No worries yet, Quarnero. I just haven’t got around to it yet. I will surely let you all know how it turns out.
It looks like it was not able to find the driver it was looking for:
root@ralf-macbookpro11:/home/ralf# apt-get install firmware-misc-nonfree
Reading package lists… Done
Building dependency tree… Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 124 not upgraded.
Need to get 8,953 kB of archives.
After this operation, 36.5 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bullseye/non-free amd64 firmware-misc-nonfree all 20210315-3 [8,953 kB]
Fetched 8,953 kB in 14s (643 kB/s)
Selecting previously unselected package firmware-misc-nonfree.
(Reading database … 143149 files and directories currently installed.)
Preparing to unpack …/firmware-misc-nonfree_20210315-3_all.deb …
Unpacking firmware-misc-nonfree (20210315-3) …
Setting up firmware-misc-nonfree (20210315-3) …
Processing triggers for initramfs-tools (0.132pureos1) …
update-initramfs: Generating /boot/initrd.img-5.10.0-8-amd64
root@ralf-macbookpro11:/home/ralf# apt-get install isenkram-cli
isenkram-cli is already the newest version (0.48).
0 upgraded, 0 newly installed, 0 to remove and 124 not upgraded.
root@ralf-macbookpro11:/home/ralf# isenkram-autoinstall-firmware
info: looking for firmware file b43/ucode29_mimo.fw requested by kernel
info: looking for firmware file b43-open/ucode29_mimo.fw requested by kernel
info: some kernel driver requested extra firmware files: b43/ucode11.fw b43/ucode13.fw b43/ucode14.fw b43/ucode15.fw b43/ucode16_lp.fw b43/ucode16_mimo.fw b43/ucode24_lcn.fw b43/ucode25_lcn.fw b43/ucode25_mimo.fw b43/ucode26_mimo.fw b43/ucode29_mimo.fw b43/ucode30_mimo.fw b43/ucode33_lcn40.fw b43/ucode40.fw b43/ucode42.fw b43/ucode5.fw b43/ucode9.fw intel/ibt-11-5.ddc intel/ibt-11-5.sfi intel/ibt-12-16.ddc intel/ibt-12-16.sfi renesas_usb_fw.mem rtl_bt/rtl8723a_fw.bin rtl_bt/rtl8723b_config.bin rtl_bt/rtl8723b_fw.bin rtl_bt/rtl8723bs_config.bin rtl_bt/rtl8723bs_fw.bin rtl_bt/rtl8723ds_config.bin rtl_bt/rtl8723ds_fw.bin rtl_bt/rtl8761a_config.bin rtl_bt/rtl8761a_fw.bin rtl_bt/rtl8821a_config.bin rtl_bt/rtl8821a_fw.bin rtl_bt/rtl8822b_config.bin rtl_bt/rtl8822b_fw.bin b43/ucode29_mimo.fw b43/ucode29_mimo.fw b43-open/ucode29_mimo.fw b43-open/ucode29_mimo.fw
info: unable to find any local firmware info for dist byzantium, using info for sid
info: locating packages with the requested firmware files
info: determining whether enabling other components is required
info: Updating APT sources after adding non-free APT source
E: The repository ‘http://deb.debian.org/debian byzantium Release’ does not have a Release file.
info: trying to install firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer firmware-b43-installer
E: Unable to locate package firmware-b43-installer
firmware-b43-installer package is in contrib repository (I wasn’t aware of this, sorry) so please add contrib to your sources.list, beside bullseye main and non-free.
Now you should proceed with (while rest is looking like very good job of yours):
- get root by
sudo su - add to the
/etc/apt/sources.list:deb https://ftp.debian.org/debian/ bullseye main contrib non-free - execute
apt-get update - execute
apt-get install firmware-b43-installer - execute
isenkram-autoinstall-firmware -
exitto exit root. -
remove bullseye entry from
/etc/apt/sources.listor mark it to something like this:##deb https:// …, save/exit .
Let us know if anything else needed.
I see also this. There is no byzantium in Debian. The corresponding entry in sources list needs to be corrected to point to pureos site, or removed.
The wifi is working now. Thank you so much Quarnero and Dwaff.
Hi guys,
Thanks for this awesome thread. I have the same issue with an old Macbook Pro and PureOS 10. My broadcom network controller is BCM43602 … (rev 01). I followed the steps as described until this point and I experience two issues.
First, regarding the sources.list:
I get the same error as Ralf, but I don’t have this source in my sources list:
E: The repository ‘Index of /debian byzantium Release’ does not have a Release file.
Nevertheless I was able to download and update the firmware installer
firmware-b43-installer is already the newest version (1:019.7)
When I run isenkram-autoinstall-firmware It says
info: No new firmware package with requested firmware detected
Hence, when I open wifi settings it still says “no wifi adapter found”
Any ideas on how I can get my wifi adapter up and running?
Thanks,
D
Debian maintainers have another one ready for your particular Wi-Fi hardware (looks like it should help): brcmfmac - Debian Wiki. Please proceed with here mentioned BCM43602 [non-free] link like this:
sudo su
apt-get purge firmware-b43-installer
apt clean
apt update
apt search firmware-brcm80211
apt-get install firmware-brcm80211
apt-get autoclean
exit −− please close other open programs as well
sudo reboot
After your PureOS comes back please remove bullseye entry from /etc/apt/sources.list, connect your Wi-Fi … and execute: sudo time apt update to see if everything works.
EDIT (to explain): Actually: firmware-b43-installer was in contrib repo from … (therefore added) and in your case: firmware-brcm80211 package lies available within non-free repo from same …, yet to be consistent with main role of isenkram-autoinstall-firmware command please execute it before and without: apt-get install firmware-brcm80211 as isenkram-autoinstall-firmware command should pull this (or any other firmware) package by itself, I think. I’m just trying to avoid any sort of unnecessary confusion, make clear on why isenkram-autoinstall-firmware command is important by itself.
Thank you @Quarnero. I followed the step but it still says
Info: no new firmware package with requested firmware detected
How could I check which firmware is being used?
Update:
I also installed the b43legacy-installer (from debian 9 stretch as mentioned here) but with the same result: no new firmware package detected.
Update 2: Wifi now works
→ I used the command you edited out, rebooted and now I have a wifi adapter & wifi connection.
Thanks for your help @Quarnero ![]()
For anyone finding this thread because they searched for the libc6-dev, libgcc-8-dev, gsettings-desktop-schemas, mutter, upgrade errors: the solution can be found here Upgrade to Byzantium
