PostmarketOS tangent
I already showed you the link here https://source.puri.sm/Librem5/firmware-tps6598x-nonfree That is non-free firmware instructions for the DP. If you look at that, you’ll notice that they actually have the binary blob stored locally now: tps65982-librem5-dp-alt-mode.bin · master · Librem5 / firmware-tps6598x-nonfree · GitLab
If you’re looking at the cellular modem link and presume I haven’t read that and see that the user who posted it a moderator blacked out the URL after the fact, it’s a bad presumption. But I will point out that support certainly gave the instructions with the URL. And it doesn’t take a genius (only google-fu) to find that the link is <<censored by moderator - seriously, dude!>> which if you unzip it has the nonfree firmware. Distributed from puri.sm. Intention.
Or one could simply look at the BroadMobi operations manual and go right to the section entitled “Updating Firmware” where they describe how to upgrade the firmware from windows. It’s in their FCC documents. So, at least BroadMobi had the intention that people would need to update firmware after delivery. Of course their instructions require Windows … which is a bigger obstruction to Purism customers than most :wink:
Discourse posts can only be edited up to one month, so the image containing the instructions was recently tampered by a third-party.
I’m not sure if it wasn’t originally blacked out by the poster. I am confident, though, that when Purism support gave that user the instructions, it included a non-blacked out URL for the download. That said, the link to the Purism hosted zip file that contains the non-free driver was still easy to find.
The image did not originally contain redacted information.
No good deed goes unpunished, I suppose. I’ll take the action to secure those files on Nextcloud. Sharing links to protected files hosted on Purism servers is a quick way to have those files locked down. It’s a matter of a business agreement/relationship with the product vendor; we must be careful to not bite the hand that feeds. I’m an advocate of sharing as much as possible, but it’s not worth a cease-and-desist and/or losing future access.
Be aware that Broadmobi describes how to use Windows to update their firmware as part of the FCC documents for their card.
That is the danger of proprietary firmware. Those dangers are best made clear and transparent. It’s part of why RYF is there.
Yep. Thanks :pray:
:rocket:
I understand, but my point stands. These restrictions will not change until we have a follow-up discussion with the vendor. It’s professional courtesy.
Yes. I did that. In order to give effect to Purism’s intention.
Of course I only did what I had access to do. I can’t fix the underlying URL.
Could we just use a new random URL each time and time out any given URL after X days?
Regardless, as a valid URL has escaped into the wild, that URL should cease to be valid.
Yes, Nextcloud allows expiration dates for link shares, with or without password protection.
To me David Heidelberg and PostmarketOS both are same untransparent. They are a perfect match for each other. Both do not recognize Gnu credits.
