Why does my command uuu -lsusb not work? Wrong version of uuu ?
florian@Laptop2022:~$ uuu -lsusb
uuu (Universal Update Utility) for nxp imx chips – libpureos/1.2.91+0git6b465-0pureos+librem5.2-1-g5e5fee8
Unknown option: -lsusb
uuu [-d -m -v -V] <bootloader|cmdlists|cmd>
bootloader download bootloader to board by usb
cmdlist run all commands in cmdlist file
If it is path, search uuu.auto in dir
If it is zip, search uuu.auto in zip
cmd Run one command, use -H see detail
example: SDPS: boot -f flash.bin
-d Daemon mode, wait for forever.
-v -V verbose mode, -V enable libusb error\warning info
-m USBPATH Only monitor these paths.
-m 1:2 -m 1:3
uuu -s Enter shell mode. uuu.inputlog record all input commands
you can use “uuu uuu.inputlog” next time to run all commands
uuu -udev linux: show udev rule to avoid sudo each time
uuu -h -H show help, -H means detail helps
uuu [-d -m -v] -b[run] <emmc|emmc_all|fat_write|qspi|sd|sd_all|spl> arg…
Run Built-in scripts
emmc burn boot loader to eMMC boot partition
arg0: _flash.bin bootloader
arg1: _image[Optional] image burn to emmc, default is the same as bootloader
emmc_all burn whole image to eMMC
arg0: _flash.bin
arg1: _rootfs.sdcard
fat_write update one file in fat partition, require uboot fastboot running in board
arg0: _image image, which cp to fat partition
arg1: _device storage device, mmc\sata
arg2: _partition
arg3: _filename[Optional] file name in target fat partition, only support rootdir now
qspi burn boot loader to qspi nor flash
arg0: _flexspi.bin bootloader
arg1: _image[Optional] image burn to flexspi, default is the same as bootloader
sd burn boot loader to sd card
arg0: _flash.bin
sd_all burn whole image to sd card
arg0: _flash.bin
spl boot spl and uboot
arg0: _flash.bin
uuu -bshow <emmc|emmc_all|fat_write|qspi|sd|sd_all|spl>
Show built-in script
Enjoy auto [tab] command complete by put below script into /etc/bash_completion.d/uuu
_uuu_autocomplete()
COMPREPLY=($(/usr/local/bin/uuu $1 $2 $3))
complete -o nospace -F _uuu_autocomplete uuu
