Hi,
I use cacert for some personal services, and need to add its root to the system store.
This is because the online accounts
section fails to add a nextcloud account, I presume because the certificate root is unknown. The error message is very generic, hence presume.
Where should I put it?
Thanks.
Since PureOS is based on Debian, perhaps this answer for Debian is applicable: https://askubuntu.com/a/1007236
Note that I haven’t tried it, just throwing this out there in case it is useful.
ah, I forgot the update-ca-certificates
command. It worked.
nextcloud however still won’t connect , the Librem (and only the Librem) fails with a TLS handshake failure.
The only suggestions I can think of are updating the L5 and making sure the time on the L5 is correct. Other than that, I don’t know.
