Yesterday I tested up-time by turning off WiFi, setting to 4G, and leaving the phone on the table all day. It took 7 hours to drain from 100% to 20%, with just an occasional peek to check the charge status, doing nothing else.
But I think at one point, it lost the network and was maybe scanning for it for a couple of hours, which could have affected the power usage.
Would you mind to repeat your test? Scanning for network for a couple of hours means your test result is useless. Every phones battery would be drained down in few hours in such a case. But I also trust more in your words about L5 than random people on YT.
I’m using it as Daily Driver, I can guarantee that it doesn’t last more than 9 hours, no matter how light is the usage. In fact a positive note about L5 is that the usage (in terms of phone calls) doesn’t affect dramatically the up time (much less than my old Android, that took advantage of the suspend functionality).
So you need to use them. Cycle them through. (Each battery has a unique serial number so you have the option of various levels of rigour regarding battery health and maintenance.)
If you are going to use a second battery in order to double your time on battery each day then that won’t be a problem.
That’s putting a positive spin on it.
That is hopefully a temporary situation.
Are you saying that the mobile network is unreliable where you are?
I think it is even more complicated than that. You are assuming that the state of the modem with respect to the mobile network makes any difference to its power consumption. I’m certainly not across what sleep modes the BM818 has and what the power consumption is in each mode and whether the sleep modes are being used at all and what conditions affect what sleep modes are possible.
That’s a lot of unknowns.
As a blackbox modem, it is difficult to know what exact factors will influence power consumption. If you had a dedicated test rig, you could presumably measure it even though the modem is a blackbox.
Fairly obviously the modem is drawing enough power 24x7 to listen for transmissions from the tower.
I think you would have to be a 3GPP guru even to start to know what the expectations should be.
Anything in a log file to correlate with that? I ask because then I could scan my logs to see whether I am seeing that too. I have never noticed such a problem but that doesn’t mean absolutely that it is not happening.
I haven’t looked for any logs yet, but I know it’s happening when I find I’m unable to make or receive a call, at which point I take a look at the Mobile settings and discover the name of my carrier is no longer present. Re-selecting and setting the carrier again brings it back. Sometimes the “4G” is still present at the top of the screen.
I’m not sure what conditions trigger the behavior. I’m not too concerned yet, since it’s not my main phone.
Perhaps a better title would be L5 Daily Driver dream
L5 is a device for very serious use. Do not touch it without a serious reason, otherwise you will get the message “Battery Aziz!” (no more battery) at a crucial moment
Let’s see: approximately 10% of the battery every hour in “do not touch me” mode without activating deep sleep - suspend mode. Ah…
My job is customer contact and the L5 still can’t get through my workday without me having to think about where my charger is."
Suspend device is in experimental and manual mode, subjectively it seems to me that it does its job, but I often forget to activate that option.
On the street where there is more noise, I can often barely hear the interlocutor.
The sound is relatively clear but not strong enough.
ok, there will be more upgrades and progress.
The fact that there is a GNU/Linux phone next to me at work and that it works solidly (could and must be better) makes me happy enough. A completely different eco system in a pocket edition as independent as possible, decentralized as possible. The device that changes the definition of a smartphone. IT is smart as far as I know, not as much as “they will”
There has been progress since the creation of this post from 2+ years ago
