State of MMS on Librem 5
Yes, I had found that and looked up what allow_inactive vs allow_active meant and that was my impression. And by running chatty from the terminal instead of from a remote session, I got different output which you will see in the other post I just made.
I also get the error “Couldn’t delete SMS - error: GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Failed: Couldn’t delete 2 parts from this SMS” but that does not prevent me from receiving MMS messages.
Looking back at the mmsd output you posted earlier and comparing to what I get, I think now I see a difference that could be important.
You posted this:
For me the corresponding part of mmsd output looks like this:
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:mms_parse_headers() saw header of type 11
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:mms_parse_headers() running handler for type 11
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:decode_text() claimed len: 18
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:decode_text() val: 717500249@mmscse1
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:mms_parse_headers() handler for type 11 was success
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:mms_parse_headers() saw header of type 25
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:mms_parse_headers() type isn't a part of the standard? Skipping 26
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:extract_content_id() extracted content-id <FOT4928.jpg>
Apr 16 00:04:51 pureos mmsd[590]: src/mmsutil.c:extract_content_id() extracted content-id <Smil.txt>
Apr 16 00:04:51 pureos mmsd[590]: src/service.c:activate_bearer() service 0xaaaae13a4b30 setup 0 active 1
So for me it says “extracted content-id <FOT4928.jpg>” which looks good, that .jpg is probably the image I received in the MMS.
But for you it instead says “extracted content-id” and nothing more, as if the content-id is nonexistent/empty.
What do you think @kop316 – could this be something, to find out why there is no content-id there? That could be figured out by adding some extra debug output in mmsd, perhaps?
I’m sorry at this point, I tried to read the thread a couple of times and I am not sure what I am trying to answer. Is it still this:
" I never get anything in ~/mms just in /.mms/modemmanager."
“extracted content-id” alone should be okay? but I am not as familiar with that part of the code. It looks to be here:
EDIT: Does this look familiar for the issue?:
@kop316 I see that you found a possible fix for the MMS issue I was seeing, so I started over with all the steps from https://source.puri.sm/Librem5/chatty/-/issues/30#note_151962. Unfortunately, I am unable to build mmsd anymore. If I do these steps:
mkdir mmsd
cd mmsd
git clone Chris Talbot / mmsd ¡ GitLab
cd mmsd/
git checkout debian/modemmanager/latest
sudo apt-get -y build-dep .
dpkg-buildpackage -us -uc -b
I get this error:
builddeps:. : Depends: debhelper-compat (= 13)
If I try to follow the instructions that you put at your git page for mmsd I can’t build because the version of meson I have is 0.51.1 but 0.56.0 or later is required.
Can you tell me how I can build your mmsd on librem 5 amber? Is it possible?
Thanks.
@francepat
Good! Was it the SMIL issue? That turned out to be a silly mistake on my end, a pmOS dev was very nice in helping be figure it out. Everyone so far who has reported the issue says it is fixed.
HOWEVER, that was a purple-mm-sms bug, NOT an mmsd bug. You need to rebuild purple-mm-sms for the fix.
Mobian is on Bullseye, and Amber Phone is on Buster, so you need to change “Depends: debhelper-compat (= 13)” to “debhelper-compat (= 12)” :
https://source.puri.sm/kop316/mmsd/-/blob/debian/modemmanager/latest/debian/control#L6
This is probably not an issue. This is what Mobian/pmOS had as their version…so I just stuck that number. Change this line:
to “0.51.1” instead of “0.56.0”
If you want to use the deb package, you can change it here:
https://source.puri.sm/kop316/mmsd/-/blob/debian/modemmanager/latest/debian/patches/0014-Add-support-for-building-with-meson.patch#L139
So, I had already tried changing the debian control file, but that didn’t work.
So I tried changing meson.version in meson.build and that did seem to work, except that instead of:
meson compile -C _build
I had to do just:
meson compile
I verified that the change from Commit afffbef0 (changing a guint to a guint64 on line 1035) was there. I verified that the built mmsd was the one running but I am still not getting the MMS message, although it does show up in ~/.mms/modemanager (but nothing in ~/mms) and if I send it a regular text it goes through so things aren’t blocked. I will try getting further debug information later.
Thanks for all your help.
Hello,
The bug was in purple-mm-sms, NOT mmsd. Please redownload/compile/install purple-mm-sms.
Unfortunately I cannot do much without logs.
@kop316, sorry I guess I wasn’t clear. I needed to rebuild mmsd along with everything else because I had put on updates. I did rebuild the purple-mm-sms with this fix. I have verified that I have the newly built mm-sms.so in /usr/lib/purple-2 and that it is the one referenced by the running chatty.
No worries, just didn’t want you to be confused if a bug showed up again when it was fixed.
OK, here is the excerpt from mmsd with debugging on:
mmsd[2062]: ../src/mmsutil.c:mms_message_decode() about to check well known
mmsd[2062]: ../src/mmsutil.c:mms_message_decode() about to extract short
mmsd[2062]: ../src/mmsutil.c:mms_message_decode() octet 132
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 24
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() running handler for type 24
mmsd[2062]: ../src/mmsutil.c:decode_text() claimed len: 34
mmsd[2062]: ../src/mmsutil.c:decode_text() val: DLLB01030419205126521203000100000
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() handler for type 24 was success
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 13
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() running handler for type 13
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() handler for type 13 was success
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 23
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() running handler for type 23
mmsd[2062]: ../src/mmsutil.c:extract_text_array_element()
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() handler for type 23 was success
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 16
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 9
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() running handler for type 9
mmsd[2062]: ../src/mmsutil.c:extract_from() trying to decode text of length 22: +15612062856/TYPE=PLMN
mmsd[2062]: ../src/mmsutil.c:extract_from() text=“+1[…]/TYPE=PLMN”
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() handler for type 9 was success
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 11
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() running handler for type 11
mmsd[2062]: ../src/mmsutil.c:decode_text() claimed len: 37
mmsd[2062]: ../src/mmsutil.c:decode_text() val: 139d4b85-4baa-49dc-8da4-7285144be58e
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() handler for type 11 was success
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 5
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() running handler for type 5
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() handler for type 5 was success
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 6
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() saw header of type 25
mmsd[2062]: ../src/mmsutil.c:mms_parse_headers() type isn’t a part of the standard? Skipping 26
mmsd[2062]: ../src/mmsutil.c:extract_content_id() extracted content-id
Note it does mention attachment this time, but again nothing in ~/mms.
And here is the debug output from chatty:
16:51:25) mm-sms: New SMS at ‘/org/freedesktop/ModemManager1/SMS/4’(sm.puri.Chatty:2094): mm-sms-DEBUG: 16:51:25.650: cb_dbus_signal_sms_added: New SMS at /org/freedesktop/ModemManager1/SMS/4
(sm.puri.Chatty:2094): mm-sms-DEBUG: 16:51:25.659: pur_mm_check_pdu_type: pdu type deliver
(sm.puri.Chatty:2094): mm-sms-DEBUG: 16:51:25.659: cb_sms_list_new_ready
(sm.puri.Chatty:2094): mm-sms-DEBUG: 16:51:26.408: Received SMS WAP! Sending proxy call to mmsd
(sm.puri.Chatty:2094): mm-sms-DEBUG: 16:51:26.409: cb_sms_state_change: state received
(sm.puri.Chatty:2094): mm-sms-DEBUG: 16:51:26.483: cb_pur_mmsd_push_notify
(sm.puri.Chatty:2094): mm-sms-DEBUG: 16:51:26.511: Couldn’t delete SMS - error: GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Failed: Couldn’t delete 2 parts from this SMS
Do you think the issue is in the purple-mm-sms code or the mmsd code? I could try to put in some additional debug code in my copy if I knew the appropriate place.
Thanks.
On concerned about seeing the header 26…but maybe that’s a red herring.
Do you ever see a “MessageAdded” over the dbus? It looks like purple-mm-sms never sees the message.
No, the only thing I see monitoring the dbus is:
method call time=1618867920.222238 sender=:1.53 → destination=:1.3 serial=126 path=/org/ofono/mms; interface=org.ofono.mms.ModemManager; member=PushNotify
array of bytes [
2d 06 22 61 70 70 6c 69 63 61 74 69 6f 6e 2f 76 6e 64 2e 77 61 70 2e 6d
6d 73 2d 6d 65 73 73 61 67 65 00 af 84 8c 82 98 44 4c 4c 42 30 32 30 33
30 34 31 39 32 31 33 31 35 39 35 32 32 32 30 33 30 30 30 30 38 30 30 30
30 00 8d 91 89 18 80 2b 31 35 36 31 32 30 36 32 38 35 36 2f 54 59 50 45
3d 50 4c 4d 4e 00 96 02 ea 00 86 81 8a 80 8e 02 4e 82 88 05 81 03 03 f4
80 83 68 74 74 70 3a 2f 2f 31 30 37 2e 31 32 35 2e 36 33 2e 32 31 33 3a
38 30 30 35 2f 59 2f 30 34 31 39 32 31 33 31 35 39 35 32 32 32 30 33 30
30 30 30 38 30 30 30 30 00
Hmmm…that sounds like the parser is erroring out.
I’ll try to make a debug build for you to try tonight or tomorrow to figure out what’s happening.
Please do the following things for me:
  1. Delete (or move out of the folder) any MMSes in $HOME/.mms/ModemManager
  2. Start mmsd
  3. Recieve an MMS
  4. close mmsd
  5. Post the FULL log of the events here.
This will help me figure out the issue and where to put the debug messages.
Looking through the code again, I suspect mmsd is silently erroring out somewhere, but without the full log, it is hard for me to tell where.
Edit: Actually if you could, please file an issue here: https://source.puri.sm/kop316/mmsd/
Part of my problem is it was hard to parse through the logs here on what’s happening, and that’s why I got confused.
I have the log, but unfortunately I tried to register for source.puri.sm last week but I am still waiting for approval. Is there another way I can get the log to you?
Hmm,
That is worrying if that’s happening (though I guess I’m not surprised that they want to give approvals now).
You can post it here then and I can cross post it.
MMS daemon version 0.1-4
mmsd[2861]: ../src/service.c:__mms_service_init()
mmsd[2861]: ../src/plugin.c:__mms_plugin_init()
mmsd[2861]: ../src/service.c:mms_service_create() service 0xaaaae5e59f30
mmsd[2861]: ../src/service.c:mms_service_set_identity() service 0xaaaae5e59f30 identity modemmanager
mmsd[2861]: ../src/plugin.c:add_plugin() Plugin modemmanager loaded
mmsd[2861]: ../src/plugin.c:add_plugin() Plugin ofono loaded
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_state() MMSD_MM_STATE_MANAGER_FOUND
mmsd[2861]: ../plugins/modemmanager.c:cb_mm_manager_new() ModemManager found: :1.10
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_add_object() Added device at: /org/freedesktop/ModemManager1/Modem/0
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_init_modem() Not autoprocessing SMS WAPs
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_init_modem() mmsd_mm_init_modem
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_get_modem_state() MM_MODEM_GOOD_STATE: 11
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_state() MMSD_MM_STATE_READY
mmsd[2861]: ../plugins/modemmanager.c:mmsd_plugin_connect() Registering Modem Manager MMS Service
mmsd[2861]: ../src/service.c:mms_service_register() service 0xaaaae5e59f30
mmsd[2861]: ../src/service.c:emit_service_added() service 0xaaaae5e59f30
mmsd[2861]: ../src/service.c:mms_load_settings() Maximum Attachment Total Size (in bytes): 1400000
mmsd[2861]: src/service.c:load_message_from_store() There is no date stamp!
mmsd[2861]: ../src/mmsutil.c:mms_message_decode() about to check well known
mmsd[2861]: ../src/mmsutil.c:mms_message_decode() about to extract short
mmsd[2861]: ../src/mmsutil.c:mms_message_decode() octet 132
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 24
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 24
mmsd[2861]: ../src/mmsutil.c:decode_text() claimed len: 34
mmsd[2861]: ../src/mmsutil.c:decode_text() val: ATNB04050419211907424005000190000
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 24 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 13
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 13
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 13 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 11
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 11
mmsd[2861]: ../src/mmsutil.c:decode_text() claimed len: 37
mmsd[2861]: ../src/mmsutil.c:decode_text() val: 1c4b30fb-c6ef-44fd-9cec-2d97b1912aab
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 11 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 23
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 23
mmsd[2861]: ../src/mmsutil.c:extract_text_array_element()
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 23 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 9
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 9
mmsd[2861]: ../src/mmsutil.c:extract_from() trying to decode text of length 22: +1[…]/TYPE=PLMN
mmsd[2861]: ../src/mmsutil.c:extract_from() text=“+1[…]/TYPE=PLMN”
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 9 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 16
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 5
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 5
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 5 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 6
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 25
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() type isn’t a part of the standard? Skipping 26
mmsd[2861]: ../src/service.c:activate_bearer() service 0xaaaae5e59f30 setup 0 active 0
mmsd[2861]: ../src/mmsutil.c:decode_text() val: DLLB02030419213159522203000080000
mmsd[2861]: ../src/mmsutil.c:decode_text() val: 8905eb20-98d2-4b16-821e-923408f96bda
mmsd[2861]: ../src/mmsutil.c:extract_content_id() extracted content-id
mmsd[2861]: ../src/mmsutil.c:decode_text() val: DLLA04020419211654524202000230000
mmsd[2861]: ../src/mmsutil.c:decode_text() val: 366b63d2-c63c-42c1-9c84-60de95f0c57f
mmsd[2861]: ../src/mmsutil.c:decode_text() val: ATNA03020419213023413002000120000
mmsd[2861]: ../src/mmsutil.c:decode_text() val: 08523da1-849d-4510-ba6f-8fe85172c09e
mmsd[2861]: ../plugins/modemmanager.c:mmsd_plugin_connect() Setting Bearer Handler
mmsd[2861]: ../src/service.c:mms_service_set_bearer_handler() service 0xaaaae5e59f30 handler 0xaaaaac67044c
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_state() Not checking SMS WAPs
mmsd[2861]: ../plugins/modemmanager.c:mmsd_mm_get_modem_state() Auto processing unsent/unrecieved messages per settings.
mmsd[2861]: ../src/service.c:activate_bearer() service 0xaaaae5e59f30 waiting for 20 seconds
mmsd[2861]: ../plugins/modemmanager.c:set_context() Setting Context…
mmsd[2861]: ../src/service.c:mms_service_set_mmsc() service 0xaaaae5e59f30 mmsc https://mmsc.mobile.att.net
mmsd[2861]: ../plugins/modemmanager.c:set_context() Max number of bearers: 1
mmsd[2861]: ../plugins/modemmanager.c:set_context() Current Context APN: reseller, mmsd settings MMS APN: reseller
mmsd[2861]: ../plugins/modemmanager.c:set_context() You are connected to the correct APN! Enabling context…
mmsd[2861]: ../plugins/modemmanager.c:bearer_handler() At Bearer Handler: path /org/freedesktop/ModemManager1/Modem/0 active 1 context_active 1
mmsd[2861]: ../plugins/modemmanager.c:bearer_handler() active and context_active, bearer_notify
mmsd[2861]: ../src/service.c:mms_service_bearer_notify() service=0xaaaae5e59f30 active=1 iface=wwan0 proxy:80=proxy.mobile.att.net
mmsd[2861]: ../src/service.c:mms_service_bearer_notify() interface wwan0 proxy proxy.mobile.att.net:80
mmsd[2861]: ../src/service.c:process_request_queue() service 0xaaaae5e59f30
mmsd[2861]: ../src/service.c:process_request_queue() location (null)
mmsd[2861]: Cannot process request (request type: 2)
mmsd[2861]: ../src/service.c:get_messages()
mmsd[2861]: ../plugins/modemmanager.c:cb_get_sim_ready() Got SIM Path: /org/freedesktop/ModemManager1/SIM/0 Identifier: 89014104279702124090, imsi: 310410970212409
mmsd[2861]: ../src/service.c:activate_bearer() service 0xaaaae5e59f30 setup 0 active 1
mmsd[2861]: ../src/service.c:bearer_idle_timeout() service 0xaaaae5e59f30
mmsd[2861]: ../src/service.c:deactivate_bearer() service 0xaaaae5e59f30
mmsd[2861]: ../plugins/modemmanager.c:bearer_handler() At Bearer Handler: path /org/freedesktop/ModemManager1/Modem/0 active 0 context_active 1
mmsd[2861]: ../plugins/modemmanager.c:bearer_handler() checking for failure
mmsd[2861]: ../plugins/modemmanager.c:bearer_handler() No failures
mmsd[2861]: ../src/service.c:mms_service_bearer_notify() service=0xaaaae5e59f30 active=0 iface=wwan0 proxy:80=proxy.mobile.att.net
mmsd[2861]: ../plugins/modemmanager.c:handle_method_call() handle_method_call
mmsd[2861]: ../src/service.c:mms_service_push_notify() service 0xaaaae5e59f30 data 0xffff94011400 len 177
mmsd[2861]: ../src/service.c:mms_service_push_notify() about to push notify
mmsd[2861]: ../src/push.c:mms_push_notify() pdu 0xffff94011400 len 177
mmsd[2861]: ../src/push.c:mms_push_notify() 2D06226170706C69636174696F6E2F766E642E7761702E6D6D732D6D65737361676500AF848C8298444C4C413033303330343139323233333331353233323033303030303030303030008D918918802B31353631323036323835362F545950453D504C4D4E009602EA0086818A808E024E828805810303F48083687474703A2F2F3130372E3132352E36332E3130303A383030352F592F3034313932323333333135323332303330303030303030303000
mmsd[2861]: Body Length: 140
mmsd[2861]: ../src/service.c:mms_service_push_notify() did push notify; about to store
mmsd[2861]: ../src/store.c:generate_uuid_from_pdu() pdu 0xffff94011425 len 140
mmsd[2861]: ../src/store.c:mms_store() pathname /home/purism/.mms/modemmanager/EBBD68242206333C8793B30116F19F65B43EE09A
mmsd[2861]: ../src/service.c:mms_service_push_notify() did store; about to decode
mmsd[2861]: ../src/mmsutil.c:mms_message_decode() octet 130
mmsd[2861]: ../src/mmsutil.c:decode_text() val: DLLA03030419223331523203000000000
mmsd[2861]: ../src/mmsutil.c:extract_from() trying to decode text of length 22: +1YPE=PLMN
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 22
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 22
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 22 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 10
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 10
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 10 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 14
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 14
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 14 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 8
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 8
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 8 was success
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() saw header of type 3
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() running handler for type 3
mmsd[2861]: ../src/mmsutil.c:decode_text() claimed len: 55
mmsd[2861]: ../src/mmsutil.c:decode_text() val: http://107.125.63.100:8005/Y/0419223331523203000000000
mmsd[2861]: ../src/mmsutil.c:mms_parse_headers() handler for type 3 was success
mmsd[2861]: ../src/service.c:mms_service_push_notify() did decode message
mmsd[2861]: ../src/service.c:mms_service_push_notify() is type NI?
mmsd[2861]: ../src/service.c:mms_service_push_notify() type is NI
mmsd[2861]: MMS transaction id: DLLA03030419223331523203000000000
mmsd[2861]: MMS version: 1.1
mmsd[2861]: From: +1[…]/TYPE=PLMN
mmsd[2861]: Subject:
mmsd[2861]: Class: Personal
mmsd[2861]: Size: 20098
mmsd[2861]: Expiry: 2021-04-22T18:33:33-0400
mmsd[2861]: Location: http://107.125.63.100:8005/Y/0419223331523203000000000
mmsd[2861]: ../src/service.c:mms_service_push_notify() about to store_meta_open 2
mmsd[2861]: ../src/service.c:mms_service_push_notify() did store_meta_open 2
mmsd[2861]: ../src/service.c:mms_service_push_notify() did create_request
mmsd[2861]: ../src/service.c:process_request_queue() location http://107.125.63.100:8005/Y/0419223331523203000000000
mmsd[2861]: ../src/service.c:web_get_cb() status: 200
mmsd[2861]: ../src/service.c:web_get_cb() data size = 20137
mmsd[2861]: ../src/service.c:web_get_cb() request->result_cb=0xaaaaac661694 vs. retrieve_conf=0xaaaaac661694/send_conf=0xaaaaac65e32c/notify_resp=0xaaaaac661510
mmsd[2861]: ../src/store.c:generate_uuid_from_pdu() pdu 0xffffa0edb000 len 20137
mmsd[2861]: ../src/store.c:mms_store_file() pathname /home/purism/.mms/modemmanager/1EA8E994B64C60A5825E18AEE69E100D1F411470
mmsd[2861]: ../src/mmsutil.c:decode_text() val: 12a69e28-0a1c-4943-83ac-a094bc551de4
mmsd[2861]: Terminating
mmsd[2861]: ../src/plugin.c:__mms_plugin_cleanup()
mmsd[2861]: ../src/service.c:mms_service_unregister() service 0xaaaae5e59f30
mmsd[2861]: ../src/service.c:emit_service_removed() service 0xaaaae5e59f30
mmsd[2861]: ../plugins/modemmanager.c:mmsd_plugin_disconnect() Disabling Bearer Handler
mmsd[2861]: ../src/service.c:mms_service_set_bearer_handler() service 0xaaaae5e59f30 handler (nil)
mmsd[2861]: ../src/service.c:__mms_service_cleanup()
mmsd[2861]: Exit
setting proxy proxy.mobile.att.net:80
request https://mmsc.mobile.att.net
address proxy.mobile.att.net
port 80
host mmsc.mobile.att.net
flags 1
content-type application/vnd.wap.mms-message
binding wwan0
using TLS encryption
channel missing
port 80
flags 1
binding wwan0
channel missing
port 80
flags 1
binding wwan0
channel missing
port 80
flags 1
binding wwan0
channel missing
request http://107.125.63.100:8005/Y/0419223331523203000000000
port 80
host 107.125.63.100:8005
flags 0
binding wwan0
no encryption
creating session proxy.mobile.att.net:80
request http://107.125.63.100:8005/Y/0419223331523203000000000 from 107.125.63.100:8005
status 1 bytes to write 154 bytes written 154
bytes read 185
[header] HTTP/1.1 200 OK
[header] Date: Mon, 19 Apr 2021 22:33:35 GMT
[header] Content-Length: 20137
[header] Content-Type: application/vnd.wap.mms-message
[header] Via: 1.1 proxy.mobile (HPM/14.09.0099)
[header] Connection: close
[body] length 0
bytes read 1392
[body] length 1392
bytes read 2047
[body] length 2047
bytes read 737
[body] length 737
bytes read 1392
[body] length 1392
bytes read 1392
[body] length 1392
bytes read 1392
[body] length 1392
bytes read 2047
[body] length 2047
bytes read 2047
[body] length 2047
bytes read 2047
[body] length 2047
bytes read 819
[body] length 819
bytes read 1392
[body] length 1392
bytes read 1392
[body] length 1392
bytes read 2041
[body] length 2041
bytes read 0
port 80
flags 1
binding wwan0
channel missing
Ok, I may see where it is. I will try to make a debug version to try.
By the way, i fyou have matrix, I am also on the comunity/librem-5 channel. That may be easier to find me and work with me.
Ok, here is the debug branch:
Please compile and run it.
As a Heads up, there is an issue with mmsd. The payload does not have expected headers so mmsd errors out.
I need to fix it, and @francepat has been kind enough to help me with it.
EDIT:
@francepat: I think I fixed the issue.
Please test: https://source.puri.sm/kop316/mmsd/-/tree/debug-francepat
and let me know if it worked.
As a note for anyone else, if it works I will merge it, and it is only for specific use cases, so don’t try to compile/use this unless you have a good reason to (like you are francepat, or have the same problems).
