Wifi and Bluetooth Have Never Worked
I think that means … repeat until something does happen.
Will this problem persist or is it prone to fixing some time soon?
I have some ideas on what could be tried to fix this (or at least make it less likely to happen), but we’ll see.
So I managed to flash different OSes (Mobian, PostmarketOS) with different Desktop Environments but the problem is persistant in all of those. I have too little technical knowledge as to if a DE makes any difference (KDE for example) but in my case, after updating the OS once, wifi and bluetooth can never be enabled. No matter how often I reboot or switch on or off the kill switches. Somehow the orientation button is activated when I slide some of the switches, which is very odd.
