Anyone manage to get Librem tunnel to work in Gentoo?
I’ve been going into installing the tunnel blind since there isn’t any relevant documentation for Gentoo as far as what packages are required. I’ve tried to find the corresponding packages in Gentoo that are required in distros such as Debian, but I’m sure I’ve missed a couple. Such as python3-vev, libcairo2-dev and libgirepository1.0-dev. I did get pip to install as well as gobject-introspection and pygintrospection.
I was able to install liberty, and was even able to put in my librem-one username and password. However, I’ve run into a roadblock. This is the error is spits out:
Something went wrong when connecting to https://librem.one/api/v1/user/tunnel_account
Problem details: Internal Server Error
Does anyone have any ideas as to what may be the problem?
@hoxaen in case you still have this issue try runnig liberty tunnel-setup again but in the username use only: username and not username@librem.one
Thanks for always helping me out! Indeed I was accidentally using my username with the @librem.one which was causing the problem.
