Librem 13 v4 - PureOS - Wifi disconnects
#1
Hi,
I’ve been having issues with my laptop regularly losing Wi-Fi connectivity over past few weeks. I’m not too sure how best to begin investigating this issue. I found a previous post on the forum that was similar to my issue, but not the same(sorry, I can’t find it right now). There was a recommendation to grep the syslog for the device name and provide the output. Below is a sample output from doing so.
Is anyone able to provide some guidance, please? It seems to be something to do with WPA supplicant. Net searches seem to keep referring to a “wpa_supplicant.conf” file, which doesn’t exist on my system. I have VMware Workstation installed which will be the references to virtual networks in the log output below. I’m pretty sure the WiFi issues started before I installed Workstation.
Oct 4 21:52:42 librem NetworkManager[1522]: [1570222362.2222] device (wlp1s0): state change: ip-config -> ip-check (reason ‘none’, sys-iface-state: ‘managed’)
Oct 4 21:52:42 librem avahi-daemon[1498]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.0.91.
Oct 4 21:52:42 librem avahi-daemon[1498]: New relevant interface wlp1s0.IPv4 for mDNS.
Oct 4 21:52:42 librem NetworkManager[1522]: [1570222362.2233] device (wlp1s0): state change: ip-check -> secondaries (reason ‘none’, sys-iface-state: ‘managed’)
Oct 4 21:52:42 librem avahi-daemon[1498]: Registering new address record for 192.168.0.91 on wlp1s0.IPv4.
Oct 4 21:52:42 librem NetworkManager[1522]: [1570222362.2235] device (wlp1s0): state change: secondaries -> activated (reason ‘none’, sys-iface-state: ‘managed’)
Oct 4 21:52:42 librem NetworkManager[1522]: [1570222362.2340] policy: set ‘Homenet’ (wlp1s0) as default for IPv4 routing and DNS
Oct 4 21:52:42 librem NetworkManager[1522]: [1570222362.2395] device (wlp1s0): Activation: successful, device activated.
Oct 4 21:52:42 librem nm-dispatcher: req:1 ‘up’ [wlp1s0]: new request (2 scripts)
Oct 4 21:52:42 librem nm-dispatcher: req:1 ‘up’ [wlp1s0]: start running ordered scripts…
Oct 4 21:52:42 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=-84 txrate=39000
Oct 4 21:52:44 librem ntpd[1613]: Listen normally on 31 wlp1s0 192.168.0.91:123
Oct 4 21:52:44 librem ntpd[1613]: unable to create socket on wlp1s0 (32) for fe80::1baf:bd46:141a:8927%2#123
Oct 4 21:52:46 librem ntpd[1613]: Listen normally on 33 wlp1s0 [fe80::1baf:bd46:141a:8927%2]:123
Oct 4 21:58:18 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 21:59:23 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 21:59:43 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 21:59:56 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:00:10 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:00:11 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:01:24 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:08:57 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:08:59 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:09:24 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:09:30 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:09:53 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:09:56 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:10:06 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:10:10 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:10:12 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS
Oct 4 22:10:13 librem vmnetBridge: RTM_NEWLINK: name:wlp1s0 index:2 flags:0x00001003
Oct 4 22:10:13 librem vmnetBridge: Removing interface wlp1s0 index:2
Oct 4 22:10:13 librem vmnetBridge: Stopped bridge wlp1s0 to virtual network 0.
Oct 4 22:10:13 librem wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Oct 4 22:10:15 librem ntpd[1613]: Deleting interface #31 wlp1s0, 192.168.0.91#123, interface stats: received=25, sent=48, dropped=0, active_time=1051 secs
Oct 4 22:10:15 librem ntpd[1613]: Deleting interface #33 wlp1s0, fe80::1baf:bd46:141a:8927%2#123, interface stats: received=0, sent=0, dropped=0, active_time=1049 secs
#2
Are you using PureOS or some other GNU/Linux?
#3
I’m running PureOS on a Librem 13v4. I mistakenly put librem 15 in the title.
#4
Since removing a couple of virtual networks created during the VMware Workstation installation I’ve not had any network issues. Although I’ve not done a lot of testing.
I have noticed that I’m no longer seeing any “wpa_supplicant[1507]: wlp1s0: CTRL-EVENT-BEACON-LOSS” entries in my syslog, which I take to be a good thing.
