Librem 5 MMS Australia
Thanks for this info @nscomputing, Everything appears to be working!
Thanks @stookie, everything appears to work as within a minute of entering the info you and @nscomputing gave me, I received notification of a few mms messages a friend sent last week, which came up as expired though. (on '1970-01-01 09:59).
Do you happen to know if I need to do anything to change the date (my phone time and date settings are correct for AEST though)?
Referencing your step 4, when I’m at home I only use wifi on my L5, and so far, when I’ve been out I’ve turned off the kill switch for the wlan. So, my plan is to have mms set to on, and when I’m out, only access the mobile internet if I need to.
Thanks again.
That’s just Unix base date/time expressed in Australian Eastern Standard Time (AEST) i.e. a time value of 0 - but offset by 10 hours for the timezone difference between GMT and AEST.
Why it is then out by 1 minute is a mystery. So it is really a time value of -60 (seconds).
What that means in terms of MMS and expiry I don’t know.
Probably get your friend to send another MMS now that things are working on your end.
Hi Nico1
When I got MMS working on my Librem 5 I also got a lot of expired MMS messages
But now MMS is working fine for sending and receiving.
to set date time and syncing I used following commands, I have UBUNTU on my PC
But the commands also worked on the phone
To set the time to your specifications, use the following command:
Display Current Date and Time with timedatectl
In Terminal
To display the current time and date information, use the command:
timedatectl
Sync Time to NIST Atomic Clock
Set the Ubuntu system to synchronize to the NIST atomic clock with the following command:
sudo timedatectl set-ntp yes
How to Change the Date
Use the same command to define the date on the system:
sudo timedatectl set-time 2019-04-10
sudo timedatectl set-time 21:45:53
Hi
i would like to update the Purism Community Wiki on the settings to config the MMS for Librem 5 for Australia Telechoice and OPTUS sims.
Any thoughts if this is a good idea, or not. Is there a better place for this?
However even though I tried to register many times for the wiki I never get a confirmation email.
So I cannot do the update even if I wanted to.
Frank
@amosbatto
Yes, good idea. I suggest adding a column to: Cellular Providers · Wiki · Librem5 / Librem 5 Community Wiki · GitLab
Yes, upstream - so that Linux just works out of the box for that carrier.
Hi @frank, Post the changes here that you want to add, and I (or somebody else) will add them to the community wiki.
PS: Who we can pester at Purism, so that new people can be added to edit the community wiki?
I would ask @joao.azevedo
Also, welcome back.
Thanks Amos
Location Provider Bands provided Modem Calls VoLTE SMS Data† MMS Notes Sources
Australia Telechoice LTE1800 (B3) 2600 (B7) 900 (B8) 700 (B28) BM818-T1 Yes ??? Yes Yes CHATS/Preferences/ SMS and MMS Settings SMIL for MMS ON CHATS/Preferences/ SMS and MMS Settings MMSC: http://mmsc.mdata.net.au:8003 APN: telstra.internet Proxy: 10.1.1.180 Settings/Mobile/Mobile Data ON Settings/Mobile/Access Point Names +(add new APN) Name: Telstra(next G) APN: telstra.internet (leave others blank) SIM activated only on a large display using a dock frankkolmann
Australia OPTUS LTE2100 (B1)1800 (B3) 2600 (B7) 900 (B8) 700 (B28) 2300(B40) BM818-T1 Yes ??? Yes Yes CHATS/Preferences/ SMS and MMS Settings MMSC: http://mmsc.optus.com.au:8002/ APN: mms Proxy: 61.88.190.10:8070 Settings/Mobile/Moile Data ON Settings/Mobile/Access Point Names +(add new APN) Name: Optus MMS APN: mms (leave others blank) SIM activated only on a large display using a dock frankkolmann
Hi Amos. I had a thought. Perhaps you can apply to be a Wiki Administrator.
I added the two entries in the Cellular providers table. There isn’t room to add more columns, so I added the MMS info under the “Notes” column.
If Purism gives you access to the community wiki, you can edit anything so effectively you become a wiki administrator. :slight_smile: I’m guessing that Purism got so much spam, so they don’t want to add new people.
Looks good. Thank you Amos.
