Optimizing Battery Management on Linux Phones: A Dive into PinePhone and Librem 5
That’s really cool
Yes, you are. chg_en is not a LED, it’s just hackily (and temporarily) exposed using the kernel’s LED framework. It does actually stop charging - it’s a GPIO line that is connected to BQ25895’s CHG_EN input. It’s completely unrelated to the actual red LED.
It’s the other way around! The red LED is directly controlled by BQ25895, so it can indicate real status of charging without software involvement. You can disable that and control the LED exclusively from software as well, but we don’t do that right now.
The actual red LED is exposed as part of rgb:status LED device.
A cleaner way to stop charging using kernel interfaces that are actually designed to do that would be to write 0 to /sys/class/power_supply/bq25890-charger-0/constant_charge_current (though this alone won’t stop precharging deeply discharged batteries from happening - you’d need to set precharge_current as well, though I don’t see much point in doing so unless you really need it and know what you’re doing).
This is very interesting. It has happened to me as well but for me it was because I either had put the phone on suspend (the the script didn’t get a chance to run) or it hit 100% before the 10 minute timer which is the service timer. Check the logs next time it happens and send it over. I’d be happy to troubleshoot with you :blush:
Hey thanks! Can you tell me which logs you mean? Terminal or any specific logfile?
  1. run journalctl -u manage_librem_battery.service in terminal and grab the logs for the given time period your incident happened. ie it didnt charge
  2. go to Documents/codes/manage_librem_battery/logs and grab that day’s csv
(i so need to make log save location better)
Hi after executing the journalctl -u command, it shows me the logs in the terminal, but my Documents folder ( Data/Documents) is complete empty!
Is there another location that you mean?
Not data/Documents but just Documents it should be in your home directory. You can send me a dm with the information aswell if you want.
Finally after an hour or so I managed to copy and paste the terminal prompts into a text file! The controls on the mobile screen are just terrible, I really should think about an adapter cable for a bigger screen. Hopefully this helps to find the error, Im so exited to try to use it as standart phone!
– Journal begins at Thu 2022-12-22 11:55:43 UTC, ends at Thu 2025-03-13 13:25:17 UTC. –
Mär 04 11:08:38 librem systemd[1]: Starting Manage Librem5 battery…
Mär 04 11:08:38 librem systemd[1]: Started Manage Librem5 battery.
lines 1-3…skipping…
Mär 04 11:08:38 librem python3[5237]: /usr/bin/python3: can’t open file '/usr/bin/manage_libre>
Mär 04 11:08:38 librem systemd[1]: manage_librem_battery.service: Main process exited, code=ex>
Mär 04 11:08:38 librem systemd[1]: manage_librem_battery.service: Failed with result 'exit-cod>
Mär 04 11:08:39 librem systemd[1]: manage_librem_battery.service: Scheduled restart job, resta>
Mär 04 11:08:39 librem systemd[1]: Stopped Manage Librem5 battery.
Mär 04 11:08:39 librem systemd[1]: Starting Manage Librem5 battery…
Mär 04 11:08:39 librem systemd[1]: Started Manage Librem5 battery.
Mär 04 11:08:39 librem python3[5239]: /usr/bin/python3: can’t open file '/usr/bin/manage_libre>
Mär 04 11:08:39 librem systemd[1]: manage_librem_battery.service: Main process exited, code=ex>
Mär 04 11:08:39 librem systemd[1]: manage_librem_battery.service: Failed with result 'exit-cod>
lines 1-15
P.S. Ah first see now that the ciles are still incomplete. I need to find the journalctl extension which allows me to copy and save specific prompts directly into a file.
If you run the command journalctl -u manage_librem_battery.service > log_file it will save everything in the log_file which you can grab and post. Also tell me the date and time it happened
Great we go it, thank you for this easy method, the one I wanted to use would be much more complicated! So now here is the log, it is a lot longer, but it is always only repeating those lines:
Mär 13 12:36:42 librem systemd[1]: manage_librem_battery.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Mär 13 12:36:42 librem systemd[1]: manage_librem_battery.service: Failed with result ‘exit-code’.
Mär 13 12:36:42 librem systemd[1]: manage_librem_battery.service: Scheduled restart job, restart counter is at 3.
Mär 13 12:36:42 librem systemd[1]: Stopped Manage Librem5 battery.
Mär 13 12:36:42 librem systemd[1]: Starting Manage Librem5 battery…
Mär 13 12:36:42 librem systemd[1]: Started Manage Librem5 battery.
Mär 13 12:36:42 librem systemd[1]: manage_librem_battery.service: Scheduled restart job, restart counter is at 4.
Mär 13 12:36:42 librem python3[851]: /usr/bin/python3: can’t open file ‘/usr/bin/manage_librem_battery.py’: [Errno 2] No such file or directory
Mär 13 12:36:42 librem systemd[1]: manage_librem_battery.service: Scheduled restart job, restart counter is at 5.
Mär 13 12:36:42 librem systemd[1]: manage_librem_battery.service: Start request repeated too quickly.
Mär 13 12:36:42 librem systemd[1]: Failed to start Manage Librem5 battery.
Did you copy the python file to the correct location
sudo cp manage_librem_battery.service /etc/systemd/system/manage_librem_battery.service
sudo cp manage_librem_battery.py /usr/bin/manage_librem_battery.py
There should be /usr/bin/manage_librem_battery.py present. Can you check please?
I have a folder named manage_librem_battery.service in my personal folder, it contains those the files and a readme file. I will move them by terminal, because the desktop right click menue appears when tipping on the screen, but I cant interact with it, it directlly disappears again.
EDIT: Ok I moved both of them there. I checked both folders and the files are now there. Before they werent. But I cant create new data for the journal. Will restart the phone and look tomorrow if this creates any new information in the journal.
Make sure you follow the steps in the github repo readme correctly
Seems to work now. The charging LED hasnt turned on while the desktop loading icon shows that it is conncected to electricity at 83%, so now it should drop to 60% and then start to charge it, right?
EDIT: Ok it seems to be a holding function, overnight it only drops by 1%, under normal circumstances, the battery could be at 100% now or empty if there is no cable plugged into. GREAT!!!
So now I cann finally attach the Anker Powerbank with he Velcrutape and try if I can make it useable in my daily life. But this was a big help now to make the phne useable, thanks!!
Take a look at: unicsy_demo/bat at master · pavelmachek/unicsy_demo · GitHub
From the site:
Charge modes:
max I payed for 100% of battery and I’m going to use it
norm simply always charge to 80%
eco Charge to 60%..80% percent. Good if you only need 40% of your battery (and can usually keep battery above 20%)
min Keep charge at 50%. Good for long-term storage or running at AC power, when you don’t need your battery at all.
readyby Make sure battery is 80% by specified time.
It would be cool to see integrated in “Mobile Settings”.
Not sure how you would integrate it. The thing is that both Pavel’s bat as well as manage_librem_battery run in userspace and will probably not work if you put the phone to sleep. Hence, you need to somehow daemonize them (e.g. using the systemd scripts) to run in the background plus you need to disable sleep on AC.
But yes, in theory it should be able to create such an package with a daemon that can be controlled out of mobile-settings, provided they can be extended as this stuff is quite l5-specific.
I cannot get manage_librem_battery.service to work with my Librem5. The script runs as expected but the /sys/class/leds/chg_en/brightness content doesn’t seem to have any effect on the charging behavior.
The content of /sys/class/power_supply/max170xx_battery/status constantly switches between Charging and Discharging within a few seconds. The charging level is at 98%.
I noticed that /sys/class/power_supply/max170xx_battery/charge_type does not exist, but I am not sure if that is applicable.
This is shown in the log:
2026-01-18 23:05:08 Behaviour internal: Charging, Battery internal: 98%, int_charger: NA,
2026-01-18 23:07:38 Behaviour internal: Discharging, Battery internal: 98%, int_charger: NA,
2026-01-18 23:17:38 Behaviour internal: Discharging, Battery internal: 98%, int_charger: NA,
2026-01-18 23:27:38 Behaviour internal: Charging, Battery internal: 98%, int_charger: NA,
2026-01-18 23:37:38 Behaviour internal: Charging, Battery internal: 98%, int_charger: NA,
This is shown when I run the script manually:
98
int_bat_perc 98
int_charger_con NA
Current charging behaviour: 1
No change needed: Charging behaviour for max170xx_battery is already 1.
set inhibiting charger internal
98
int_bat_perc 98
int_charger_con NA
Any hint on how to get it to work would be greatly appreciated.
