This seems relevant: https://source.puri.sm/-/snippets/1170.
Yes, you can use the purism ectool, copy it to dom0, and run in dom0. Here are the steps:
# In a domU VM:
# Download the ectool on a VM with internet access and decompress
curl -LO https://source.puri.sm/firmware/releases/-/raw/master/tools/purism_ectool.gz
gzip -d purism_ectool.gz
# In dom0
# Copy the ectool to dom0 (be warned, you will be executing code in dom0.
# Executing any code in dom0 will always pose some level of risk that may
# compromise dom0 and thus all the domU's, so do this step at your own risk).
qvm-run --pass-io <src-vm> 'cat /path/to/purism_ectool' > purism_ectool
# Make executable and check the firmware version. The version number will
# be printed in the dom0 terminal.
chmod +x purism_ectool
sudo ./purism_ectool info
For more info, see these 2 links:
There are also probably better ways to check this without needing to copy an executable to dom0, so if someone knows a better way please share.
