No more WiFi after today OS update
@amarok how does it go? Does it work as expected or not?
Yes, my WiFi is totally normal now, even through multiple reboots and the latest kernel upgrade. No degradation in performance, either.
However, the bluetooth is weird right now. The GUI settings toggle turns it on and off as expected, but it never seems to scan for available devices. I hardly ever use bluetooth for anything, so I’m just waiting until a future update makes it act right.
Thanks. Because I read the issue 264 above and I still hesitate to upgrade. Because it seems they have not yet found the source of the problem. But probably I should do it if I need to connect to wifi on routers that I do not control (at work) because of the 20/40 MHz issue at 2.4GHz.
I’m now on 5.11.0-1-librem5 #1 SMP PREEMPT Wed Mar 17 02:15:51 PDT 2021 aarch64 GNU/Linux and no WiFi issues.
Edit: I just switched over to 5GHz to test and it seems fine, too…connected right away, downloaded some updates, rebooted, still connected. My router’s ranges for 2.4 and 5GHz are both set to automatic.
Bluetooth attempted to use with what kind of device?
I have the same kernel version and my Bluetooth keyboard is still working. Obviously that was paired months ago using a previous software version (and Bluetooth audio output didn’t work previously for me).
Not trying to use any device. Just that when I toggle the GUI button to “on,” the panel area below, that would normally start to list devices within range, doesn’t do anything. (And I know there are devices within range.)
As a data point, not even toggling anything, just going into Settings / Bluetooth lists two devices (both Disconnected, as it happens) and it appears to be scanning for more devices. However both of those have previously been paired and I don’t think I have any other new Bluetooth gadgets lying around to try.
I, too, tested with some previously paired devices, but the lower panel in the GUI still doesn’t appear to be scanning. No biggie for now. I haven’t really been using bluetooth with the L5. I’m sure it’ll come back to life at some point.
And actually, just did another check and my Android doesn’t see my L5, although the tray icon for BT is present (on the L5), and the GUI button is on.
Nice you got a way for wifi @amarok ! I was in touch with support about my non-wifi+bt situation and seems there has been a couple of faulty cards already, they directly asked to send me a different one to test. Still asked about whether the reseating of the wifi+bt module voids the warranty and they told me to go ahead. Was fairly simple, even reconnecting the antennas. Unfortunately still doesn’t work after reseating, seems I’ll have to wait until they send the replacement.
I didn’t have the right screwdriver yesterday, so I went for one and I also got a USB-c dock with ethernet, which for now allows me to at least connect the phone to internet at home.
I hope they find out what’s wrong with it. Mine was apparently the firmware issue, but you apparently already have the right firmware.
@dos something strange to report. I do not know if it makes sense. As long as I was using Ethernet through laptop it could not see existing updates. Today I decided to update and I thought it would be better to have all kill switches on so the updates see all the available hardware. When I turned on the wifi in 3-4 seconds there was a message that important updates are available !!
So I followed the GUI update and restart procedure. The system came up with no wifi adapter found. Terrifying. I flipped the switch off and on and the wifi came back. Rebooted several times, the wifi comes up normally. Shutdown. Start again. wifi does NOT come up. Flipping the switch corrects so far the problem. Here are some details:
uname -r reports
5.11.0-1-librem5
sudo dmesg | grep redpine, starting from shutdown with wifi not found and found after flipping the switch off and on reports:
purism@pureos:~$ sudo dmesg | grep redpine
[ 5.860653] redpine_91x: rsi_probe: ***** 9116 Module *****
[ 5.861913] redpine_91x: redpine_hal_device_init: oper_mode = 13, coex_mode 2
[ 5.869010] redpine_91x: ***** Loaded Firmware *****
[ 9.165975] redpine_91x: ================================================
[ 9.166003] redpine_91x: ================ RSI Version Info ==============
[ 9.166006] redpine_91x: ================================================
[ 9.166010] redpine_91x: FW Version : 1.2.20.0
[ 9.166018] redpine_91x: RSI FW Version : 0000.1.2.0.0502
[ 9.166024] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.04
[ 9.166029] redpine_91x: Operating mode : 13 [Wi-Fi STA + BT DUAL]
[ 9.166033] redpine_91x: Firmware file : (null)
[ 9.166037] redpine_91x: ================================================
[ 79.836706] redpine_91x: redpine_set_clr_tx_intention,357: Wait event failed
[ 79.836732] redpine_91x: rsi_disconnect,1371: Failed to get tx_access
[ 79.836881] redpine_91x: rsi_reset_chip: Failed to Write SDIO WAKEUP REG
[ 79.900169] redpine_91x: rsi_reset_card: CMD0 failed : -123
[ 79.900180] redpine_91x: rsi_reset_card: CMD5 failed : -123
[ 79.900188] redpine_91x: rsi_reset_card: CMD5 failed : -123
[ 79.900194] redpine_91x: rsi_reset_card: card in not ready : 0 -123
[ 85.984180] redpine_91x: redpine_set_clr_tx_intention,357: Wait event failed
[ 85.984215] redpine_91x: rsi_tx_scheduler_thread,623: Failed to get tx_acces
[ 92.124712] redpine_91x: redpine_set_clr_tx_intention,357: Wait event failed
[ 92.124745] redpine_91x: rsi_coex_scheduler_thread,112: Failed to get tx_acs
[ 92.125304] redpine_91x: ##### RSI SDIO device disconnected #####
[ 112.921896] redpine_91x: rsi_probe: ***** 9116 Module *****
[ 112.922348] redpine_91x: redpine_hal_device_init: oper_mode = 13, coex_mode 2
[ 112.926983] redpine_91x: ***** Loaded Firmware *****
[ 115.996813] redpine_91x: ================================================
[ 115.996830] redpine_91x: ================ RSI Version Info ==============
[ 115.996834] redpine_91x: ================================================
[ 115.996837] redpine_91x: FW Version : 1.2.20.0
[ 115.996843] redpine_91x: RSI FW Version : 0000.1.2.0.0502
[ 115.996849] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.04
[ 115.996852] redpine_91x: Operating mode : 13 [Wi-Fi STA + BT DUAL]
[ 115.996857] redpine_91x: Firmware file : (null)
[ 115.996861] redpine_91x: ================================================
[ 116.000316] redpine_91x: rsi_send_bt_reg_params: Sending BT reg frame
[ 116.000710] redpine_91x: HCI module init done…
[ 116.002268] redpine_91x: RSI HCI DEVICE “hci0” open
[ 116.098848] redpine_91x: <==== Interface UP ====>
[ 116.098910] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 116.098918] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates…
[ 116.101143] redpine_91x: <==== Interface DOWN ====>
[ 116.105976] redpine_91x: <==== Interface UP ====>
[ 116.106027] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 116.106037] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates…
[ 116.107822] redpine_91x: RSI hci0' flush [ 116.107856] redpine_91x: RSI HCI DEVICE "hci0" closed [ 116.107861] redpine_91x: rsi_hci_close: device hci0’ not running
[ 119.951740] redpine_91x: <==== Interface DOWN ====>
[ 119.956401] redpine_91x: <==== Interface UP ====>
[ 119.956463] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 119.956473] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates…
purism@pureos:~$
So does this dmesg help? It seems something is wrong.
Wait… Booted again after shutdown. wifi came up normally.
So the exists some instability? Anyway I hope the above helps.
After update WiFi does not come up but after Power Down and Power Up it comes up normally.
Yes, that’s 5.11: No wifi on boot (#264) · Issues · Librem5 / linux · GitLab. It’s not a deterministic problem (although it seems to happen much more often for some than for others).
Ah wait, looking closer at that dmesg is actually suggest some kind of communication failure between the SoC and the card. Have you tried reseating the card in its M.2 slot?
No I did not try to re-seat it because I had no failures with kernel 5.9.
If you think that would be useful (to re-seat it) then I will try it. If this happens again in the next days then I will try to re-seat it for sure.
By the way the above link now gives 500 Error (“Something went wrong on our end”).
Yes the https://source.puri.sm/ site seems to be down now (or not working anyway).
Edit: an hour later: now https://source.puri.sm/ is working again.
I have noticed that when the wifi adapter does not come up this happens after a restart. For my phone at least, the wifi comes always up when I powerdown and start again. For example, today I updated phoc from 0.6 to 0.7. I restarted the phone. The wifi adapter did not come up. Instead of flipping the switch I decided to test with shutdown. After shutdown the wifi came up normally. So maybe a problem exists at restarts. Something in the wifi does not really reboot and then locks up.
I have experienced t he same situation after a kernel upgrade on a Manjaro PC. The system asked to reboot, and after reboot I spent 2 hours trying to find why the system did not have network from its ethernet card. I decided to go to another PC and enter Manjaro forums. There some guy wrote to others having the same problem. “Shut it down, do not restart”. And it worked! So maybe there is a bug in the restart procedure @dos
Support quickly pointed to a faulty wifi card, apparently there has been a few more faulty ones. They already sent it, expected to arrive the 5th of April, so have to wait a while more to share if that was the source of the problem.
It seems my WiFi has disappeared again, and the wrong firmware is back, according to dmesg.
Edit: Following @dos’s suggestion to reapply the fix he built for me last time, I reflashed the proper firmware and got WiFi back. I have no idea how the wrong Redpine firmware was able to get reinstalled on my phone, but now I’ve got 2.0.0.0 .
I may need to see about getting a replacement module.
