Environment: gnome calls alpha43, Linux l5librem 5.18.0-1-librem5, pureos 10, arm64.
@kop316 i tried to compile it on my phone but since i dont know what i am doing (i mean i can copy paste commands but i dont know which folders i need to execute them in) its not working haha. Also during meson _build prep stage it is having issues with gtk±3.0 .
Does anybody have this compiled for deb or flatpak?
"Found CMake: /usr/bin/cmake (3.18.4)
Run-time dependency gtk±3.0 found: NO (tried pkgconfig and cmake)
meson.build:106:0: ERROR: Dependency “gtk±3.0” not found, tried pkgconfig and cmake
A full log can be found at /home/purism/Downloads/phosh-antispam-master/_build/meson-logs/meson-log.txt
Entire Log:
Build started at 2022-06-10T12:46:59.432440
Main binary: /usr/bin/python3
Build Options:
Python system: Linux
The Meson build system
Version: 0.56.2
Source dir: /home/purism/Downloads/phosh-antispam-master
Build dir: /home/purism/Downloads/phosh-antispam-master/_build
Build type: native build
Project name: phosh-antispam
Project version: 2.0
None of ‘CC’ are defined in the environment, not changing global flags.
None of ‘CFLAGS’ are defined in the environment, not changing global flags.
None of ‘LDFLAGS’ are defined in the environment, not changing global flags.
None of ‘CPPFLAGS’ are defined in the environment, not changing global flags.
None of ‘CC_LD’ are defined in the environment, not changing global flags.
Sanity testing C compiler: cc
Is cross compiler: False.
Sanity check compiler command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/sanitycheckc.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/sanitycheckc.exe -pipe -D_FILE_OFFSET_BITS=64
Sanity check compile stdout:
Sanity check compile stderr:
Running test binary command: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/sanitycheckc.exe
C compiler for the host machine: cc (gcc 10.2.1 “cc (Debian 10.2.1-6) 10.2.1 20210110”)
C linker for the host machine: cc ld.bfd 2.35.2
None of ‘AR’ are defined in the environment, not changing global flags.
C compiler for the build machine: cc (gcc 10.2.1 “cc (Debian 10.2.1-6) 10.2.1 20210110”)
C linker for the build machine: cc ld.bfd 2.35.2
Build machine cpu family: aarch64
Build machine cpu: aarch64
Host machine cpu family: aarch64
Host machine cpu: aarch64
Target machine cpu family: aarch64
Target machine cpu: aarch64
Configuring config.h using configuration
Configuring run using configuration
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpx9jye9xu
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpx9jye9xu/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpx9jye9xu/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -fasynchronous-unwind-tables
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -fasynchronous-unwind-tables: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp56th0jjg
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp56th0jjg/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp56th0jjg/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -fno-strict-aliasing
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -fno-strict-aliasing: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmph6f41xyl
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmph6f41xyl/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmph6f41xyl/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wall
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wall: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbvapehp7
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbvapehp7/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbvapehp7/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wcast-align
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wcast-align: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpa53nd3_w
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpa53nd3_w/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpa53nd3_w/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wdate-time
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wdate-time: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmplkdmt1bb
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmplkdmt1bb/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmplkdmt1bb/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Werror=format-security
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
cc1: error: ‘-Wformat-security’ ignored without ‘-Wformat’ [-Werror=format-security]
cc1: some warnings being treated as errors
Compiler for C supports arguments -Werror=format-security: NO
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpn7qugj1o
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpn7qugj1o/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpn7qugj1o/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Werror=implicit-function-declaration
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Werror=implicit-function-declaration: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmprye_dt6k
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmprye_dt6k/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmprye_dt6k/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Werror=pointer-to-int-cast
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Werror=pointer-to-int-cast: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpslfmmrzr
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpslfmmrzr/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpslfmmrzr/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Werror=redundant-decls
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Werror=redundant-decls: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv_9u8pfz
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv_9u8pfz/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv_9u8pfz/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Werror=return-type
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Werror=return-type: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp3zk22860
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp3zk22860/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp3zk22860/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Werror=vla
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Werror=vla: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpvms8flat
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpvms8flat/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpvms8flat/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Werror=write-strings
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Werror=write-strings: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpm3t75_7e
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpm3t75_7e/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpm3t75_7e/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wfloat-equal
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wfloat-equal: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/build/meson-private/tmpu0jgryc
Command line: cc /home/purism/Downloads/phosh-antispam-master/build/meson-private/tmpu0jgryc/testfile.c -o /home/purism/Downloads/phosh-antispam-master/build/meson-private/tmpu0jgryc/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wformat=2
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wformat=2: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpvql1d1a5
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpvql1d1a5/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpvql1d1a5/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wimplicit-fallthrough
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wimplicit-fallthrough: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpsxqjoqgo
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpsxqjoqgo/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpsxqjoqgo/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wlogical-op
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wlogical-op: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp28b8aqvg
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp28b8aqvg/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp28b8aqvg/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wmissing-format-attribute
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wmissing-format-attribute: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpjccfm717
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpjccfm717/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpjccfm717/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wmissing-include-dirs
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wmissing-include-dirs: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpeb1bx48m
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpeb1bx48m/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpeb1bx48m/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wmissing-prototypes
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wmissing-prototypes: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp_e8hxl0o
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp_e8hxl0o/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp_e8hxl0o/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wnested-externs
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wnested-externs: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp9xd422ss
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp9xd422ss/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmp9xd422ss/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wold-style-declaration
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wold-style-declaration: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpzz88z3nd
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpzz88z3nd/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpzz88z3nd/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wold-style-definition
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wold-style-definition: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv0o66mf1
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv0o66mf1/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv0o66mf1/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wpointer-arith
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wpointer-arith: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpuw82l8gw
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpuw82l8gw/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpuw82l8gw/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wshadow
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wshadow: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbpmfbr42
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbpmfbr42/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbpmfbr42/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wswitch-default
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wswitch-default: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpo6ra6zxm
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpo6ra6zxm/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpo6ra6zxm/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wswitch-enum
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wswitch-enum: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpz3nm0d9b
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpz3nm0d9b/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpz3nm0d9b/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wtrigraphs
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wtrigraphs: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpmpq2n_zh
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpmpq2n_zh/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpmpq2n_zh/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 -Wunused
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -Wunused: YES
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpuy368pev
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpuy368pev/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpuy368pev/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0
Code:
extern int i;
int i;
Compiler stdout:
Compiler stderr:
Compiler for C supports arguments -pipe: YES
Pkg-config binary for MachineChoice.HOST is not cached.
None of ‘PKG_CONFIG’ are defined in the environment, not changing global flags.
Pkg-config binary missing from cross or native file, or env var undefined.
Trying a default Pkg-config fallback at pkg-config
Found pkg-config: /usr/bin/pkg-config (0.29.2)
Determining dependency ‘glib-2.0’ with pkg-config executable ‘/usr/bin/pkg-config’
PKG_CONFIG_PATH:
Called /usr/bin/pkg-config --modversion glib-2.0
-> 0
2.66.8
PKG_CONFIG_PATH:
Called /usr/bin/pkg-config --cflags glib-2.0
-> 0
-I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include
PKG_CONFIG_PATH:
Called /usr/bin/pkg-config glib-2.0 --libs
-> 0
-L/usr/lib/aarch64-linux-gnu -lglib-2.0
PKG_CONFIG_PATH:
-> 0
-lglib-2.0
None of ‘PKG_CONFIG_PATH’ are defined in the environment, not changing global flags.
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv6avu8wb
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv6avu8wb/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpv6avu8wb/output.exe -pipe -D_FILE_OFFSET_BITS=64 -O0
Code:
#include<stdio.h>
int main(void) {
printf("%ld\n", (long)(sizeof(void *)));
return 0;
Compiler stdout:
Compiler stderr:
Program stdout:
8
Program stderr:
Running compile:
Working directory: /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbp6qx22l
Command line: cc /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbp6qx22l/testfile.c -o /home/purism/Downloads/phosh-antispam-master/_build/meson-private/tmpbp6qx22l/output.obj -pipe -c -D_FILE_OFFSET_BITS=64 -O0 --print-search-dirs
Code:
Compiler stdout:
install: /usr/lib/gcc/aarch64-linux-gnu/10/
programs: =/usr/lib/gcc/aarch64-linux-gnu/10/:/usr/lib/gcc/aarch64-linux-gnu/10/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/10/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/aarch64-linux-gnu/bin/aarch64-linux-gnu/10/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/aarch64-linux-gnu/bin/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/aarch64-linux-gnu/bin/
libraries: =/usr/lib/gcc/aarch64-linux-gnu/10/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/aarch64-linux-gnu/lib/aarch64-linux-gnu/10/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/aarch64-linux-gnu/lib/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/aarch64-linux-gnu/lib/…/lib/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/aarch64-linux-gnu/10/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/lib/:/lib/aarch64-linux-gnu/10/:/lib/aarch64-linux-gnu/:/lib/…/lib/:/usr/lib/aarch64-linux-gnu/10/:/usr/lib/aarch64-linux-gnu/:/usr/lib/…/lib/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/…/aarch64-linux-gnu/lib/:/usr/lib/gcc/aarch64-linux-gnu/10/…/…/…/:/lib/:/usr/lib/
Compiler stderr:
Run-time dependency glib-2.0 found: YES 2.66.8
Pkg-config binary for MachineChoice.HOST is cached.
Determining dependency ‘gtk±3.0’ with pkg-config executable ‘/usr/bin/pkg-config’
PKG_CONFIG_PATH:
Called /usr/bin/pkg-config --modversion gtk+-3.0
-> 1
CMake binary for MachineChoice.HOST is not cached
None of ‘CMAKE’ are defined in the environment, not changing global flags.
CMake binary missing from cross or native file, or env var undefined.
Trying a default CMake fallback at cmake
None of ‘CMAKE_PREFIX_PATH’ are defined in the environment, not changing global flags.
Extracting basic cmake information
Try CMake generator: auto
Calling CMake ([’/usr/bin/cmake’]) in /home/purism/Downloads/phosh-antispam-master/_build/meson-private/cmake_gtk±3.0 with:
- “–trace-expand”
- “–trace-format=json-v1”
- “–no-warn-unused-cli”
- “–trace-redirect=cmake_trace.txt”
- “-DCMAKE_TOOLCHAIN_FILE=/home/purism/Downloads/phosh-antispam-master/_build/meson-private/cmake_gtk±3.0/CMakeMesonToolchainFile.cmake”
– Module search paths: [’/’, ‘/opt’, ‘/usr’, ‘/usr/local’]
– CMake root: /usr/share/cmake-3.18
– CMake architectures: [‘aarch64-linux-gnu’]
– CMake lib search paths: [‘lib’, ‘lib32’, ‘lib64’, ‘libx32’, ‘share’, ‘lib/aarch64-linux-gnu’]
Preliminary CMake check failed. Aborting.
