Information needs to be corrected on Posts, Products, and Shop pages
OK, so I think that what is happening here is that
a) Purism is not specifying a language at all on that page, and
b) you have enabled automatic translation in Google Chrome (on by default?).
The recommended fix for the first one (@Kyle_Rankin) is as outlined here: https://stackoverflow.com/questions/2467454/why-does-chrome-incorrectly-determine-page-is-in-a-different-language-and-offer
however I would disagree on principle with the idea of putting in
<meta name="google" content="notranslate">
as some crappy proprietary Google metadata. (The other suggestions are reasonable.)
The recommended fix for the second one (@Sharon) is as outlined here: https://www.howtogeek.com/407924/how-to-turn-translation-on-or-off-in-chrome/
but better would be "Don’t use Google Chrome at all ! "
and if you do choose to use Google Chrome then first check that you have specified a reasonable default language (in your case presumably Canadian English or Canadian French or both), which is also covered by the config mentioned in the howtogeek article.
Thank you very much for this detailed answer.
I hadn’t considered that it was an endless cat and mouse game, but your response definitely helped me understand the problem. I’m happy that the google stuff is easy to block, and I can safely make my purchases on the Purism shop without any google connections.
I wish more online shops were as good as the Purism shop.
Nope. Not my end. I said before, I will search best I can before jumping down any rabbit hole.
Business has to play with business - whether we like it or not.
Funny you provided the link to howtrogeek. I already read the same thing before mentioning it here.
Summary: It’s not the end user. It didn’t bother me, seeing other errors in typos and grammar, and simply obsolete stuff, or following a link I was handed, was a 404.
I just thought someone new might look at whole and think ā€˜Hmm, not good housekeepers’.
It’s your house.
~f
