SSH stops after battery level is low
Thanks,
if that is for the case when ssh is not working, then I have no idea what the problem is. If you get it sorted, please let us know the details.
Found this link;
The suggested solution mentions
If your server struggles to respond to you via ssh, then it most likely is swapping itself to death. Everything starts to take ages if server consumes all its time for swapping pages in and out of memory to disk.
Could that be the case when Waydroid is installed?
Maybe.
By using the command free before and after you start Waydroid you can see how much additional swap Waydroid uses.
