Earbuds work fine on android phone. Software appears to be up to date. The message under setting is No Bluetooth Found. The slider will not engage. Is this a software issue?
Kill switch?
The switch is working for WiFi and bluetooth. The kill switch for camera and mic is off.
that did not sound right. I have not used the kill switch to disable WiFi and Bluetooth but I have used it to disable the camera and mic.
Also in the terminal I typed sudo apt update in case there was a driver issue.
Then I would make two suggestions:
- Examine journalling / logging for relevant messages.
- Use the kill switch to switch off and then on again.
In fact, sometimes it is an idea to switch off with kill switch, shutdown, then reboot with kill switch still off, wait 10 minutes so that the burst of logging messages from the boot is well in the past, then use the kill switch to switch on, and examine recent logging messages if the Bluetooth doesn’t appear.
I’ll give the shut down using the kill switch a shot and boot up tomorrow.
Check the status of the Bluetooth systemd service. It might not be active.
systemctl status bluetooth
Byzantium has reached EOL and is no longer receiving updates.
Should I try
sudo apt install pureos-standard
The jump to PureOS 11 is a major upgrade, and Bluetooth on the Librem 15v4 has a history of regressing across versions, so the pop-up install likely isn’t a clean fix on its own. Running the plain pureos-standard metapackage could pull in firmware that isn’t currently installed, which might restore the adapter, but confirm the radio isn’t just soft-blocked first. Before layering more packages, check whether the update left the previous kernel in place and whether the Bluetooth service is actually starting at boot.
You have a typo in the systemctl command: you forgot the ‘e’ in bluetooth.
