At my work they provide desks with the Fujitsu USB Port Replicator PR09 with two DisplayPort displays, a mouse and a keyboard connected to it.
I connected my Librem 5 to this Fujitsu USB Port Replicator, but no output was shown on the displays. The displays were also not detected in GNOME settings. However, charging, mouse and keyboard do work.
Should video output theoretically work on display(s) connected to the Fujitsu USB Port Replicator PR09?
Here are de detailed specifications:
The spec mentions “DisplayLink”. For that you’d need https://github.com/AdnanHodzic/displaylink-debian .
edit: This works on my Librem14, but I’m not sure whether it is available for Arm64.
Thanks! According to this page you must not run Wayland, unfortunately. Are you using X server on your Librem14?
Ups, yes, I did. I always thought I did, because I wanted some manager for the clipboard, but probably it’s that also.
Just moved on to wayland, because of waydroid ;-). The dock is at the office and I worked from home during the pandemic.
Here some more info of the docking station:
Bus 001 Device 005: ID 2020:2060 Qualcomm, Incorporated Qualcomm CDMA Technologies MSM
Bus 001 Device 003: ID 0424:4041 Microchip Technology, Inc. (formerly SMSC) Hub and media card controller
Bus 001 Device 002: ID 0424:2640 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Bus 004 Device 007: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 004 Device 006: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 004 Device 005: ID 0bda:0412 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 004 Device 004: ID 17e9:6005 DisplayLink PR09 DisplayPort Dock
Bus 004 Device 003: ID 0bda:0411 Realtek Semiconductor Corp. Hub
Bus 004 Device 002: ID 0bda:0421 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 008: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 003 Device 007: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 003 Device 006: ID 0bda:5412 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 003 Device 005: ID 0bf8:1028 Fujitsu Siemens Computers Fujitsu Keyboard
Bus 003 Device 004: ID 03f0:0941 HP, Inc X500 Optical Mouse
Bus 003 Device 003: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
Bus 003 Device 002: ID 0bda:5421 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.20
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 9
idVendor 0x17e9 DisplayLink
idProduct 0x6005
bcdDevice 31.12
iManufacturer 1 DisplayLink
iProduct 2 PR09 DisplayPort Dock
iSerial 3 YVFJ033769
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x026a
bNumInterfaces 7
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 8mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 6
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 3
iInterface 0
** UNRECOGNIZED: 0c 5f 01 00 0a 00 04 04 01 00 04 00
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x0a EP 10 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x0b EP 11 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x0c EP 12 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 1
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 4
iInterface 0
** UNRECOGNIZED: 0c 5e 01 00 0a 00 00 04 01 00 00 00
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
bInterfaceProtocol 1
iInterface 0
Device Firmware Upgrade Interface Descriptor:
bLength 9
bDescriptorType 33
bmAttributes 1
Will Not Detach
Manifestation Intolerant
Upload Unsupported
Download Supported
wDetachTimeout 200 milliseconds
wTransferSize 16384 bytes
bcdDFUVersion 1.01
** UNRECOGNIZED: 10 40 0a 0b 30 09 02 21 52 69 64 67 65 44 6f 63
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 2
bInterfaceCount 3
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 6 USB Audio
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 6 USB Audio
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 11
wTotalLength 0x0087
bmControls 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 1
bmAttributes 1 Internal fixed clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 0
bLength 8
bDescriptorType 36
bClockID 2
bmControls 0x07
bAssocTerminal 0
iClockSource 0
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bCSourceID 1
bNrChannels 2
bmChannelConfig 0x00000003
Front Left (FL)
Front Right (FR)
iChannelNames 0
bmControls 0x0004
Connector Control (read-only)
iTerminal 0
bLength 18
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 4
bSourceID 3
bmaControls(0) 0x00000000
bmaControls(1) 0x0000000f
Mute Control (read/write)
Volume Control (read/write)
bmaControls(2) 0x0000000f
iFeature 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 5
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 4
bCSourceID 1
bmControls 0x0000
iTerminal 6 USB Audio
bLength 17
bDescriptorType 36
bTerminalID 6
bAssocTerminal 0
bCSourceID 2
bNrChannels 6
bmChannelConfig 0x0000003f
Front Left (FL)
Front Right (FR)
Front Center (FC)
Low Frequency Effects (LFE)
Back Left (BL)
Back Right (BR)
iChannelNames 0
bmControls 0x0000
bLength 34
bDescriptorType 36
bUnitID 7
bSourceID 6
bmaControls(3) 0x0000000f
bmaControls(4) 0x0000000f
bmaControls(5) 0x0000000f
bmaControls(6) 0x0000000f
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 8
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 7
bCSourceID 2
bmControls 0x0004
iTerminal 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0007 1x 7 bytes
bInterval 8
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 1
bNumEndpoints 1
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 6
bmControls 0x00
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 6
Front Left (FL)
Front Right (FR)
Front Center (FC)
Back Left (BL)
Back Right (BR)
iChannelNames 0
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x09 EP 9 OUT
bmAttributes 13
Transfer Type Isochronous
Synch Type Synchronous
Usage Type Data
wMaxPacketSize 0x0241 1x 577 bytes
bInterval 4
bMaxBurst 0
AudioStreaming Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 1 Milliseconds
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 2
bNumEndpoints 1
bLength 16
bDescriptorType 36
bTerminalLink 6
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 13
Usage Type Data
wMaxPacketSize 0x00c1 1x 193 bytes
bInterval 4
bMaxBurst 0
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 1
bNumEndpoints 1
bLength 16
bDescriptorType 36
bTerminalLink 5
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x00c5 1x 197 bytes
bInterval 4
bMaxBurst 0
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 8
bDescriptorType 11
bFirstInterface 5
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 13
bFunctionProtocol 0
iFunction 5 USB Giga Ethernet
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 13
bInterfaceProtocol 0
iInterface 5 USB Giga Ethernet
CDC Header:
bcdCDC 1.20
CDC Union:
bMasterInterface 5
bSlaveInterface 6
CDC Ethernet:
iMacAddress 4 6CA9367F1830
bmEthernetStatistics 0x1afbffff
wMaxSegmentSize 1514
wNumberMCFilters 0x8010
bNumberPowerFilters 8
CDC NCM:
bcdNcmVersion 1.00
bmNetworkCapabilities 0x03
net address
packet filter
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0011 1x 17 bytes
bInterval 8
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 6
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 10 CDC Data
bLength 9
bDescriptorType 4
bInterfaceNumber 6
bAlternateSetting 1
bNumEndpoints 2
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x0046
bNumDeviceCaps 4
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000006
BESL Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000c
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 2
Lowest fully-functional device speed is High Speed (480Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 100 micro seconds
Container ID Device Capability:
bLength 20
bDescriptorType 16
bDevCapabilityType 4
bReserved 0
ContainerID {953efcf4-2d98-8847-91bc-1924d6fddf25}
Platform Device Capability:
bLength 28
bDescriptorType 16
bDevCapabilityType 5
bReserved 0
PlatformCapabilityUUID {d8dd60df-4589-4cc7-9cd2-659d9e648a9f}
CapabilityData[0] 0x00
CapabilityData[1] 0x00
CapabilityData[2] 0x03
CapabilityData[3] 0x06
CapabilityData[4] 0x22
CapabilityData[5] 0x06
CapabilityData[6] 0x01
CapabilityData[7] 0x00
Device Status: 0x0001
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0bf8 Fujitsu Siemens Computers
idProduct 0x1028
bcdDevice 1.00
iManufacturer 1 Fujitsu
iProduct 2 Fujitsu Keyboard
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x003b
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 65
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
wDescriptorLength 158
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
Device Status: 0x0000
(Bus Powered)
