I thought so. But what I don’t understand is that mainstream memory kits are not supported by the Intel FSP… And that I’m so unlucky to pick two of those memory kits which are not supported. At the same time I can’t find all those “I payed so much for this useless crap and now I payed even more for memory which isn’t supported yada yada yada…” posts in this forum. And that’s really surprising…
I find it more surprising that my Librem 14 works just fine with very similar RAM, but yours does not. Here is a photo of my Librem 14 after disassembly:
Yes and it’s hard to accept for me that you were just lucky and I wasn’t. If we were talking about a free software project I’d find it much easier to accept that – but we are talking about the Intel FSP.
I simply can’t believe that Kingston is selling memory modules which are known not to work on Intel hardware and with the Intel FSP…
Still, all what was tested until now does not rule out that your hardware could simply be faulty…
Maybe someone nice here on this forum would accept that you send them both your DRAM modules for them to try on their Librem 14. If those work fine on someone else’s L14, at least you will know the problem originates from your device.
I’m surprised the RAM slots require one stick to be flipped (left-to-right) different than the other. There should be no confusion because of the alignment cut/slot, but it seems strange.
It’s pretty odd. IIRC, the Librem 14 had some delay because it had issues with the RAM slots/combinations (IIRC it was a blog comment by mrchromebox or kylerankin; I only recall this because it surprised me since I had thought they were using a bog-standard mainboard).
Memory timing is tricky. If you hadn’t tried with another pair, I would have assumed the sticks had problems meeting its advertised timings.
If you can still return your 2 x 16GB kit, I suppose you could try a 1 x 32GB (with the same stick that FranklyFlawless is using). Even if it doesn’t work as a single, it probably would work paired with your 8GB chip. You wouldn’t get dual channel performance, but it might be an option. And that way, if funds become available, you would only need to upgrade with a single 32GB chip instead of a pair.
I strongly doubt this to be possible: if bought online, most certainly not (unless maybe still inside the sealed anti-static package as a proof of never used); and if returned to a brick-and-mortar outlet, they would not want nor have the means to exhaustively test both modules to insure they were not damaged and still meet specifications…
