Lock-up only at home
OK, so just to confirm … the dates and times in that log file are local times for where you are and you booted at 7:41pm on Saturday evening, left it running, and at 3:57pm on Sunday afternoon (or thereabouts) it locked up?
If that’s right, let’s get back to assessing what state the computer is in when it locks up.
  • can you ping it?
  • can you SSH in?
However you might not normally be able to SSH in anyway. So you would need to confirm that you can SSH in when it is running normally and if not then you need to get SSH going first.
Actually it turns out due to my firewall settings, that I would not have been able to ssh into it anyhow. But don’t you think that by virtue of the fact that the system had completely stopped logging anything that it had hung and would respond to a ping either? I will change my firewall settings next weekend and try again, as well as ping.
The times you noted are exact. I should note that the Reboot entry would have to be for several hours later when I had to forcibly reboot the computer.
