I’m a mediocre Linux user. Recently ran a upgrade through the GUI gnome updater on my Librem 15v4. Now I’m stuck in it prompting the initial setup and I can’t get it to load my primary user account. How can I fix this? Thanks
Bump. Anyone?
thanks
If you haven’t already, you should email support@puri.sm for any kind of tech support, although someone here might be able to chime in with some ideas.
When you say “initial setup,” do you mean it’s behaving as if it’s a fresh installation?
Yes, that’s correct, where you first connect to wifi, create a user account, etc. My original user account and files are still in tact, but for some reason after the update, it has borked my user login
