Mobile Data Usage
Blerrrrrccccch. Facebook. (WhatsApp maybe?)
My experience is that turning off mobile data also prevents mms from incoming. Those who receive mms may not want to do this as they don’t tend to control when messages will be sent to them.
Yes this is correct, if you turn off data you will not get any MMS messages.
I have in the past couple days just been toggling the mobile connection off then on after aquiring a new wifi connection to see how that works. I also have tcpdump running in a terminal window that I periodically clear just to see if there is an over abundance of activity on the interface.
It’s worth noting that MMS not being delivered with mobile data off is just a shortcoming of the current implementation and it’s not going to stay this way in the future.
Oh ok…good to know.
That would be a hugely welcome change from my perspective, at least for working around problems like this.
purism@pureos:~$ ifconfig wlan0 ; ifconfig wwan0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.178.49  netmask 255.255.255.0  broadcast 192.168.178.255
        inet6 fe80::2358:a748:95b0:644b  prefixlen 64  scopeid 0x20<link>
        ether 88:da:1a:7c:30:1c  txqueuelen 1000  (Ethernet)
        RX packets 1951705  bytes 533060882 (508.3 MiB)
        RX errors 0  dropped 134983  overruns 0  frame 0
        TX packets 2921828  bytes 3886244020 (3.6 GiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
wwan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.49.90.36  netmask 255.255.255.248  destination 10.49.90.36
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
        RX packets 25972  bytes 16116383 (15.3 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 26446  bytes 2830989 (2.6 MiB)
Just wanted to point out that this bug seems to have been fixed with the kernel update the week of 10/23. Now PureOS switches from mobile network to using WiFi without any fuss. At least that’s what I’ve observed this last week.
Broadband priorities, that is a great idea. I have to find that in the settings.
