This weekend I’ve had time to test the new modem while having the latest kernel installed.
All is OK now (modem part). Sadly the other issue is still not solved. It looks like I have to send it back again. Bummer
Thanks for the update, I’ll have to try it tonight at home to see if I can register on the network now. I did do the update but just haven’t tested it yet.
UPDATE: The kernel update did nothing to solve my problem and support has basically gone silent on me with this. I would have thought they would have put my phone through it’s paces before sending it back to me but it appears not. My sim works fine in my android phone and nothing has changed on our network here since it went in that would affect how it should work. If I don’t get an answer soon I’m just going to sell it.
The fact that almost exactly the same problem happens with the pinephone when using modemmanager makes me wonder if modemmanager has something to do with this issue. I dont recall the same issue happening when using ofono (which plama mobile used to use)… Although ofono had other issues.
Is it just me, or have the modem been much more robust the last few days? I don’t think I have had a single dropout of internet when using suspend, so I am now testing with lowering the value in /usr/lib/udev/rules.d/85-librem5-pm.rules again.
I’ve been turning off autosuspend so I haven’t noticed. Been working fine since doing it.
Nope. Its still happening. Also someone said that patch is for a seperate issue.
Just wanted to give an update. My replacement phone appears to be working normally whereas my old one that was lost had all kinds of problems. I did a 20 minute test call while driving home which was a problem before and it kept the call up. So I have no idea what might have been wrong with my old one. Still can’t do VoLTE though, but I never could before it drops down to HSPA (3G) when in a call.
