L5 Items that still need to be polished mentioned in various other blogs Oct 2023
The one thing I wish the L5 supported was international calling, when I use the same sim card in an iphone I can place international calls, when I put it in the L5 no international calls are possible, that makes it very challenging when your family or some of your family lives abroad. I wish there was more urgency on this.
That is weird. I can make an international phone call without any problem (tested within the EU).
I get the sense that all of us experience different issues; some of us are lucky and experience none.
And that is concerning. It means that today I’m lucky but have no guarantee for the future.
How are things with the sim card tray not coming out of the phone. Is there a solution yet? I gave up trying because I do not want to damage anything.
You can eject the SIM card tray using the removal tool, or potentially a toothpick. Just ensure your device is turned off before you perform the procedure so that your SIM card does not get short-circuited/fried during the process.
I also had this problem and I was afraid I’d break something by just applying force. Support told me to wiggle the tray, something I so far hadn’t had any success with. But since that was the official solution, I decided to try again and this time for real.
My SIM was stuck in a position where I could not grab the tray itself, only the outer black part that has some play. Therefore I made myself a simple tool by slitting a piece of stiff plastic, so that I could reach behind the outer part.
Then I used the tool to wiggle the tray while alternating between mostly pulling and sometimes pushing. It took a while, but eventually the tray did come out.
Finally, before inserting the tray again, I rounded off the back side edges of the SIM card (my thinking being that maybe they were catching on something). My tray now easily slides in and out, as it should.
Edit: My SIM was delivered as a bigger card with smaller form factors pre-cut. It could be that it was too thick even though I got the correct outline of a nano SIM. These are 0.1 mm thinner than other SIMs.
Good going!
I also managed to solve this one.
A while back I picked up one of these old school feeler gauges that are used to measure tiny gaps between objects, for instance when tuning a car’s ignition. (For fifty cents at the thrift store.)
After unlocking the tray with the pointy tool that came with the L5, I inserted the thinnest but one blade in the slot on the side where the sim card sits in the tray (toward the back of the phone). That way, the sim card does not get stuck behind the inner workings of the phone. Had the tray out within seconds.
So let’s hope that Purism supplies feeler gauges with their phones now…lol.
The blade that does the job is something like 0.1mm ‘thick’. Can easily be included it in the box, or mailed in a regular envelope.
I would want the full set so I can set the gap on the sparkplugs on my chainsaws…
