Librem 5 record uptime
Well you power it down and then turn it back on
Sure, that is a normal part of my workflow:
Yes but if you run the command uptime it be ‘always’, it will be from when you last reflashed, which in the spirit of OP would be when most people reboot. (ie. from a bug or problem that requires rebooting or reflashing)
Well right now my Librem 5 USA is turned off with all of the hardware kill switches toggled downwards, while I am currently using my Librem 14 for more productive tasks. Later on this evening, I will probably turn the Librem 5 USA on with the Wi-Fi hardware kill switch toggled upwards, use Shortwave to connect to a Internet radio station, and play some music in the background to stay productively focused.
So then this statement is incorrect
The statement is still valid since I never restart the phone and it is fully functional.
Powering it down and then powering it back up is restarting!
From my perspective, they are not equivalent operations.
Restart has two meanings:
  1. The “operation”, where PC shuts down and automatically starts again.
  2. The generell process where the PC switches the state from on to off to on again, while it can take multiple steps and does not need to be instantly (like shutting down, waiting a day, starting again).
When we speak about uptime, it’s clear that everyone understand “restart” as something about definition 2. Who cares if you restart it as one operation or if you shut it down, go sleep, start next day again? The uptime was interrupted and the purpose for that is (mostly) irrelevant. You’re maybe technical right about “I’m not restarting”, but that is misleading in context of this thread.
I care about every operation I ultimately end up deciding for myself.
And that is good, but in the context of this thread you restart your phone.
But the phone (OS) is not up the entire time, so “Always” is a false response.
It is not fully functional during the flashing.
I think the intended (and actual) meaning of the first post is quite clear.
And here I thought micrsoft’s attempt to redefine uptime fraction as (total uptime)/(elapsed time - scheduled down time) would never be beat.
I wasn’t keeping track, and I haven’t put in the time to extract it from system logs, but I feel like there have been times that I got a long uptime on my L5, by doing the following:
  • Use a fleet of batteries and chargers
  • When current L5 battery is low:
    – plug into the Librem 5 charger momentarily
    – rip off the backplate
    – rip out the battery while the L5 is still on
    – put a new battery from a wall charger into the L5 and throw backplate back on
    – put the old L5 battery back on the charger to continue the cycle
  • Never use waydroid
  • Never use suspend, as the above battery cycling renders it largely meaningless
  • Prefer keeping the modem turned off whenever possible, ideally most of all the time
Recently I’ve been having bad uptimes because I was caring less and letting the battery go flat, but when the “fleet of batteries” is up and running like a well-oiled machine, looping these behaviors can keep the L5 running pseudo indefinitely. If I’m going to travel away from the chargers, I can take all the batteries with me after charging them up and leaving the L5 to charge from the wall or something. The end result then is that I travel and can go for a day or two without charging, but with blips in the uptime because on-the-go it’s less likely that I would be able to connect to a wall charger to do a battery swap while the device is still on. (So, instead, at the end of each battery’s lifetime I power off the device, and insert the next battery.)
But I also had an event recently where the L5 froze and had to be hardbooted, which has not happened in a long time it seems like. I don’t know why that happened.
When I type last reboot in command line, I see some entries that are 2 days long and some that are 20000 days long. It seems that the 20000 days long are errors due to the clock resetting, and they make it difficult to determine for how long the device was actually running.
This.
Regardless of all other considerations … issue the uptime command and determine the largest value ever seen.
Obviously reflashing will reset the uptime but so will just applying updates that require a restart (typically kernel updates) and so will certain bugs (hopefully eventually all of those will be fixed) and so will accidentally letting the battery go flat.
purism@pureos:~$ uptime
 17:19:01 up 6 days, 10:04,  2 users,  load average: 0.06, 0.25, 0.30
But I’ve to boot now for the new image which came to /boot right now
Similar issues as others.
  • Bluetooth will not come back, other times both Wi-Fi and Bluetooth (no issues with Wi-Fi not coming back while Bluetooth does); sometimes I’ll toggle the HKS and the software doesn’t recognize it
  • Baseband either doesn’t come back, or cannot connect to data; sometimes I’ll toggle HKS and the software doesn’t recognize it
  • Phosh crashes I assume, as it logs itself out
  • Screen won’t turn on
  • It freezes
  • Sudo anything hangs and can’t complete
  • Battery will be fine at 20-30%, then suddenly it starts going down 1% every couple seconds, sometimes stopping somewhere again, other times continuing until 0% then turning off
  • It will say Chatty is busy with something, when attempting to do anything from the power menu (and will fail if you try, requiring a power button held shut down)
  • Answering a call sometimes get an error when you press the answer button, ending the call before it connects
I would say with all this, it is not reliable enough to be a daily driver yet, as I would not be confident I could be reached in an emergency while driving connected to Bluetooth for example (which combines a few of these issues into one); something a flip phone could do better.
Since I’ve updated to the new kernel some days ago:
purism@pureos:~$ apt info linux-image-6.6.0-1-librem5 2> /dev/null | grep Version
Version: 6.6.83pureos1~byz1
 10:42:34 up 3 days, 17:19,  2 users,  load average: 0.00, 0.05, 0.12
I face no problems at all. @dos It seems even the bug of freezes on USB plug-in/out while the L5 was in suspend has been fixed. At least I don’t face it anymore.
The dream!
I’m on 6.6 as well
We are all on 6.6,*
Are you on 6.6.83?
