Because there’s no reason to deviate from Debian. Disabling them would only save a tiny bit of disk space, nothing more.
I started feeling sad because no gdawn yet. = (
Branch TinyGL support special OpenGL3.0.
However i would like a native TinyGL for Librem 5, featuring GPLv4 and first GPLv4 program born on Librem 5 ![]()
On new GPLv4 License the Ethical-is-Mandatory, for Real Freedom for Real Gnu System.
GPLv4 full blocking blobs-handshakes-omnidirectional. [CERRADO] OSI Licenses is gone as well.
More things I love about dawn,
- Caffeine mode in phosh - super useful when I have to tether data via usb cable (earlier I had to go through so many screens to disable automatic suspend and later remember to turn it on after I disconnect).
- FreeTube keyboard opens up without manually long pressing
- I can finally type in Malayalam to find contacts saved in Malayalam (this is coming from phosh-osk-stub) - big boost for people not using latin scripts like Arabic, Chinese or Japanese (though more languages support would need even newer phosh-osk-stevia). Without this, I had to scroll down a long address book to find those contacts, which was very annoying. Now I have both transliteration (type in English and choose the Malayalam word from suggestions) and native Malayalam keyboard.
- Newer backports like dino from trixie-backports (hopefully gajim 2.6 gets there too soon) or even https://packages.fastforward.debian.net/ (for people use an external screen and use it a desktop at this point - recent gimp, inkscape, scribus etc @galilley this could an option to update packages, you could talk to its maintainer and see if they are interested to have mobile software like phosh there - I already mentioned it here I Challenge Thee)
Things I had to do manually, switch to phosh-osk-stub, without this I can’t enter UPI ID in *99# USSD payments - squeekboard just shows numbers only keyboard. Also Malayalam typing is thanks to this change.
Im losing hope of getting Gdawn. I dont see any obsession to-get Gdawn out… ![]()
I’m waiting for new monthly Purism Report about it! On milestone it’s still at 0%.. ![]()
I smell opensource for very long time. I am sure that is the cause.
I know i know i being quite aggressive in my criticism for opensource, but i tired and i dont want to be dependent on a vendor via opensource. Either a slave from vendor thanks to opensource-vendor-propietary-enablements. Either i will want that opensource will be the unique option for a systems.
Opensource just copy which already exist which shutdown human-emotion-engines.
Phosh as a tiny example is a copy from Android and iOS which do not make any real emotion. IMHO. On Phosh you may see more than 4 bars on a app running… bar is obsolete even for desktop. Bar has not made for Mobile, it was forced for no reason.
I agree that Opensource most to exist but very far from real freesoftware, real _gnu_system.
Mixing make conflicts.
I happy if a user want to be opensource and slaved and most be used from vendors, but outside real freesoftware world. I am not delirious.
I would like that any real freesoftware program do not depend on java on anything…plus a sized universal fsf button to prioritize [ the source code available ] on one click, not 2 clickes.
No scroll to get the delicious [ the source code available ] as is on front on you and shining..
If you go to firefox.com, it seem that source code do not exist, just binary exist at the first and ugly place. It looks like firefox is using Neuroscience to guide you for a evil trail.
TinyGL in the sense for few but real free software driver…like etnaviv, lima.
So panfrost, v3d, freedreno, pvr just cannot enter to the prestigious place GPLv4 of TinyGL.
TinyGL Engineered for Mobile born-in-Librem5. True FreeSoftware mobile drivers.
I also want: Coherence to reinforce the Ethical into GPLv4.
At first glance, it might seem like GPLv4 is Less Libre , but thats not true; it simply it requires more time for your brain to process GPLv4, until GPLv4 sent to you back the ACK. ![]()
I told you that I am stricter than RMS.
Another thing I noticed today is that, it now correctly unlocks the login keyring after login so I don’t have to unlock it manually by entering the password again after every login/reboot.
unl0kr in dawn now provides compatibility symlink for osk-sdl, so upgrade from crimson to dawn should now work without a manual edit to /etc/crypttab.
So apt dist-upgrade from crimson should get you to dawn now!
…which is of little use as it’s still not ready to be used and it’s still not helpful to report any issues with it.
Now mmdebstrap can create a dawn chroot from debian sid (for example to build a package targeting dawn) $ sudo mmdebstrap --arch arm64 dawn dawn http://repo.pureos.net/pureos
This was not working with crimson when I tried last time. I want to try switching to pipewire Echo cancellation with pipewire (for dawn) - need testers and first step would be rebuilding librem5-base package to allow using pipewire instead of pulseaudio.
I would like:
Gnu Dawn is a Libre and Liebre gnu-mobile system engineered for gL5 ![]()
GNU Savannah
GNU Baobab
Though minimum version specified in Breaks+Replaces is not enough to actually replace osk-sdl, so need to manually remove osk-sdl once apt dist-upgrade command fails (but we don’t need to edit /etc/crypttab anymore). Breaks+Replaces in unl0kr is does not actually replace osk-sdl (#139) · Issues · PureOS / Tasking · GitLab
