And again Librem 14 is not charging
So I’ve been through this before. But today it hit me again, my Librem 14 is not charging anymore.
Charge sits at 53%, charger is active and shows as online.
/sys/class/power_supply/BAT0/charge_control_start_threshold 70
/sys/class/power_supply/BAT0/charge_control_end_threshold 95
So, what’s going on?
-H
Mine does the thing same thing, it will sit at whatever percentage it was at when I plug in the charger if it’s in between the low limit and the high limit. But if I unplug it and let it drop below the low limit it will then charge all the way up to 100% if I allow it, regardless of what the upper limit is.
Well,
if you see my post, the charge level (53%) is below start threshold (70). So it is wrong.
But I got it to work.
I changed the start level to 40 and then back to 90. After two minutes it started charging.
I have no idea why it was not picking up the start threshold before.
-H
