I manged to try on Bookworm. I now wonder if all these distros are too new with some Python package. But I’m guessing.
user@debian:~/librem5-flash-image$ ./scripts/librem5-flash-image --stable
2024-10-28 22:44:54 INFO Looking for librem5r4 luks byzantium image
2024-10-28 22:44:55 INFO Found disk image Build “stable” ‘Last stable librem5r4 build’ from Fri Jun 23 22:21:40 2023
File “/usr/lib/python3/dist-packages/jenkins/init.py”, line 462, in get_job_info
response = self.jenkins_open(requests.Request(
File “/usr/lib/python3/dist-packages/jenkins/init.py”, line 564, in jenkins_open
return self.jenkins_request(req, add_crumb, resolve_auth).text
File “/usr/lib/python3/dist-packages/jenkins/init.py”, line 580, in jenkins_request
self.maybe_add_crumb(req)
File “/usr/lib/python3/dist-packages/jenkins/init.py”, line 369, in maybe_add_crumb
File “/usr/lib/python3/dist-packages/jenkins/init.py”, line 583, in jenkins_request
self._request(req))
File “/usr/lib/python3/dist-packages/jenkins/init.py”, line 557, in _request
return self._session.send(r, **_settings)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 664, in send
timeout = TimeoutSauce(connect=timeout, read=timeout)
File “/usr/lib/python3/dist-packages/urllib3/util/timeout.py”, line 119, in init
self._connect = self._validate_timeout(connect, “connect”)
File “/usr/lib/python3/dist-packages/urllib3/util/timeout.py”, line 156, in _validate_timeout
raise ValueError(
ValueError: Timeout value connect was <object object at 0x7f6b449784c0>, but it must be an int, float or None.
During handling of the above exception, another exception occurred:
File “/home/user/librem5-flash-image/./scripts/librem5-flash-image”, line 538, in
sys.exit(main())
File “/home/user/librem5-flash-image/./scripts/librem5-flash-image”, line 478, in main
uboot_ref = find_uboot(UBOOT_JOB_NAME.format(uboot_board))
File “/home/user/librem5-flash-image/./scripts/librem5-flash-image”, line 282, in find_uboot
info = server.get_job_info(jobname)
File “/usr/lib/python3/dist-packages/jenkins/init.py”, line 475, in get_job_info
raise JenkinsException(
jenkins.JenkinsException: Could not parse JSON info for job[u-boot_builds/uboot_librem5_build]
