PureOS how-to: System U2F Authentication
This is a guide for setting up system U2F authentication on PureOS. All of the files used for this configuration are stored outside of the home folder, so home folder encryption should be compatible with this approach. While I am using a YubiKey, any U2F-compatible device should do the trick.
Using this configuration, I have been prompted to authenticate with U2F in the following situations:
  • system login
  • unlocking lock screen
  • sudo commands
  • unlocking Settings panels
  • installing software from Software
  • unlocking attached LUKS drives
  • …there are probably other situations I have not run into yet.
Read this in it’s entirety before proceeding, as it is possible to lock yourself out partially or wholly.
1. Update PureOS and install dependencies:
  • sudo apt-get update && sudo apt-get full-upgrade
    • All lines formatted as above are to be entered in the terminal.
  • If updates were installed, reboot before proceeding.
  • sudo apt-get install libpam-u2f scdaemon pamu2fcfg yubikey-manager
    • While I need yubikey-manager, you may need something else if using a different make of U2F device. Refer to the documentation for your device as needed.
Do not proceed until you have these successfully installed.
2. Enable Linux udev rules for U2F devices:
udev is the Linux device manager which handles events when USB devices are added and removed. Custom rules need to be added to properly identify U2F devices and provide applications access. The rules file linked below supports multiple makes and models of U2F devices. If yours is not included in the list, see the device manufacturer about the udev rules needed for U2F.
  • sudo mkdir -p /etc/udev/rules.d/
    • You may get an error that the folder exists. You can safely ignore that error.
  • Open in new window (ctrl+click link): https://raw.githubusercontent.com/Yubico/libu2f-host/master/70-u2f.rules
  • Select all and copy content (ctrl+a, ctrl+c)
  • nano 70-u2f.rules
  • Paste and save (ctrl + shift + v, ctrl + x, y, return)
  • sudo mv 70-u2f.rules /etc/udev/rules.d/
  • sudo udevadm control --reload-rules && sudo udevadm trigger
  • lsusb
If this was successful, you will see something describing your U2F device as an attached device. If you do not, stop here and troubleshoot this issue.
3. Register your U2F device(s):
Here we will tell the system which U2F devices can be used for authentication.
Primary U2F device:
  • Connect U2F device.
  • mkdir u2f
  • pamu2fcfg --origin=pam://localhost > u2f/keys
  • Touch the device when it lights up or you are otherwise prompted.
    • Note that some U2F devices do not require a touch and do not light up.
Backup U2F device(s):
When setting up security like this, it is always a good idea to have at least one backup U2F device that you store somewhere safe – and almost always a bad idea to not have a spare. If you do not have a spare to configure now, you can do so later.
  • Connect backup U2F device.
  • pamu2fcfg -n --origin=pam://localhost >> u2f/keys
  • If needed, touch the device when it lights up or you are otherwise prompted.
  • Repeat for all backup devices.
Move registration to /etc:
  • sudo mv u2f /etc
4. Make U2F an authentication requirement:
As far as I have experienced so far, this method requires U2F for literally every situation in which you must enter your password. It is possible to require it for only certain situations, such as login, sudo, unlocking the screen, etc. See @lipu’s guide and the other sources listed at the bottom of this guide for more information on that approach.
  • sudo nano /etc/pam.d/common-auth
  • Add (or, if adding new keys after initial setup, un-comment) this to the bottom of the file:
    auth required pam_u2f.so cue no detect origin=pam://localhost authfile=/etc/u2f/keys
    • Configuration options from most secure to least:
      • Omit “cue no detect” to prevent prompting of any kind. Incorrect password and absent key failures both appear to be an incorrect password to the user.
      • Leave “cue no detect” in the above line if you want to be prompted to touch the device only when it is present. An absent key appears to be an incorrect password.
      • Omit “no detect” to always be prompted to touch the device, even when the key is not present. Arguably the least secure setup, as it reveals that a second factor exists when a key is absent.
  • Save and exit (ctrl+x, y, return).
  • DO NOT CLOSE TERMINAL WINDOW
5. CRITICAL: Test U2F Authentication:
Without closing current terminal, open a new terminal window.
  • sudo echo success
  • Enter account password, as usual for sudo.
  • If so configured, you will be prompted to touch the device, and the U2F device will then blink (if supported); touch it.
If you are not prompted to touch the device when expected (depends on configuration outlined above), or the device does not blink when expected, your password fails to be accepted, or authentication otherwise fails:
  • Close test terminal window (in which you ran echo), and return to the previous terminal window (in which you edited common-auth).
  • Remove the line you added above:
  • sudo rm -r /etc/u2f
  • Close terminal, and re-read this before trying again. :slight_smile:
If everything was done correctly, you will see “success”.
  • Repeat the test phase for each registered U2F device.
  • You can now safely close terminal and go about your day with the added peace of mind knowing that you have system U2F authentication!
Appendix: Adding additional U2F device(s) later:
  • Comment out (add “#” to front of the line):
  • Begin again at Step 3, above.
Sources & Inspirations:
Updates:
  • Added pam configuration options in section 4 based on an option I learned about.
  • Clarified section on adding additional keys later.
  • De-YubiKey’d the guide; added some notes about other device manufacturers.
  • Changed method of obtaining udev rules from curl to copy, paste, move.
Thanks for making such a good write-up for PurOS!
Glad to, I hope it helps some people :slight_smile:
@mladen
This might be a good addition to the PureOS wiki at https://tracker.pureos.net/w/pureos/tips/
What do you think?
Good idea. We’re currently busy, but we will check out and perhaps add it.
Personally I don’t like the call to curl to download the udev rules file. While the file itself is readable and quickly vetted, I think it is a bad practice to download files and install them with curl, it’s hard to know if they’ll always be at the URI you point to, if they have gone through proper review, or even are not malicious. I note that the file you point to is at GitHub and that it is meant to work with udev > 188. On PureOS I believe the default is to use systemd-udevd and I’ve had issues mixing different udev rules with different udev implementations.
I am happy to rework it to meet the need there. The idea with curl was to minimize clicks, etc. I’m sure I can find an acceptable solution, though.
If we were to create a wiki article for it, we could just get folks to copy and paste the needed udev rule into a new file on their computer. The file linked above does include the rules for a YubiKey, U2F Zero, Nitrokey FIDO U2F, and etc, so theoretically one only needs the rule for the key they have.
I’ll have to test this out with my Solo Key once I have a spare moment or five. Might have to make some changes compared to their udev rules and the ones from Yubico.
Perhaps better to include those rules in the distro?
Setting up U2F is needlessly complicated, which is a shame given how easy it is to use once enabled. So any convenience provided by the distro would be welcome, even if only for people comfortable doing this at the command prompt.
(Ultimately, I would like to see 2FA directly supported in Gnome Settings!)
As for avoiding curl, it should be a simple change to downloading the file, then moving it. Or creating an empty file with the appropriate name, and pasting in what we need.
As for the source of this file, it is the one provided by Yubico directly – this is the same file linked from their own help documents.
I put this guide together after working through the process myself, using Lipu’s guide, among other resources, to get it working properly on PureOS. After putting the guide together I happened to encounter a need to reinstall my OS, which presented a wonderful opportunity to put this guide to the test. I can say that following it as written, you can get U2F set up within 5 minutes, provided you are comfortable. An inexperienced user probobly would not take all that much longer with it.
We’re doing work packaging udev rules: https://tracker.pureos.net/T694 While we’re currently focused on the Librem Key, the udev rules should work for any key. I’m having issues with udev on local systems and don’t have the spare cycles to work on this at the moment, but hope to invest some time in it in the near future.
This would be a great addition, as would adding something in GNOME settings, as lipu suggested, to facilitate U2F setup. If libpam-u2f, scdaemon, pamu2fcfg, yubikey-manager, and/or any other dependency could be included at install, or automatically installed when needed based on the token model (along the lines with how printers are added) when enabling U2F, it would make this kind of security extremely accessible to average bears.
Just imagine a nice little “Two-Factor Authentication” or “U2F” button there somewhere around the password field.
I updated the guide to de-Yubi things, changed the method of obtaining the udev rules, and added some notes about other manufacturers.
Hello everybody, with a bit of tinkering, I was able to get the multi-factor authentication running. Of course, being a OS level program, the OS is taking care of multi-factor authentication. It would be interesting if the security measure can be done on the hardware-based firmware/interface, disk encryption, and disk-based GNU Grub bootloader level. Of course, I might be asking for too much since access to files is required after an unforeseen unloggable error occurs. Close call scenario! Some crashable programs need to be researched and reconsidered before use. I’m looking at (more like pointing fingers and accusing) Simple Screen Recorder! Although, I should have at least remove the program while it looked like it was bugging out.
Anyways, things are moving along, more or less.
The only remaining afterthought is a question left.
I see multiple pages regarding multi-factor authentication. Some of them mentioned two authentication mechanism modes. Those modes are either ‘client’ or ‘challenge-response’ value. According to these pages, the client mode value sends a client request to the multi-factor authentication server(s) for verification and requires pressing the key of the multi-factor authentication device; Internet connection is required for client mode. The challenge-response mode value sends a user request to the multi-factor authenticated operating system for verification and does not allow pressing the key of the multi-factor authentication device; Internet connection is not for challenge-response mode. Given the facts, the client mode value would appear to be the most secure option. I would usually opt for the client mode value, but I also consider situations without Internet connectivity.
This forum topic did not mention the multi-factor authentication mechanism modes, but the pages that I scoured through imply that the client mode value is the default multi-factor authentication mechanism mode value. Challenge-response mode value requires manual configuration. Can you confirm this assumption?
Here are the reference material.
https://adl1995.github.io/passwordless-logins-with-yubikey.html
https://www.redhat.com/sysadmin/mfa-linux
A bit off-topic. A encrypted disk is still at risk from UEFI’s automated external device boot execution acting as OS installers or live OS environments/operations. With live OS environments/operations, one can access the encrypted disk after bypassing disk-based security measures. I would rather prevent such devices to interfere with the hardware-based firmware/interface in the first place. I recommend to apply at least a firmware-based administration passphrase prompt along with setting the UEFI boot sequence to Legacy boot option with all external device check flags unchecked, leaving the internal disk drive check flag checked. If you only have Legacy boot sequence, just uncheck all device check flags. The next computer boot with set the automatic boot sequence to an invalid legacy device error message. The situation would now require manual boot sequence with the unchecked devices, initiating the firmware-based administration passphrase prompt. Until then, we be waiting for the study/possibility of multi-factor authentication for hardware-based firmware/interface, disk encryption, and disk-based GNU Grub bootloader level.
I hope I don’t overwhelm readers with such overflow. Keeping on track is key to security’s progress.
Here is the reference material for UEFI-induced vulnerability.
https://www.gnu.org/proprietary/proprietary-insecurity.html#uefi-rootkit
Does the multi-factor authentication work for USB-C devices to pair with Librem 5 (USA) smartphones? I hope the hardware and software can handle such device types. There is other questions for the phone (such as internet connection), but that would be for another topic.
Then again, the external USB-C device hub can help with data, inlet, and outlet port transmission. Yeah, let’s stick with that until we need a straight up USB-C device connection.
I don’t know what’s happening, but I assume that one of the PAM software updates is rendering the OS on Librem 5 (USA) as inoperable. DE session shuts down. its own operation as obsolete. Even a fresh OS installation with another PAM try is not working. At the very least, I get to use the OS again. The bad news is what now seems like a lack of PAM support (it’s there, but the keys are not being read). Maybe it has to do something about /etc/pam.d/common-auth and its pam-auth-update recommendation? It’s almost like GNU GRUB. Nevertheless, I will begin researching for any changes with the software in question. In addition, I might shall not make a move towards OpenPAM. OpenPAM sounds like something libre, but is in fact, not. Usually, we take notes about its BSD tendencies, but we can also see that McAfee is its current developer. No progress has been made, especially since its company’s business model is likely licensing agreements. I don’t think I would want to risk such exposure.
As for waiting for updates, maybe it’s just a lack of support for the smartphone (and it’s true that smartphones are not exactly Linux GNU/Linux priority), but I would still prefer a transitional alert before these updates. That way, I could prepare for the worst to come.
EDIT (Apr 11, 2025):
Looks like I don’t have to fret after all (or anymore).
It appears that one of the cited references have a certain page to look up to.
This page looks quite dated, but it is nevertheless solid and simple (enough) for basic users. I couldn’t think otherwise. There is a mention of local/offline verification, but I am not complaining about a working solution, even if there was online verification. At least it’s something than nothing.
