Indeed, a rescan of available APs makes the L5 switch to the one with the strongest signal. wpa_supplicant
has a bgscan
option where you can indicate at what signal level to initiate regular automatic scans. From the wpa_supplicant(5)
sample configuration:
# bgscan: Background scanning
# wpa_supplicant behavior for background scanning can be specified by
# configuring a bgscan module. These modules are responsible for requesting
# background scans for the purpose of roaming within an ESS (i.e., within a
# single network block with all the APs using the same SSID). The bgscan
# parameter uses following format: "<bgscan module name>:<module parameters>"
# Following bgscan modules are available:
# simple - Periodic background scans based on signal strength
# send_btm_query > 0 means do this many BTM queries before attempting a scan.
# bgscan="simple:<short bgscan interval in seconds>:<signal strength threshold>:
# <long interval>[:<send_btm_query>]"
# bgscan="simple:30:-45:300"
# bgscan="simple:30:-45:300:3"
# learn - Learn channels used by the network and try to avoid bgscans on other
# channels (experimental)
# bgscan="learn:<short bgscan interval in seconds>:<signal strength threshold>:
# <long interval>[:<database file name>]"
# bgscan="learn:30:-45:300:/etc/wpa_supplicant/network1.bgscan"
# Explicitly disable bgscan by setting
# bgscan=""
# This option can also be set outside of all network blocks for the bgscan
# parameter to apply for all the networks that have no specific bgscan
# parameter.
802.11r Fast Transition helps with seamless transition from AP to AP. If your setup supports it, you can enable it in wpa_supplicant
also, e.g. by setting FT-SAE
instead of just SAE
(WPA3):
# key_mgmt: list of accepted authenticated key management protocols
# WPA-PSK = WPA pre-shared key (this requires 'psk' field)
# WPA-EAP = WPA using EAP authentication
# IEEE8021X = IEEE 802.1X using EAP authentication and (optionally) dynamically
# generated WEP keys
# NONE = WPA is not used; plaintext or static WEP could be used
# WPA-NONE = WPA-None for IBSS (deprecated; use proto=RSN key_mgmt=WPA-PSK
# instead)
# FT-PSK = Fast BSS Transition (IEEE 802.11r) with pre-shared key
# FT-EAP = Fast BSS Transition (IEEE 802.11r) with EAP authentication
# FT-EAP-SHA384 = Fast BSS Transition (IEEE 802.11r) with EAP authentication
# and using SHA384
# WPA-PSK-SHA256 = Like WPA-PSK but using stronger SHA256-based algorithms
# WPA-EAP-SHA256 = Like WPA-EAP but using stronger SHA256-based algorithms
# SAE = Simultaneous authentication of equals; pre-shared key/password -based
# authentication with stronger security than WPA-PSK especially when using
# not that strong password; a.k.a. WPA3-Personal
# FT-SAE = SAE with FT
# WPA-EAP-SUITE-B = Suite B 128-bit level
# WPA-EAP-SUITE-B-192 = Suite B 192-bit level
# OSEN = Hotspot 2.0 Rel 2 online signup connection
# FILS-SHA256 = Fast Initial Link Setup with SHA256
# FILS-SHA384 = Fast Initial Link Setup with SHA384
# FT-FILS-SHA256 = FT and Fast Initial Link Setup with SHA256
# FT-FILS-SHA384 = FT and Fast Initial Link Setup with SHA384
# OWE = Opportunistic Wireless Encryption (a.k.a. Enhanced Open)
# DPP = Device Provisioning Protocol
# If not set, this defaults to: WPA-PSK WPA-EAP
Next problem: L5 uses NetworkManager and not wpa_supplicant
directly, so how to do all this with NetworkManager?
