Ah, you’re right. I might be a little sleepy… I fixed my example.
Anyway, punctuation keys will get a special function later (end prediction), so there’s more potentially breaking changes in the future. I’ll try to make them as easy as possible.
Should we remove all this then?
period:
outline: "default"
label: "."
colon:
label: ":"
keysym: "quotedbl"
Thanks.
Not quite, outlines are still useful (except maybe the default one). So in this case, yeah.
I just started with the changes on the German and Japanese layout. But there are some questions remaining for me:
How do you intend to handle “BackSpace” and “Return”. If I understand #153 correctly, you have to use the “keysym” property with those (because they are just buttons using xkb keycode names - and that’s deprecated in the future). So should it be something like the following?
BackSpace:
outline: "altline"
icon: "edit-clear-symbolic"
keysym: "0xff08"
Return:
outline: "altline"
icon: "key-enter"
keysym: "0xff0d"
Or should we use f.ex. keysym: "BackSpace"? Both seem to be OK ATM.
And what about space:
space:
outline: "spaceline"
label: " "
Shouldn’t we use the “keysym” property here as well?
No, I think I didn’t explain that well enough. Does my comment make it clearer? Treating button names as xkb codes is confusing (#153) · Issues · Librem5 / squeekboard · GitLab
Yes.
Yeah, and that reminds me I should roll out the “text” property soon…
Anyone willing to update the Russian layout? https://source.puri.sm/Librem5/squeekboard/merge_requests/220
I still intend to update this and resubmit it. I had trouble with the emulator and haven’t been able to get back to this yet. I have some time now though so I will try to work on it this week.
Related: Unicode version 13 is set to be released on March 10. “Unicode 13.0 adds 5,930 characters, for a total of 143,859 characters. These additions include 4 new scripts, for a total of 154 scripts, as well as 55 new emoji characters.” Didn’t know it was that much. It includes support for a lot of of (also new-old) languages, in addition to all the emojis.
Is/will it be fully supported on keyboards?
The keyboard doesn’t care about Unicode versions. It will dutifully forward whatever layout creators put in layouts to the input system, and to the font renderer. I don’t expect any difficulties with Unicode extensions over the next 20 years as long as system fonts keep up.
I like your confidence in stable IT
Is there anyone who wants to write or take over the French layout? https://source.puri.sm/Librem5/squeekboard/merge_requests/235
I have tried Hebrew and cyrilic alphabets on Librem before December both works ok as far as I remember, a Debian support is good for many language I am sure same applies to PureOS.
Edit,: French layout was also ok.
Regards, Alex
By the way, there’s currently no way to enter Cyryllic or Hebrew on the Librem 5 keyboard. Please contribute if you write in languages using those!
Just ignore the person that you think has been offensive with you, a forum is more than a single user, you can still helping the community.
I may be able to do the wide version for the Spanish layout, ill have a look to the repo this night because I’ve been away for a while and I don’t know the current status of the layouts.
Hi, after a while I’m trying to upload the Spanish layout again including the new Terminal layouts, but I not sure about something, in /data/langs/es-ES.txt what we need to add? all the layout codes with their Spanish translations or just the keyboard name?
All the codes – but the translations from this file are only used for the cases when gnome-desktop doesn’t provide them, so I think it’s safe to skip.
