Standard Coreboot vs Pureboot breakdown (for a newbie)
I’m trying to update the coreboot.
I’m at the step where I need to choose standard vs Pureboot beta.
I no nothing of the 2. Which do I choose & why?
thanks
Please read about PureBoot here: https://puri.sm/faq/#faq-pureboot
If you do not have a Librem Key, choose just coreboot (option 1).
Thanks. 2 more newbie q…
Where is the coreboot-heads rom file after the update to copy to the USB?
I imagine the last step to the update is the flash the room using the .ROM file?
I do not understand, how are you updating? Via script from puri.sm/coreboot ?
I’m updating via the script.
The last step says:
"Injecting serial number into firmware image
You may now copy the coreboot update file to USB for updating via Heads."
Trouble is i don’t know where the .rom is to copy to the USB?
Found it. its in user/updates/firmware
Wait, so you are already running PureBoot firmware, not a plain coreboot?
Yes, running Pureboot on the most recent 13" Librem.
This was a critical piece of information that we needed. :slight_smile:
Yes, now copy the resulting .ROM file to a USB drive, and reboot your computer. Then follow https://docs.puri.sm/PureBoot/GettingStarted.html#updating-pureboot-firmware to update.
Just curious, is it possible to order a Librem Key when preparing to flash the L5?
Sure, but the Librem Key is only suggested for PureBoot and its variants. The Librem 5 does not use PureBoot.
The Librem 5 doesn’t use Coreboot either.
Bottom line is that the Librem 5 does not (yet?) offer the integrity functionality that Pureboot + Librem Key offers and if and when that is offered for the Librem 5 we don’t know what technology it will use.
You can get a small part of the functionality of the Librem Key through use of an OpenPGP card in your Librem 5.
