for some reason, i didn’t see the mention of my username until now, sorry.
I just updated to the latest pureboot, and did not have any issues booting.
@MrChromebox has this been addressed?
He has left Purism
Will this be address?
Hi all, I’ll check this out. I’m not aware of any fixes made to root hashing for Qubes OS, so the status is probably the same, but I’ll take a look and see what is needed to get this working. Thanks for bringing it to my attention.
I looked into this - it’s still not working currently with Qubes’ default partitioning (as expected).
The default partition layout puts root on an LVM2 thin-provisioned volume, the LVM2 container is in turn LUKS-encrypted. We need a few things:
- kernel support for LVM2 thin provisioned volumes (trivial)
- LVM2 tooling wants a ‘thin_check’ tool before activating a thin volume, either need to build this and include it or disable the check
- We need scripting to find the correct root volume, probably an initial version could just look for the default name used by Qubes
It’s solvable. I’ll need to look into ‘thin_check’ more, see if any other dependencies are needed, what we lose if we disable it, how big it is, etc.
Got this working for the default Qubes partitioning layout, should work for any combination of LVM/LUKS using the ‘root’ LVM logical volume.
It’s also in the purism_next
branch of PureBoot for the upcoming Release 29.
If you’re comfortable building PureBoot/Heads, you can build from source now to give it a try. (As always, please be aware that the full release tests haven’t been run yet, and have a hardware recovery method if you are building your own firmware.)
I’ll start building release candidates for the next firmware releases next week. Once I’ve done basic testing, I can post them for anyone interested to try.
The first PureBoot 29 release candidate is up including this improvement, details here: PureBoot 29 Release Candidate
