I’m not on PureOS either, on Arch Linux but I’ve adapted some AppArmor profiles for firefox and chromium, I can share them here… hopefully not breaking any rules.
They may have to be modified a bit to work on your distribution, you just need to be familiar with the file system and be able to read the profile a bit. If it is not working you can set the profile to complain
# aa-complain <profile>
Then when you run the application it will run without the AppArmor protection and any permissions that are missing or errors that are created will show up in your audit log at /var/log/audit/
You just check the log and append the appropriate permissions to the profile in order to fix whatever was missing. I pulled a profile for firefox from Ubuntu, modified it to run on Arch Linux, and added some permissions to allow U2F functionality.
The profile is here:
# vim:syntax=apparmor
# Author: Jamie Strandboge <jamie@canonical.com>
# Declare an apparmor variable to help with overrides
@{MOZ_LIBDIR}=/usr/lib/firefox
#include <tunables/global>
# We want to confine the binaries that match:
# /usr/lib/firefox/firefox
# but not:
# /usr/lib/firefox/firefox.sh
/usr/lib/firefox/firefox {
#include <abstractions/audio>
#include <abstractions/cups-client>
#include <abstractions/dbus-strict>
#include <abstractions/dbus-session-strict>
#include <abstractions/dconf>
#include <abstractions/gnome>
#include <abstractions/ibus>
#include <abstractions/nameservice>
#include <abstractions/openssl>
#include <abstractions/p11-kit>
#include <abstractions/ubuntu-unity7-base>
#include <abstractions/ubuntu-unity7-launcher>
#include <abstractions/dbus-accessibility-strict>
dbus (send)
bus=session
peer=(name=org.a11y.Bus),
dbus (receive)
bus=session
interface=org.a11y.atspi**,
dbus (receive, send)
bus=accessibility,
# for networking
network inet stream,
network inet6 stream,
@{PROC}/[0-9]*/net/arp r,
@{PROC}/[0-9]*/net/if_inet6 r,
@{PROC}/[0-9]*/net/ipv6_route r,
@{PROC}/[0-9]*/net/dev r,
@{PROC}/[0-9]*/net/wireless r,
## Different location on Arch
#dbus (send)
# bus=system
# path=/org/freedesktop/NetworkManager
# member=state,
#dbus (receive)
# bus=system
# path=/org/freedesktop/NetworkManager,
# should maybe be in abstractions
/etc/ r,
/etc/mime.types r,
/etc/mailcap r,
/etc/xdg/*buntu/applications/defaults.list r, # for all derivatives
#/etc/xfce4/defaults.list r,
/usr/share/xubuntu/applications/defaults.list r,
owner @{HOME}/.local/share/applications/defaults.list r,
owner @{HOME}/.local/share/applications/mimeapps.list r,
owner @{HOME}/.local/share/applications/mimeinfo.cache r,
## Not present
#/var/lib/snapd/desktop/applications/mimeinfo.cache r,
#/var/lib/snapd/desktop/applications/*.desktop r,
owner /tmp/** m,
owner /var/tmp/** m,
owner /{,var/}run/shm/shmfd-* rw,
owner /{dev,run}/shm/org.{chromium,mozilla}.* rwk,
/tmp/.X[0-9]*-lock r,
/etc/udev/udev.conf r,
# Doesn't seem to be required, but noisy. Maybe allow 'r' for 'b*' if needed.
# Possibly move to an abstraction if anything else needs it.
# let the shell know we launched something
dbus (send)
bus=session
interface=org.gtk.gio.DesktopAppInfo
member=Launched,
/etc/localtime r,
/etc/ca-certificates/trust-source/ r,
/etc/ca-certificates/trust-source/anchors/ r,
/etc/ca-certificates/trust-source/blacklist/ r,
## Not present
#/etc/wildmidi/wildmidi.cfg r,
## firefox specific if present
#/etc/firefox*/ r,
#/etc/firefox*/** r,
#/etc/xul-ext/** r,
#/etc/xulrunner-2.0*/ r,
#/etc/xulrunner-2.0*/** r,
#/etc/gre.d/ r,
#/etc/gre.d/* r,
# noisy
deny @{MOZ_LIBDIR}/** w,
deny /usr/lib/firefox-addons/** w,
deny /usr/lib/xulrunner-addons/** w,
deny /usr/lib/xulrunner-*/components/*.tmp w,
deny /.suspended r,
deny /boot/initrd.img* r,
deny /boot/vmlinuz* r,
deny /var/cache/fontconfig/ w,
deny @{HOME}/.local/share/recently-used.xbel r,
# TODO: investigate
deny /usr/bin/gconftool-2 x,
# These are needed when a new user starts firefox and firefox.sh is used
@{MOZ_LIBDIR}/** ixr,
/usr/bin/basename ixr,
/usr/bin/dirname ixr,
/usr/bin/pwd ixr,
/sbin/killall5 ixr,
/bin/which ixr,
/usr/bin/tr ixr,
@{PROC}/ r,
@{PROC}/[0-9]*/cmdline r,
@{PROC}/[0-9]*/mountinfo r,
@{PROC}/[0-9]*/stat r,
owner @{PROC}/[0-9]*/task/[0-9]*/stat r,
@{PROC}/[0-9]*/status r,
@{PROC}/filesystems r,
@{PROC}/sys/vm/overcommit_memory r,
/sys/devices/pci[0-9]*/**/uevent r,
/sys/devices/platform/**/uevent r,
/sys/devices/pci*/**/{busnum,idVendor,idProduct} r,
/sys/devices/pci*/**/{,subsystem_}device r,
/sys/devices/pci*/**/{,subsystem_}vendor r,
/sys/devices/system/node/node[0-9]*/meminfo r,
## Yubikey U2F
/sys/bus/ r,
/sys/class/ r,
/sys/class/hidraw/ r,
/sys/class/hidraw/hidraw? r,
/dev/hidraw? rw,
/run/udev/data/c240:? r,
owner @{HOME}/.cache/thumbnails/** rw,
/etc/mtab r,
/etc/fstab r,
# Needed for the crash reporter
owner @{PROC}/[0-9]*/environ r,
owner @{PROC}/[0-9]*/auxv r,
#/etc/lsb-release r,
/usr/bin/expr ix,
/sys/devices/system/cpu/ r,
/sys/devices/system/cpu/** r,
/sys/devices/platform/ff5500000dwc3/xhci-hcd.0.auto/usb*/**/hidraw* r,
# about:memory
owner @{PROC}/[0-9]*/statm r,
owner @{PROC}/[0-9]*/smaps r,
# Needed for container to work in xul builds
#/usr/lib/xulrunner-*/plugin-container ixr,
# allow access to documentation and other files the user may want to look
# at in /usr and /opt
/usr/ r,
/usr/** r,
/usr/share/fonts/util/.uuid.TMP-* r,
/usr/share/fonts/encodings/large/.uuid.TMP-* r,
#/opt/ r,
#/opt/** r,
# so browsing directories works
#/ r,
#/**/ r,
# Default profile allows downloads to ~/Downloads and uploads from ~/Public
owner @{HOME}/ r,
owner @{HOME}/Public/ r,
owner @{HOME}/Public/* r,
owner @{HOME}/Downloads/ r,
owner @{HOME}/Downloads/* rw,
# per-user firefox configuration
owner @{HOME}/.{firefox,mozilla}/ rw,
owner @{HOME}/.{firefox,mozilla}/** rw,
owner @{HOME}/.{firefox,mozilla}/**/*.{db,parentlock,sqlite}* k,
owner @{HOME}/.{firefox,mozilla}/plugins/** rm,
owner @{HOME}/.{firefox,mozilla}/**/plugins/** rm,
owner @{HOME}/.gnome2/firefox* rwk,
owner @{HOME}/.cache/mozilla/{,firefox/} rw,
owner @{HOME}/.cache/mozilla/firefox/** rw,
owner @{HOME}/.cache/mozilla/firefox/**/*.sqlite k,
owner @{HOME}/.config/gtk-3.0/bookmarks r,
owner @{HOME}/.config/dconf/user w,
owner /{,var/}run/user/*/dconf/user w,
dbus (send)
bus=session
path=/org/gnome/GConf/Server
member=GetDefaultDatabase
peer=(label=unconfined),
dbus (send)
bus=session
path=/org/gnome/GConf/Database/*
member={AddMatch,AddNotify,AllEntries,LookupExtended,RemoveNotify}
dbus (send)
bus=session
path=/org/gtk/vfs/mounttracker
interface=org.gtk.vfs.MountTracker
member=ListMountableInfo
# gnome-session
dbus (send)
bus=session
path=/org/gnome/SessionManager
interface=org.gnome.SessionManager
member={Inhibit,Uninhibit}
# unity screen API
dbus (send)
bus=system
interface="org.freedesktop.DBus.Introspectable"
path="/com/canonical/Unity/Screen"
member="Introspect"
dbus (send)
bus=system
interface="com.canonical.Unity.Screen"
member={keepDisplayOn,removeDisplayOnRequest}
# freedesktop.org ScreenSaver
dbus (send)
bus=session
path=/{,org/freedesktop/,org.gnome/}Screen{s,S}aver
interface=org.freedesktop.ScreenSaver
member={Inhibit,UnInhibit,SimulateUserActivity}
# gnome, kde and cinnamon screensaver
dbus (send)
bus=session
path=/{,ScreenSaver}
interface=org.{gnome.ScreenSaver,kde.screensaver,cinnamon.ScreenSaver}
member=SimulateUserActivity
# UPower
dbus (send)
bus=system
path=/org/freedesktop/UPower
interface=org.freedesktop.UPower
member=EnumerateDevices
# Extensions
# /usr/share/.../extensions/... is already covered by '/usr/** r', above.
# Allow 'x' for downloaded extensions, but inherit policy for safety
owner @{HOME}/.mozilla/**/extensions/** mixr,
deny @{MOZ_LIBDIR}/update.test w,
deny /usr/lib/mozilla/extensions/**/ w,
deny /usr/lib/xulrunner-addons/extensions/**/ w,
deny /usr/share/mozilla/extensions/**/ w,
deny /usr/share/mozilla/ w,
# Miscellaneous (to be abstracted)
# Ideally these would use a child profile. They are all ELF executables
# so running with 'Ux', while not ideal, is ok because we will at least
# benefit from glibc's secure execute.
/usr/bin/mkfifo Uxr, # investigate
/bin/ps Uxr,
/bin/uname Uxr,
## firejail
/run/firejail/lib/libpostexecseccomp.so mr,
/run/firejail/mnt/seccomp/seccomp.postexec r,
@{PROC}/*/fd/ r,
/run/user/@{uid}/dconf/ rw,
#/usr/bin/lsb_release Cxr -> lsb_release,
#profile lsb_release {
# #include <abstractions/base>
# #include <abstractions/python>
# /usr/bin/lsb_release r,
# /bin/dash ixr,
# /usr/bin/dpkg-query ixr,
# /usr/include/python2.[4567]/pyconfig.h r,
# /etc/lsb-release r,
# /etc/debian_version r,
# /usr/share/distro-info/*.csv r,
# /var/lib/dpkg/** r,
# /usr/local/lib/python3.[0-6]/dist-packages/ r,
# /usr/bin/ r,
# /usr/bin/python3.[0-6] mr,
# # file_inherit
# deny /tmp/gtalkplugin.log w,
Here is one for Chromium, working with ungoogled-chromium on Arch Linux. I tried to minimize necessary permissions, and added support for KeepassXC in the chromium profile.
Again it was just pulled from Ubuntu repos and modified to run on Arch Linux.
#@{chromium} = chromium{,-browser}
# We need 'flags=(attach_disconnected)' in newer chromium versions
profile chromium_browser /usr/lib/@{chromium}/@{chromium} flags=(attach_disconnected) {
#include <abstractions/dbus-session>
#include <abstractions/user-tmp>
# This include specifies which ubuntu-browsers.d abstractions to use. Eg, if
# you want access to productivity applications, adjust the following file
# accordingly.
capability sys_admin,
capability sys_chroot,
capability sys_ptrace,
## UPower
## Not sure why these are needed, so deny for now
## Differnet on Arch Linux
#deny dbus (send)
# bus=system
# path=/org/freedesktop/UPower
# interface=org.freedesktop.DBus.Properties
# member=Get
# peer=(label=unconfined),
#deny dbus (send)
# bus=system
# path=/org/freedesktop/UPower/devices/*
# member=Get
#deny dbus (send)
# bus=system
# interface=org.freedesktop.UPower
# member={EnumerateDevices,GetDisplayDevice}
#deny dbus (send)
# bus=system
# path=/org/freedesktop/hostname1
# member=GetAll
# Networking
@{PROC}/@{pid}/net/if_inet6 r,
@{PROC}/@{pid}/net/ipv6_route r,
# Should maybe be in abstractions
/etc/mime.types r,
/etc/mailcap r,
/etc/mtab r,
#/etc/xdg/xubuntu/applications/defaults.list r,
#owner @{HOME}/.local/share/applications/defaults.list r,
#owner @{HOME}/.local/share/applications/mimeinfo.cache r,
@{PROC}/self/exe ixr,
@{PROC}/@{pid}/fd/ r,
@{PROC}/vmstat r,
@{PROC}/ r,
@{PROC}/@{pid}/task/@{tid}/stat r,
owner @{PROC}/@{pid}/cmdline r,
owner @{PROC}/@{pid}/io r,
owner @{PROC}/@{pid}/setgroups w,
owner @{PROC}/@{pid}/{uid,gid}_map w,
@{PROC}/@{pid}/smaps r,
@{PROC}/@{pid}/stat r,
@{PROC}/@{pid}/statm r,
@{PROC}/@{pid}/status r,
@{PROC}/@{pid}/task/@{tid}/status r,
deny @{PROC}/@{pid}/oom_{,score_}adj w,
@{PROC}/sys/kernel/yama/ptrace_scope r,
@{PROC}/sys/net/ipv4/tcp_fastopen r,
@{PROC}/sys/fs/inotify/max_user_watches r,
# Newer chromium needs these now
# Chromium appears to want all "uevent" files under /sys/devices/
/sys/devices/**/uevent r,
/sys/devices/system/cpu/cpufreq/policy*/cpuinfo_max_freq r,
/sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_max_freq r,
/sys/devices/system/node/node*/meminfo r,
/sys/devices/pci[0-9]*/**/class r,
/sys/devices/pci[0-9]*/**/config r,
/sys/devices/pci[0-9]*/**/device r,
/sys/devices/pci[0-9]*/**/irq r,
/sys/devices/pci[0-9]*/**/resource r,
/sys/devices/pci[0-9]*/**/revision r,
/sys/devices/pci[0-9]*/**/subsystem_device r,
/sys/devices/pci[0-9]*/**/subsystem_vendor r,
/sys/devices/pci[0-9]*/**/vendor r,
/sys/devices/pci[0-9]*/**/removable r,
/sys/devices/pci[0-9]*/**/block/**/size r,
/sys/devices/virtual/block/**/removable r,
/sys/devices/virtual/block/**/size r,
/sys/devices/virtual/tty/tty*/active r,
# This is requested, but doesn't seem to actually be needed so deny for now
deny /run/udev/data/** r,
owner @{PROC}/@{pid}/auxv r,
# chromium mmaps all kinds of things for speed.
/etc/passwd m,
/usr/share/fonts/TTF/**/*.tt[cf] m,
/usr/share/fonts/**/*.pfb m,
/usr/share/mime/mime.cache m,
/usr/share/icons/**/*.cache m,
owner /{dev,run}/shm/pulse-shm* m,
owner @{HOME}/.local/share/mime/mime.cache m,
owner /tmp/** m,
@{PROC}/sys/kernel/shmmax r,
owner /{dev,run}/shm/{,.}org.chromium.* mrw,
owner /{,var/}run/shm/shmfd-* mrw,
/usr/lib/@{chromium}/*.pak mr,
/usr/lib/@{chromium}/locales/* mr,
# Noisy
deny /usr/lib/@{chromium}/** w,
# Allow ptracing ourselves and our helpers
ptrace (trace) peer=@{profile_name},
ptrace (trace) peer=@{profile_name}//xdgsettings,
ptrace (trace) peer=lsb_release,
# Make browsing directories work
/ r,
/**/ r,
# Allow access to documentation and other files the user may want to look
# at in /usr
/usr/{include,share,src}** r,
owner @{HOME}/ r,
# For migration
owner @{HOME}/.mozilla/firefox/profiles.ini r,
owner @{HOME}/.mozilla/firefox/*/prefs.js r,
# Helpers
/usr/bin/xdg-open ixr,
/usr/bin/gnome-open ixr,
/usr/bin/gvfs-open ixr,
/usr/bin/kdialog ixr,
# TODO: xfce
/usr/bin/keepassxc-proxy ixr,
# Importing firefox settings (requires 'r' access to @{HOME}/.mozilla/**
# which is provided by abstractions/ubuntu-browsers.d/user-files).
/etc/firefox/profile/bookmarks.html r,
owner @{HOME}/.mozilla/** k,
# Chromium Policies
/etc/@{chromium}/policies/managed/** r,
/etc/libva.conf r,
# Chromium configuration
owner @{HOME}/.pki/nssdb/* rwk,
owner @{HOME}/.cache/chromium/ rw,
owner @{HOME}/.cache/chromium/** rw,
owner @{HOME}/.cache/chromium/Cache/* mr,
owner @{HOME}/.config/chromium/ rw,
owner @{HOME}/.config/chromium/** rwk,
owner @{HOME}/.config/chromium/**/Cache/* mr,
owner @{HOME}/.config/chromium/Dictionaries/*.bdic mr,
owner @{HOME}/.config/chromium/**/Dictionaries/*.bdic mr,
@{HOME}/.icons/default/index.theme r,
# Allow transitions to ourself and our sandbox
/usr/lib/@{chromium}/@{chromium} ix,
/usr/lib/@{chromium}/chrome-sandbox cx -> chromium_browser_sandbox,
# Allow communicating with sandbox
unix (receive, send) peer=(label=/usr/lib/@{chromium}/@{chromium}//chromium_browser_sandbox),
/{usr/,}bin/ps Uxr,
/usr/lib/@{chromium}/xdg-settings Cxr -> xdgsettings,
/usr/bin/xdg-settings Cxr -> xdgsettings,
/usr/bin/lsb_release Pxr -> lsb_release,
# GSettings
owner /{,var/}run/user/*/dconf/ rw,
owner /{,var/}run/user/*/dconf/user rw,
owner @{HOME}/.config/dconf/user r,
# Magnet links
/usr/bin/gio ixr,
# Chrome Gnome Shell Integration
/etc/chromium/native-messaging-hosts/org.gnome.chrome_gnome_shell.json r,
/usr/bin/chrome-gnome-shell ixr,
profile xdgsettings {
#include <abstractions/bash>
/{usr/,}bin/dash ixr,
/etc/ld.so.cache r,
/etc/ld.so.preload r,
/etc/xdg/** r,
/usr/bin/xdg-settings r,
/usr/lib/@{chromium}/xdg-settings r,
/usr/share/applications/*.desktop r,
/usr/share/applications/*.list r,
# Checking default browser
/{usr/,}bin/grep ixr,
/{usr/,}bin/head ixr,
/{usr/,}bin/readlink ixr,
/{usr/,}bin/sed ixr,
/{usr/,}bin/tr ixr,
/{usr/,}bin/which ixr,
/usr/bin/cut ixr,
# Setting the default browser
/{usr/,}bin/mkdir ixr,
/{usr/,}bin/mv ixr,
/{usr/,}bin/touch ixr,
/usr/bin/gconftool-2 ix,
/usr/bin/[gm]awk ixr,
/usr/bin/xdg-mime ixr,
owner @{HOME}/.local/share/applications/ w,
owner @{HOME}/.local/share/applications/mimeapps.list* rw,
profile chromium_browser_sandbox {
# Be fanatical since it is setuid root and don't use an abstraction
/{usr/,}lib/libgcc_s.so* mr,
/{usr/,}lib/@{multiarch}/libgcc_s.so* mr,
/{usr/,}lib{,32,64}/libm-*.so* mr,
/{usr/,}lib/@{multiarch}/libm-*.so* mr,
/{usr/,}lib{,32,64}/libpthread-*.so* mr,
/{usr/,}lib/@{multiarch}/libpthread-*.so* mr,
/{usr/,}lib{,32,64}/libc-*.so* mr,
/{usr/,}lib/@{multiarch}/libc-*.so* mr,
/{usr/,}lib{,32,64}/libdl-*.so* mr,
/{usr/,}lib/@{multiarch}/libdl-*.so* mr,
/{usr/,}lib{,32,64}/libld-*.so* mr,
/{usr/,}lib/@{multiarch}/libld-*.so* mr,
/{usr/,}lib{,32,64}/librt-*.so* mr,
/{usr/,}lib/@{multiarch}/librt-*.so* mr,
/{usr/,}lib{,32,64}/ld-*.so* mr,
/{usr/,}lib/@{multiarch}/ld-*.so* mr,
/{usr/,}lib/tls/*/{cmov,nosegneg}/libm-*.so* mr,
/{usr/,}lib/tls/*/{cmov,nosegneg}/libpthread-*.so* mr,
/{usr/,}lib/tls/*/{cmov,nosegneg}/libc-*.so* mr,
/usr/lib/libatomic.so* mr,
/usr/lib/@{multiarch}/libatomic.so* mr,
/usr/lib/libstdc++.so* mr,
/usr/lib/@{multiarch}/libstdc++.so* mr,
/etc/ld.so.cache r,
# Required for dropping into PID namespace. Keep in mind that until the
# process drops this capability it can escape confinement, but once it
# drops CAP_SYS_ADMIN we are ok.
# All of these are for sanely dropping from root and chrooting
capability chown,
capability fsetid,
capability setgid,
capability setuid,
capability dac_override,
ptrace (read, readby),
signal (receive) peer=unconfined,
signal peer=@{profile_name},
signal (receive, send) set=("exists"),
signal (receive) peer=/usr/lib/@{chromium}/@{chromium},
unix (receive, send) peer=(label=/usr/lib/@{chromium}/@{chromium}),
unix (create),
unix peer=(label=@{profile_name}),
unix (getattr, getopt, setopt, shutdown) addr=none,
@{PROC}/ r,
@{PROC}/@{pid}/ r,
deny @{PROC}/@{pid}/oom_adj w,
deny @{PROC}/@{pid}/oom_score_adj w,
/usr/bin/@{chromium} r,
/usr/bin/keepassxc-proxy ix,
/usr/lib/@{chromium}/@{chromium} Px,
/usr/lib/@{chromium}/chrome-sandbox mr,
/dev/null rw,
owner /tmp/** rw,
I didn’t see any copyrights or licensing on it, so suppose it should be ok.
You could alternatively use firejail as was mentioned, and enable the firejail-default profile.
# aa-enforce firejail-default
Provided you’re running a version of firejail compiled with apparmor support.
You can also run the browser in a firejail sandbox while at the same time containing it with the AppArmor profile.
matthew@ryzen: ~ $ sudo aa-status
apparmor module is loaded.
15 profiles are loaded.
15 profiles are in enforce mode.
/usr/bin/passwd
/usr/sbin/cupsd
/usr/sbin/sshd
/usr/sbin/sshd//passwd
/usr/sbin/useradd
/usr/sbin/useradd//pam_tally2
/usr/sbin/userdel
avahi-daemon
chromium_browser
chromium_browser//chromium_browser_sandbox
chromium_browser//xdgsettings
dhcpcd
firejail-default
ping
0 profiles are in complain mode.
11 processes have profiles defined.
11 processes are in enforce mode.
/usr/lib/chromium/chromium (2813) chromium_browser
/usr/lib/chromium/chromium (2816) chromium_browser
/usr/lib/chromium/chromium (2819) chromium_browser
/usr/lib/chromium/chromium (2843) chromium_browser
/usr/lib/chromium/chromium (2848) chromium_browser
/usr/lib/chromium/chromium (2882) chromium_browser
/usr/lib/chromium/chromium (2899) chromium_browser
/usr/bin/keepassxc-proxy (2935) chromium_browser
/usr/lib/chromium/chromium (2964) chromium_browser
/usr/lib/chromium/chromium (3008) chromium_browser
/usr/bin/keepassxc (2042) firejail-default
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
I don’t have a very big system with a lot of stuff on it.
matthew@ryzen: ~ $ sudo ps aux | grep chromium
matthew 2807 0.0 0.0 4296 2564 tty2 S+ 22:31 0:00 /usr/bin/firejail /usr/bin/chromium --cipher-suite-blacklist=0xc013,0xc014,0xeaea,0x009c,0x009d,0x002f,0x0035,0x000a
matthew 2809 0.0 0.0 4296 2228 tty2 S+ 22:31 0:00 /usr/bin/firejail /usr/bin/chromium --cipher-suite-blacklist=0xc013,0xc014,0xeaea,0x009c,0x009d,0x002f,0x0035,0x000a
It definitely works, and the web browser certainly presents a large attack surface.
