If possible, I’d like to have a sort of “once and for all” statement about the best practices with installing third-party software. I’ll start by making all kinds of claims based on my current (flimsy) understanding. Hopefully that will inspire internet hate to tell me how stupid I am, until I have corrected my wrong ideas.
If no such “once and for all” guide to installation is possible, well that will be instructive in its own way.
A little background in case it’s helpful to see where I’m coming from:
I have been using Linux for a few years now, initially Ubuntu, then Mint, now PureOS. That sequence probably already tells you I don’t know a whole lot still. I’ve installed various software in various ways, usually by googling “how do you install R on linux” and following whatever results at the top of the search page. This has gotten me into some pretty knotted problems because the instructions were out of date or just plain bad. Sometimes instructions tell you to use a package manager, sometimes they instruct you to install from binaries, sometimes from source code. Sometimes the package manager only gives you out of date versions of the software that you want. Recently I experienced the issue that Java’s JDK is a little TOO new and by trying to run the most recent version of it, it caused Eclipse to stop working. Sometimes one installation method does something “weird” and when you get errors and ask people what’s happening on StackExchange you get a “Sorry, can’t understand what your computer is doing, your installation is weird” even when it was the officially recommended installation method. (I had and frequently have this problem with installations of LaTeX and related IDEs.)
Just hours ago I got my Librem 15 in the mail and have been toying with it, and I at least know that sudo apt update works as expected (although with just a single repo, which was a bit of a surprise). So I’m guessing if I want to install software that can’t be found in the software manager, it’s going to go a lot like it did on Ubuntu.
But in order to not make the same mistakes I’ve made before, I wanted to ask if there is a standard protocol for installing third-party software.
The package manager?
Should you always try to find a repo and let the package manager handle the rest? How do you know which repo to use? What do you do if the repo/package manager gives you outdated software–do you only then go look for an alternate installation method? You can always easily uninstall software that you installed from a package manager. Although I think in some cases like Java’s JDK, it leaves files and folders behind from the install, and if you try to re-install by a different process, this can cause conflicts. If you know which folders and files should be deleted you can do it yourself, but if you don’t know exactly what you’re doing, this sounds dangerous.
Although I often get the advice to just install from the package manager unless there is some overriding reason not to, I notice that the versions from package managers are almost always very much earlier than the versions that are available directly from the third-party’s website. I don’t need bleeding edge software, but this causes issues enough times that I no longer default to the package manager because it seems to avoid me having to deal with this down the road. Also in the case of texlive, I ran into issues when trying to install extra class files. It seems the issues were caused by the package manager’s method of installation.
Binaries
My understanding is that binary files are basically machine language files, meaning you can’t read them but your computer can. It also means that the binaries for a Windows machine won’t necessarily run on a Linux. But unlike source files, if you find the binaries that are right for you, you can install them more easily. I am not fully clear on how you install them. I think for some of them you can just download and click the downloaded file, it’ll pop up an install wizard, and walk you through the installation. For others, you may need to pop open a terminal and run sudo dpkg -i <filename> if it’s a .deb file. For others they come with configuration and installation files which you run with sudo ./<filename>. I may have some of this confused, so any clarification would be appreciated.
If you are installing certain software for development purposes, like the Java JDK or Python, you need this to be able to run commands from the terminal, and that means you need your terminal to know where to find them when you enter those commands. So for software like these, after installation you also need to find where your computer’s PATH variable is stored (I think the .bashrc file at the user’s home directory) and edit that file.
Source files
Source files are smaller and more human-readable than binaries, but when you download them you then have to build the software yourself. That means you need to have the compiler installed which will do the building, and different source files require different compilers. Then there’s the issue of dependencies, so this can be a much more difficult installation method for someone who doesn’t know what they’re doing. But if they come with a Makefile file, then if you have the compiler and all dependencies, you can run sudo make -f Makefile.
A test case
So let’s think about how someone following best practices would install some specific softwares. For selfish reasons, let’s suppose those softwares are:
- Java JDK
Just from experience I know that installing open-jdk through a repo actually seems to work better because versions that are too new can break Eclipse. - Anaconda
Go to the site, download and install from binaries or source files. - Eclipse
Go to the site, download and install from binaries or source files. - R and RStudio
R can install pretty easily from a repo for “base-r” but RStudio I still haven’t had a lot of success with–whenever it upgrades, something seems to break. - LaTeX and some kind of LaTeX editor like Atom
Installing from the repo for texlive works until you need to install new class files. Then I think to correct whatever that doesn’t do correctly you have to build your own directory tree and put the class files in there. - OCaml
I think for this it’s best to use the package manager to install another package manager! You install OPAM and then OPAM will install OCaml. Sheesh. - Chrome
From a repo seems fine. - Vim
Repo. - Sage
I still haven’t figured out how to have both Anaconda and Sage installed on the same machine as they seem to have some kind of naming conflict. I don’t understand how to resolve that conflict so for now I’ve kind of just given up on trying to have both. - TeamViewer
There is no repo so you have to install from a binary or source file.
