Mounting home folders to sd card
Thanks, actually learning a few things here.
all 3 have the same config in the [Unit] section:
[Unit]
Documentation=man:fstab(5) man:systemd-fstab-generator(8)
SourcePath=/etc/fstab
Right. So far after 4 reboots, I have had no issues without x-systemd-requires. Not sure why a few reboots yesterday HAD the problem, which were only fixed after I added that (with a typo, so not really adding it) lol.
Thanks @pajuky.
I just looked into the man page of systemd.mount, and I think I understand now why no dependency relation shows up in the [Unit] section:
If a mount unit is beneath another mount unit in the file system hierarchy, both a requirement dependency and an ordering dependency between both units are created automatically.
In other words, systemd doesn’t mention the dependency in the generated unit file but still takes care of the correct mount order automatically.
Interesting. Then the reason they didn’t mount, the first few attempts to reboot, might have been something entirely unrelated….
Did you in the end solve this issue that your mounting switches from rw to ro?
I have the same issue and I can’t figure out what is going on. My SD card showed no issues so far and was running in the phone before without any problems… Even adding errors=continue does not solve the issue.
Edit:
There is already a bug report
