Librem 5 GPS/Location Tracking
I’m well aware that this is a case under warranty and that it is perhaps a fault in some (or many) devices. Even that’s why I think any technical experiment will help Purism to understand the nature of the problem and that’s why they should read this thread, perhaps skipping over the rants and simple complaints.
from the mails i got back from purism i learned that they dont follow this thread thorrowly.
and: i dont rant, i am interested to solve the problem and i investigated alot of time into it.
+1
me too
Next experiment will be to locate the L5 10cm above a metallic surface of ~1x1meter, with display up. It’s only to cold today outside :slight_smile:
Also I and another L5 owner have been doing quite extensive GPS testing. Many tests based on information of this thread. I did not want to contact Purism support yet, because I do not want to increase their load. Information and tips from Purism in this forum board will be highly appreciated, and probably also decrease the number of support requests. I encounter quite similar issues as described here, but lately I got good fixes. I hope to do some more testing soon.
I propose to assemble here a small table of the affected users and devices. Maybe the device number even leads to some conclusion about a “serie”. You find the serial number below the battery (the list is sorted by the serial number now):
user        | serial no.  | fix at all (y/n) | comments
janvlug     | L521313269  | yes              | L5 has to be put on metal (oven) plate
mdt         | L521313286  | no               | never
guru        | L521313541  | yes              | fix only with display down
guru        | L521313983  | no               | -
nico202     | L5xxxxxxxx  | yes              | now does not get a fix anymore
All, just send me a msg with your data and I’m happy to fill it in.
i just found
The GNSS module is unable to reliably receive broadcasts from satellites, making it difficult to fix the location of the phone. This problem will be addressed in later revisions of the hardware, from Dogwood onwards.
in https://docs.puri.sm/Librem_5/Known_Issues/Chestnut.html - no hint about the exact problem.
I covered the table (70x95cm) with aluminum folio (see photo) and the results are:
display up (after 30 minutes):
fix            None
View sats
S13:20.0 S24:19.0 S15:22.0 S05:10.0 S23:14.0 S10:18.0 S14:17.0 S66:19.0
Solution sats
timestamp      2021-12-11 14:15:28.17
Fix time       1639228528.000
TTFF           0.0
display down:
fix            3D
View sats
S23:26.0 S15:29.0 S13:24.0 S24:27.0 S10:29.0 S14:23.0
Solution sats
timestamp      2021-12-11 14:19:54.35
Fix time       1639228794.000
TTFF           145.4
rotating the device to display up again does not loose the fix
Thank you. Are you able to tell how much of a difference the presence of the aluminum foil made, when comparing your current test results with the test results you posted 3 days ago (the L5 face-down test without the foil)? The time-to-first-fix 3 days ago was 68 seconds without the foil but 145.4 seconds with the foil. Can we infer that the foil was actually a hindrance to fixing?
Better compare it with the tests in posting #105 in this tread:
  1. without the folio and display down it gets a fix in less than 10 secs; with display up it does not see any satellite
  2. with the folio and display down it gets a fix after some 145 secs; with display up it sees at least some satellites and almost got a fix;
Any experts here to explain this?
The antenna amplifying effect works (but not much). Actually the distance between antenna and reflector is very critical with Ghz frequencies. A few mm more or less can make a big difference.
Due to the results as reported:
  • GPS module works
  • Antenna not effective (loose or bad connection to GPS module)
  • Antenna (partly) obscured (this gives even less signal, but should not be a problem with a well connected antenna)
Here my test results: My L5 has difficulties finding a GPS fix.
But in this setup it can easily get a fix (at the moment within ~ 15 seconds): The L5 is screen down in a this plastic container, I put this container on the metal baking plate of my oven. The metal plate with the plastic container is on top of a table which also has a stair on it, so that it is relative high on my terrace outside. The weather conditions are: a constant drizzle, so the plastic container and the baking plate from the oven are wet. The sky is completely covered with a light drizzle cloud layer.
When the oven baking plate is not there, I will not get a fix, when the oven plate is there, the L5 will get a fix.
I use these two commands to follow the progress of the fix via ssh, warm and dry from the inside of my house:
NOTE: running multiple socat commands in parallel on the unix-client:/var/run/gnss_share.sock seems to break things, so do NOT do that!
First I do:
sudo socat unix-client:/var/run/gnss_share.sock - | grep -aE --line-buffered '^\$G[P,L]GSV,.*'
This command shows all GPGSV and GLGSV sentences. From these sentences I can see if there are any satellites that have a signal/noise (s/n) value.
This is a typical example of these lines without s/n values (recognizable as the ,, values)
$GPGSV,3,1,11,13,77,298,,14,52,119,,05,49,215,,30,47,068,*71
$GPGSV,3,2,11,15,45,293,,20,25,190,,07,18,065,,18,16,299,*79
$GPGSV,3,3,11,23,10,325,,08,10,029,,24,06,248,,,,,*41
$GLGSV,3,1,09,76,75,065,,66,66,139,,67,56,316,,77,46,208,*6B
$GLGSV,3,2,09,75,20,038,,84,13,005,,83,09,309,,68,06,318,*67
$GLGSV,3,3,09,65,06,139,,,,,,,,,,,,,*52
With the oven baking plate under the plastic container, these lines change into lines that do contain an s/n value, like this:
$GPGSV,3,1,11,13,79,299,27,14,53,116,28,15,48,293,,05,48,213,*76
$GPGSV,3,2,11,30,45,068,28,20,23,189,,07,16,066,,18,15,297,*7C
$GPGSV,3,3,11,23,11,324,,08,09,027,,24,07,249,,,,,*47
$GLGSV,2,1,08,76,73,059,,66,63,141,,67,58,316,,77,49,209,*68
$GLGSV,2,2,08,75,18,039,,84,13,003,,68,08,319,,83,08,307,*6B
When I have lines with s/n values, I stop the command with CTRL-C and run:
sudo socat unix-client:/var/run/gnss_share.sock - | grep -aE --line-buffered '^\$GNGSA,[DANE],[1-3],[0-9]{2}'
This will then result in lines like:
$GNGSA,A,1,14,,,,,,,,,,,,99.0,99.0,99.0*1B
$GNGSA,A,1,14,30,,,,,,,,,,,99.0,99.0,99.0*18
$GNGSA,A,2,13,14,30,,,,,,,,,,4.3,4.1,1.0*2A
$GNGSA,A,2,13,14,30,,,,,,,,,,99.0,99.0,99.0*19
$GNGSA,A,3,13,14,15,30,,,,,,,,,9.2,5.6,7.4*27
The 3 in the above line indicates a 3D fix.
For details regarding the NMEA sentences, see this page.
Kudos to a close by other L5 owner who helped me with the commands and testing!
Do you get a fix in this assemble with display upside?
No, I explicitly tried that.
Just for a check (it solves nothing). Can you try with L5 upside, but with ~10cm distance from the baking plate as in this image
To verify if you get similar results as @guru
My assumption is that the antenna is not well connected and that the GPS module is receiving just by itself (which tells me that it’s a good quality module). A little bit extra ‘internal antenna’ amplification by a reflective surface on the right distance could than just be enough.
If I received my L5 (still waiting :cry:) I would try to fix the antenna connection (if reachable).
@Jan2 Could you clarify what we are to understand from the images?
Is the idea that the solid line from e.g. S1 to L5 via the metal plate can (with luck) be very close to an integral number of wavelengths longer than the dashed line? Then, the signal strength can effectively be doubled for that particular satellite?
In that case, to get the best result, the metal surface (baking plate or whatever) should be as large as possible, and the L5 should be placed at least one wavelength (about 20 centimeters?) above the metal surface?
If the metal surface was infinitely large then it would not matter if the L5 was placed significantly higher, like several wavelengths above it, but given that the metal plate is of limited size it is probably best to place the L5 at about one wavelength above the metal, since moving it higher means satellites closer to the horizon cannot benefit from the metal surface?
A possible improvement could be to put a few (many!) more baking plates around the center one, effectively creating a larger metal surface?
Perhaps also put some of the plates at a slight angle as above, making it possible to get 3x signal strength for some very lucky satellite? :slight_smile:
Will we have to bring the entire contents of our kitchen along with us when we are navigating? lol.
Antenna design for mobile GPS is much more complex than the space available in this forum allows for explanation (and I don’t regard myself as an expert in this field). The antenna used in the GPS module is most probably a Planar Inverted-F antenna (PIFA), although other variations are possible.
What I tried to explain was the effect of a bad antenna connection. The differences between the receiving path, direct - indirect, is exaggerated and partly misleading ..
For reflection of the back plane or earth it’s best to assume that both direct and indirect path are passing through the antenna. The next picture explains the amplifying effect of reflector at 1/2 wavelength.
The dotted line is the reflected wave, arriving at the antenna in the same phase as the direct signal. As such the reflector improves the GPS signal, hopefully just enough to increase signal/noise ratio above the threshold level.
To answer your question: the reflector is best placed on an integral number of half wavelengths.
The use of many baking plates leads ultimo to a parabolic reflector. It’s best to put the L5 in the focus-point :laughing:
What I understand from this and other explanations in this tread and from own experiments, it seems to me that in the L5 something around the GNSS chip/antenna/earthing is bad or let’s say not optimal constructed, i.e. it is a hardware issue. While any software issue can relatively easy be fixed by installing an updated version, how Purism could address such a hardware issue?
And, why they didn’t detected this before in own tests, or in the versions before Evergreen?
I tested this. The L5 can get a fix in this configuration. But also when the with the screen down 10 cm above the baking plate.
It is quite difficult to exactly determine how all factors influence each other, but I think that the following statements are true:
  • Screen down works better than screen up;
  • With metal oven baking plate is better than without it;
  • 10 cm above metal oven baking plate is better than directly on top of it.
It seems that the best results are obtained by having the L5 screen down, 10 cm above the metal over baking place (and outside, obviously).
When I have the seemingly optimal configuration inside at the top level of my house, some satellites do show a s/n value, but I did not get a 3D fix.
Also note: when the L5 has a 3D fix, which I monitor with this line:
It looks like it can hold the fix when putting the L5 in less optimal positions. When I then stop the command with CTRL-C, but keep the phone in the less optimal position, the L5 cannot establish a 3D fix again. So, I think that somehow the L5 can sometimes maintain a 3D fix in a location where it cannot freshly establish a 3D fix.
Are there any L5 owners that can always easily get and maintain a 3D fix when outside, without applying special configurations?
Mine seems to get decent SNR values quickly and easily - and gets a fix.
I don’t know whether it’s a 3D fix. Would have to study the message spec.
I’m not using any special software. Just grep -a xxx /dev/gnss0
