernation working on my Librem 13v3 without having to reinstall PureOS? Right now I have no option to enable it.
#2
It’s become a bit complex with systemd;
https://www.freedesktop.org/software/systemd/man/systemd-sleep.conf.html
But the easier way is to go to settings;
  • Go to settings
  • Choose Power
  • At the bottom, choose for the value Hibernate for the When the Power Button is pressed
Now you can just click the power button to suspend.
#3
Many thanks. For some reason, prior to just checking, there was never a hibernate option availible. After just looking there was an option for it.
I really like how closing the lid puts the librem to sleep, and you can quickly get started again later. However, sometimes when I’m not going to use the laptop for a while, I prefer not wearing the battery done for nothing.
Thanks for the response!
#4
Glad I saw this.
So now I have it going to hybrid suspend when I close the cover (so that if the battery runs out while it’s shut, I don’t lose my session) and hibernate when I hit the power key (which I’ll do if I know it will be a while.
#5
How did you change the lid closing behavior? I looked around but didn’t see that.
Also I installed a gnome extension to add a hibernation button on the power selection, and it appeared to work, however, when I turned it back on, it started up as if from a cold boot. (IE: My session was gone.)
Does having your hdd encrypted mess up hibernation?
#6
There was a topic regarding hibernation quite a while ago. What i directly can remember:
  • swap-partition has to be big enough to accept the whole RAM-size + x (otherwise the hibernation-box ticked doesn’t do anything)
  • real hibernation didn’t work for me - just sleep
  • if the akku is going towards zero, the laptop doesn’t fall into hibernation, but switches off - so cold boot next time
Found it: Have a look https://forums.puri.sm/t/hibernation-hibernate-on-librem/3432/14
The last message might be a solution. Didn’t find the time to try myself (respectably i’m not confident enough with linux-internals to risk shooting my right now mostly stable system :wink: ).
